[GeoNode-users] about geonode harvesting (mutil geoserver)
Francesco Bartoli xbartolone at gmail.com
Fri Mar 24 00:58:50 PDT 2017
Hi Eugenio,
what do you mean with renaming geoserver?
Il giorno 23/mar/2017, alle ore 09:20, Eugenio Trumpy <frippe12573 at hotmail.com> ha scritto:
> Hi,
> I'm using two geoserver too in the same server. I just renamed the geoserver from geonode in geoserver2  and modified the local_setting accordingly. Then as Simone said you can add the other geoserver as external services, and you have its layer available for creating maps.
> Eugenio
> Da: geonode-users <geonode-users-bounces at lists.osgeo.org> per conto di Simone Dalmasso <simone.dalmasso at gmail.com>
> Inviato: giovedì 23 marzo 2017 07.24
> A: 원영진
> Cc: geonode-users at lists.osgeo.org
> Oggetto: Re: [GeoNode-users] about geonode harvesting (mutil geoserver)
> Hi, the geonode's geoserver is one, this because that geoserver has a specific permissions and security system.
> I geonode 2.4 and 2.6 you can use the "services"(you can find it on top right in your user's tab) app of Geoode to pair a remote OGC catalogue(i.e a remote geoserver) in your geonode.
> 2017-03-23 3:08 GMT+01:00 원영진 <icetiger at nate.com>:
> I am studying GEONODE for my testing and It helps so much more than we imagined.
> I think this is really useful solution so I am interested in learning more about your service.
> By the way, I read 'python manage.py updatelayers' of [Management Commands for GeoNode] which is linked with this:
> http://docs.geonode.org/en/master/tutorials/admin/admin_mgmt_commands/index.html#admin-mgmt-commands
> and I was wondering if there is any method to add another geoserver for search layers.
> I look forward to hearing from you soon.
> Thank you.
> ( confirm 27a58647a5cf74f94975f00887102b6985d12030 )
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170324/18018571/attachment.html>
More information about the geonode-users mailing list
