[GeoNode-users] Connection error
Carmine Massarelli
carmine.massarelli at ba.irsa.cnr.it
Thu Mar 23 00:28:34 PDT 2017
unfortunately I have not install master version but production one.
Thanks again
Il 03/22/2017 05:54 PM, Francesco Bartoli ha scritto:
> Then you should use the command ‘updatelayers’ as Simone already
> suggested. GeoNode needs that layer within its configuration data.
> Hope this helps
> Il giorno 22/mar/2017, alle ore 17:47, Carmine Massarelli
> <carmine.massarelli at ba.irsa.cnr.it
> <mailto:carmine.massarelli at ba.irsa.cnr.it>> ha scritto:
>> Dear,
>> I created a new db in postgres on geonode server with postgis extension.
>> We manipulate a layer stored in that db from our local qgis istance
>> using the plugin DB manager for a remote connection.
>> If I add new store, postgis (sorry for spatialite), directly from
>> geoserver and then I create a map in geonode adding that layer I
>> receive that error.
>> thanks in advance
>> carmine
>> Il 03/22/2017 05:35 PM, Francesco Bartoli ha scritto:
>>> Hi Carmine,
>>> what do you mean with upload a spatialite layer in geoserver? Maybe
>>> using its extension for spatialite? Can you explain a little better
>>> your workflow?
>>> Il giorno 22/mar/2017, alle ore 17:17, Carmine Massarelli
>>>> thanks,
>>>> but sometimes we need to edit a spatialite layer from different
>>>> qgis desktop in remote connection to geonode postgresdb. Is it
>>>> possible without receive that error?
>>>> many thanks
>>>> carmine
>>>> Il 03/22/2017 02:50 PM, Simone Dalmasso ha scritto:
>>>>> Hi you should use Geonode to load data. Or run the updatelayers
>>>>> commands after you loaded in geoserver.
>>>>> Il giorno mer 22 mar 2017 alle 14:00 Carmine Massarelli
>>>>> Dear,
>>>>> if I upload a layer (shapefile or spatialite) directly in
>>>>> geoserver and then I create a map using local geoserver option
>>>>> to add a layer, I receive this error:
>>>>> /Connection Error//
>>>>> //The server returned an error: 404 NOT FOUND./
>>>>> If I click on Detail I can only see Page not Found.
>>>>> I use geonode version 2.4 on Ubuntu 14.04.
>>>>> How could I solve this issue?
>>>>> thank in advance
>>>>> carmine
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> <mailto:geonode-users at lists.osgeo.org>
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Simone
>>>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170323/6e957bd9/attachment-0001.html>
More information about the geonode-users
