[GeoNode-users] thumb with only basemap, no layer overlapped
Eugenio Trumpy
frippe12573 at hotmail.com
Thu Mar 23 01:37:43 PDT 2017
I open a bug in github,
however if it interests here the output of geoserverlog: http://pastebin.com/4Kg3HHsJ
E.
[http://pastebin.com/i/facebook.png]<http://pastebin.com/4Kg3HHsJ>
Possible Spam Detected<http://pastebin.com/4Kg3HHsJ>
pastebin.com
Da: Simone Dalmasso <simone.dalmasso at gmail.com>
Inviato: giovedì 23 marzo 2017 07.26
A: Eugenio Trumpy
Cc: geonode-users at lists.osgeo.org
Oggetto: Re: [GeoNode-users] thumb with only basemap, no layer overlapped
Yes, it should be a permissions configuration. Although if you see the layer in the geosite, then the thumbnail should work. If tihs is not the case please open a bug in github.
Thanks
2017-03-22 22:34 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
yes, that's right.
By the way if I set the thumb from the layer properties from one of the geosites the new thumb has the background but not layer. If I set the thumb from the master it works correctly.
I suppose this issue is due to somehow grant of the layer at geosites level, isn't it?
E.
Da: Simone Dalmasso <simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>>
Inviato: mercoledì 22 marzo 2017 09.52
A: Eugenio Trumpy
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
On layer save it shouldn't keep the background, it will keep it only if you use set thumbnail from layer detail -> edit layer.
2017-03-21 17:14 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
I changed the grants of the folder:
/dati/geonode/geonode/contrib/geosites/uploaded/thumb and layers
in 755.
Now I have what you expected: the layer without the background.
If I set the thumb from the master site, it works correctly.
Ideas?
E.
Inviato: martedì 21 marzo 2017 16.09
A: Eugenio Trumpy
Hi, I would expect the opposite, only having the layer and not the background, check in geoserver logs what happens when you save the layer
2017-03-21 14:56 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
Hi all,
in my geonode project (2.4.1 stable), which consists in a multi-geosite configuration,
I have a problem if I modify layer information, because on saving layer
the thumbnail changes and it includes only the basemap.
Any idea of the cause?
E.
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170323/e760a5d5/attachment-0001.html>
More information about the geonode-users
