[GeoNode-users] thumb with only basemap, no layer overlapped
Simone Dalmasso simone.dalmasso at gmail.com
Wed Mar 22 23:26:15 PDT 2017
Yes, it should be a permissions configuration. Although if you see the
layer in the geosite, then the thumbnail should work. If tihs is not the
case please open a bug in github.
Thanks
2017-03-22 22:34 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> yes, that's right.
> By the way if I set the thumb from the layer properties from one of the
> geosites the new thumb has the background but not layer. If I set the thumb
> from the master it works correctly.
> I suppose this issue is due to somehow grant of the layer at geosites
> level, isn't it?
> E.
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* mercoledì 22 marzo 2017 09.52
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: [GeoNode-users] thumb with only basemap, no layer
> overlapped
> On layer save it shouldn't keep the background, it will keep it only if
> you use set thumbnail from layer detail -> edit layer.
> 2017-03-21 17:14 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> I changed the grants of the folder:
>> /dati/geonode/geonode/contrib/geosites/uploaded/thumb and layers
>> in 755.
>> Now I have what you expected: the layer without the background.
>> If I set the thumb from the master site, it works correctly.
>> Ideas?
>> E.
>> *Inviato:* martedì 21 marzo 2017 16.09
>> *A:* Eugenio Trumpy
>> overlapped
>> Hi, I would expect the opposite, only having the layer and not the
>> background, check in geoserver logs what happens when you save the layer
>> 2017-03-21 14:56 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi all,
>>> in my geonode project (2.4.1 stable), which consists in a multi-geosite
>>> configuration,
>>> I have a problem if I modify layer information, because on saving layer
>>> the thumbnail changes and it includes only the basemap.
>>> Any idea of the cause?
>>> E.
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170323/9222c2eb/attachment.html>
More information about the geonode-users mailing list
