[GeoNode-users] GeoNode 2.6.x installation problem
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 24 00:06:38 PDT 2017
Hi I'm not expert of windows installations but from the erro I can tell you
that geoserver is not responding on localhost:8080 or 127.0.0.1:8080. Check
the geoserver installation.
Hope this helps
2017-05-24 5:21 GMT+02:00 Rasika Chinchwade <rasikachinchwade31 at gmail.com>:
> hello all,
> whenever I tried to install GeoNode 2.6.x on windows 10 OS layer creation
> gets failed.Also while uploading of layer or creating a new map that is
> giving me erroe like:
> 488] AH00354: Child: Starting 250 worker threads.
> [Wed May 24 08:35:24.219358 2017] [proxy:error] [pid 2552:tid 2552] (OS
> 10061)No connection could be made because the target machine actively
> refused it.  : AH00957: HTTP: attempt to connect to 127.0.0.1:8080
> (localhost) failed
> AH00959: ap_proxy_connect_backend disabling worker for (localhost) for 60s
> [Wed May 24 08:35:24.219358 2017] [proxy_http:error] [pid 2552:tid 2552]
> [client ::1:52302] AH01114: HTTP: failed to make connection to backend:
> localhost
> [Wed May 24 08:44:00.415267 2017] [wsgi:error] [pid 2552:tid 2568] [Errno
> 10061] No connection could be made because the target machine actively
> refused it
> Traceback (most recent call last):
> [Wed May 24 08:44:00.415267 2017] [wsgi:error] [pid 2552:tid 2568]   File
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\layers\\views.py", line 168,
> in layer_upload
> metadata_uploaded_preserve=form.cleaned_data["metadata_uploaded_preserve"]
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\layers\\utils.py", line 499,
> in file_upload
> defaults=defaults
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\
> django\\db\\models\\manager.py", line 127, in manager_method
> return getattr(self.get_queryset(), name)(*args, **kwargs)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\modeltranslation\\manager.py",
> line 389, in get_or_create
> return super(MultilingualQuerySet, self).get_or_create(**kwargs)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\django\\db\\models\\query.py",
> line 407, in get_or_create
> return self._create_object_from_params(lookup, params)
> line 439, in _create_object_from_params
> [Wed May 24 08:44:00.415267 2017] [wsgi:error] [pid 2552:tid 2568]     obj
> = self.create(**params)
> line 381, in create
> return super(MultilingualQuerySet, self).create(**kwargs)
> line 348, in create
> obj.save(force_insert=True, using=self.db)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\polymorphic\\models.py",
> line 72, in save
> return super(PolymorphicModel, self).save(*args, **kwargs)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\django\\db\\models\\base.py",
> line 734, in save
> force_update=force_update, update_fields=update_fields)
> line 758, in save_base
> django\\dispatch\\dispatcher.py", line 189, in send
> response = receiver(signal=self, sender=sender, **named)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\geoserver\\signals.py", line
> 93, in geoserver_pre_save
> charset=instance.charset)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\geoserver\\helpers.py", line
> 1059, in geoserver_upload
> workspace = cat.get_default_workspace()
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\geoserver\\catalog.py",
> line 875, in get_default_workspace
> ws.fetch()
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\geoserver\\support.py",
> line 176, in fetch
> self.dom = self.catalog.get_xml(self.href)
> line 211, in get_xml
> response, content = self.http.request(rest_url)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\httplib2\\__init__.py",
> line 1659, in request
> (response, content) = self._request(conn, authority, uri, request_uri,
> method, body, headers, redirections, cachekey)
> line 1399, in _request
> (response, content) = self._conn_request(conn, request_uri, method, body,
> headers)
> line 1319, in _conn_reques
>  File "C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages\\httplib2\\__init__.py",
> line 958, in connect
> raise socket.error, msg
> [Wed May 24 08:44:00.415267 2017] [wsgi:error] [pid 2552:tid 2568] error:
> [Errno 10061] No connection could be made because the target machine
> actively refused it
> [Wed May 24 08:44:16.567777 2017] [proxy:error] [pid 2552:tid 2568] (OS
> (localhost) failed
> [Wed May 24 08:44:16.567777 2017] [proxy_http:error] [pid 2552:tid 2568]
> [client ::1:52793] AH01114: HTTP: failed to make connection to backend:
> localhost, referer: http://localhost/maps/new
> [Wed May 24 08:44:16.567777 2017] [proxy:error] [pid 2552:tid 2544] (OS
> (localhost) failed
> [Wed May 24 08:44:16.567777 2017] [proxy_http:error] [pid 2552:tid 2544]
> [client ::1:52795] AH01114: HTTP: failed to make connection to backend:
> [Wed May 24 08:44:30.040790 2017] [wsgi:error] [pid 2552:tid 2568]
> Internal Server Error: /maps/new/data
> [Wed May 24 08:44:30.040790 2017] [wsgi:error] [pid 2552:tid 2568]   File
> django\\core\\handlers\\base.py", line 132, in get_response
> response = wrapped_callback(request, *callback_args, **callback_kwargs)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\maps\\views.py", line 501, in
> new_map_json
> map_obj.save()
> line 72, in save
> line 734, in save
> line 771, in save_base
> update_fields=update_fields, raw=raw, using=using)
> 490, in geoserver_post_save_map
> create_gs_thumbnail(instance, overwrite=True)
> 1820, in create_gs_thumbnail
> ogc_client=http_client, overwrite=overwrite, check_bbox=check_bbox)
> "C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\layers\\utils.py", line 721,
> in create_thumbnail
> resp, image = ogc_client.request(thumbnail_create_url)
> headers)
> line 1319, in _conn_request
> conn.connect()
> [Wed May 24 08:44:30.040790 2017] [wsgi:error] [pid 2552:tid 2568] error:
> actively refused it
> Please tell me what should I do .
> Thank You
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/b4262da5/attachment-0001.html>
More information about the geonode-users mailing list
