[GeoNode-users] geonode-users Digest, Vol 28, Issue 21
Federico Gianoli
alpacagis at gmail.com
Sat May 13 03:11:54 PDT 2017
Thanks Toni,
I am trying to understand how to fix this error, and I don't understand why
this has happened later than more than 50 layer correctly uploaded.
In Geoserver page, I am not able to identify where to check geowebcache, in
Tile layer window all seems working fine, I have empty cache tile, etc.
I have check Geoserver logs and there is this error message:
2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - Returning
VectorAccessLimits [readAttributes=null, writeAttributes=null,
writeFilter=Filter.EXCLUDE, readFilter=Filter.EXCLUDE, mode=HIDE] for layer
geonode:permian_wajid_gaara_aquifers_region and user
2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - Getting access
limits for workspace geonode
2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - Getting admin auth
for Workspace geonode
2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - AdminAuth filter:
RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs
ip:"147.162.47.102"+ serv:ANY req:ANY ws:"geonode"+ layer:ANY]
2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence.cache] - AdminAuth
Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs
2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - Admin auth for
User: Workspace:geonode: false
2017-05-13 05:39:19,369 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer
at
org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1341)
at
org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:240)
at
org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:85)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1498)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:673)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:258)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
Thanks a lot
Federico
2017-05-13 5:52 GMT+02:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>:
> Hi Federico,
> have you checked your log files like geoserver etc ?
> I had a similar behavior once. First I´ve tested the layer in
> geoserver layer preview. Everything worked fine. I don´t remember
> why and how but found that there are invalid layers in geowebcache.
> After removing them and a restart it worked again.
> As said logs first ;)
> Cheers,
> Toni
> > Message: 1
> > Date: Sat, 13 May 2017 00:34:53 +0200
> > From: Federico Gianoli <alpacagis at gmail.com>
> > To: geonode-users at lists.osgeo.org
> > Subject: [GeoNode-users] Error in layer preview, geonode 2.6
> > Message-ID:
> > <CAO9K6eqGBg39WNm5zRWb1r08uV4Em0ofZRGPNa0mJ+-A16BcAw at mail.
> gmail.com>
> > Content-Type: text/plain; charset="utf-8"
> > Dear list,
> > I have a problem with Geonode 2.6,
> > when I upload a layer, I can see the thumbnail with the correct symbology
> > and location,
> > but when I open the layer page, I am not able to see neither layer
> preview
> > nor legend.
> > I rebooted the server several times,I tried with a lot of different data
> > and symbologies but without results...
> > I have already populated my geonode with more than 50 layers without
> > problems and now I'm not able to understand what is happened. I tried
> with
> > another Geonode istance and everythings works correctly.
> > Has somebody had the same issue?
> > Thanks a lot
> > Federico
> > [image: Immagine incorporata 1]
> > [image: Immagine incorporata 2]
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <http://lists.osgeo.org/pipermail/geonode-users/
> attachments/20170513/8cad597c/attachment.html>
> > A non-text attachment was scrubbed...
> > Type: image/png
> > Desc: not available
> attachments/20170513/8cad597c/attachment.png>
> > Type: image/png
> > Desc: not available
> attachments/20170513/8cad597c/attachment-0001.png>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170513/78377f99/attachment.html>
More information about the geonode-users
