[GeoNode-users] geonode-users Digest, Vol 28, Issue 21
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Fri May 12 20:52:36 PDT 2017
Hi Federico,
have you checked your log files like geoserver etc ?
I had a similar behavior once. First I´ve tested the layer in
geoserver layer preview. Everything worked fine. I don´t remember
why and how but found that there are invalid layers in geowebcache.
After removing them and a restart it worked again.
As said logs first ;)
Cheers,
Toni
> Message: 1
> Date: Sat, 13 May 2017 00:34:53 +0200
> From: Federico Gianoli <alpacagis at gmail.com>
> To: geonode-users at lists.osgeo.org
> Subject: [GeoNode-users] Error in layer preview, geonode 2.6
> Message-ID:
> <CAO9K6eqGBg39WNm5zRWb1r08uV4Em0ofZRGPNa0mJ+-A16BcAw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Dear list,
> I have a problem with Geonode 2.6,
> when I upload a layer, I can see the thumbnail with the correct symbology
> and location,
> but when I open the layer page, I am not able to see neither layer preview
> nor legend.
> I rebooted the server several times,I tried with a lot of different data
> and symbologies but without results...
> I have already populated my geonode with more than 50 layers without
> problems and now I'm not able to understand what is happened. I tried with
> another Geonode istance and everythings works correctly.
> Has somebody had the same issue?
> Thanks a lot
> Federico
> [image: Immagine incorporata 1]
> [image: Immagine incorporata 2]
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170513/8cad597c/attachment.html>
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: not available
> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170513/8cad597c/attachment.png>
> Type: image/png
> Desc: not available
> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170513/8cad597c/attachment-0001.png>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170513/927b824d/attachment.sig>
More information about the geonode-users
