[GeoNode-users] User (no SuperUser) dont can view layers in Goserver
Abel Quesi aquesi at itssaconsulting.com
Wed Nov 1 12:57:45 PDT 2017
Hi. Again this error.
The data of layers is in SqlServer 2008 R2 in other server.
Can this to be the problem?
Regards
error at /maps/35
10053 Se ha anulado una conexi�n establecida por el software en su equipo host
Request Method:
GET
Request URL:
http://10.240.14.253/maps/35
Django Version:
1.8.17
Exception Type:
error
Exception Value:
Exception Location:
C:\GeoNode-2.6.x\Python27\Lib\socket.py in readline, line 480
Python Executable:
C:\GeoNode-2.6.x\Apache2\bin\Apache.exe
Python Version:
2.7.10
Python Path:
['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\Lib\\site-packages',
'C:\\Windows\\system32\\python27.zip',
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\DLLs',
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib',
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\plat-win',
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\lib-tk',
'C:\\GeoNode-2.6.x\\Apache2\\bin',
'C:\\GeoNode-2.6.x\\Python27\\Lib',
'C:\\GeoNode-2.6.x\\Python27\\DLLs',
'C:\\GeoNode-2.6.x\\Python27\\Lib\\lib-tk',
'C:\\GeoNode-2.6.x\\geonode-2.6.x',
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages',
'C:\\GeoNode-2.6.x\\Apache2']
Server time:
Mié, 1 Nov 2017 16:48:36 -0500
Error during template rendering
In template C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\templates\maps\map_detail.html, error at line 215
10053
205
206
        <li class="list-group-item">
207
          <h4>{% trans "Copy this map" %}</h4>
208
          <p>{% trans "Duplicate this map and modify it for your own purposes" %}</p>
209
          <a href="{% url "new_map" %}?copy={{ resource.id }}" class="btn btn-default btn-md btn-block">{% trans "Create a New Map" %}</a>
210
        </li>
211
212
        {% if resource.is_public and "change_resourcebase" in perms_list or resource.layer_group %}
213
214
          <h4>{% trans "Map WMS" %}</h4>
215
                <dl>
      {% if resource.layer_group %}
216
            <dt>{% trans "WMS layer group for local map layers" %}:</dt>
217
            <dd><em>{{ resource.layer_group.catalog.name }}</em> ({% trans "on" %} <a href="{{ resource.layer_group.ows }}?service=WMS&request=GetCapabilities">{% trans "local OWS" %}</a>)</dd>
218
            {% endif %}</dl>
219
          {% if "change_resourcebase" in perms_list %}
220
          <p>{% trans "Publish local map layers as WMS layer group" %}</p>
221
          <a id="layer-group" href="{%url "map_wms" resource.id %}" class="btn btn-default btn-md btn-block">{% trans "Publish Map WMS" %}</a>
222
          {% endif %}
223
          <dl id="layer-group-dl"></dl>
224
        </li>
225
        {% endif %}
Traceback  <http://10.240.14.253/maps/35> Switch to copy-and-paste view
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\core\handlers\base.py in get_response
132.                                          response = wrapped_callback(request, *callback_args, **callback_kwargs)
·          <http://10.240.14.253/maps/35> ▶ Local vars
·         C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\views.py in map_detail
152.                          return render_to_response(template, RequestContext(request, context_dict))
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\shortcuts.py in render_to_response
39.                     content = loader.render_to_string(template_name, context, using=using)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\loader.py in render_to_string
99.                     return template.render(context, request)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\backends\django.py in render
74.                     return self.template.render(context)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py in render
210.                                          return self._render(context)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py in _render
202.                              return self.nodelist.render(context)
905.                                      bit = self.render_node(node, context)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\debug.py in render_node
79.                         return node.render(context)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\loader_tags.py in render
135.                              return compiled_parent._render(context)
65.                             result = block.nodelist.render(context)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\defaulttags.py in render
329.                                      return nodelist.render(context)
322.                                          match = condition.eval(context)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\defaulttags.py in eval
937.                              return self.value.resolve(context, ignore_failures=True)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py in resolve
648.                                      obj = self.var.resolve(context)
789.                                  value = self._resolve_lookup(context)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py in _resolve_lookup
827.                                              current = getattr(current, bit)
·         C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\models.py in layer_group
317.                                      'catalog': gs_catalog.get_layergroup(lg_name),
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\geoserver\catalog.py in get_layergroup
753.                                  group = self.get_xml(group_url)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\geoserver\catalog.py in get_xml
211.                                  response, content = self.http.request(rest_url)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\httplib2\__init__.py in request
1659.                                        (response, content) = self._request(conn, authority, uri, request_uri, method, body, headers, redirections, cachekey)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\httplib2\__init__.py in _request
1399.                            (response, content) = self._conn_request(conn, request_uri, method, body, headers)
·         C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\httplib2\__init__.py in _conn_request
1355.                                    response = conn.getresponse()
·         C:\GeoNode-2.6.x\Python27\Lib\httplib.py in getresponse
1132.                                response.begin()
·         C:\GeoNode-2.6.x\Python27\Lib\httplib.py in begin
453.                                  version, status, reason = self._read_status()
·         C:\GeoNode-2.6.x\Python27\Lib\httplib.py in _read_status
409.                              line = self.fp.readline(_MAXLINE + 1)
·         C:\GeoNode-2.6.x\Python27\Lib\socket.py in readline
480.                                          data = self._sock.recv(self._rbufsize)
Principio del formulario
Final del formulario
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable
Value
csrftoken
'uqa3WGQiktOATVPh3szwzVhRTVtgSoA8'
sessionid
'vetz9syzi9tsxmdwvrkh0zhu9j2ho07e'
JSESSIONID
'71ADDD4F3DB218863FF7DEC132DC8258'
META
Variable
Value
wsgi.multiprocess
False
HTTP_COOKIE
'JSESSIONID=71ADDD4F3DB218863FF7DEC132DC8258; sessionid=vetz9syzi9tsxmdwvrkh0zhu9j2ho07e; csrftoken=uqa3WGQiktOATVPh3szwzVhRTVtgSoA8'
SERVER_PROTOCOL
'HTTP/1.1'
SERVER_SOFTWARE
'Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10'
SCRIPT_NAME
u''
mod_wsgi.enable_sendfile
'0'
mod_wsgi.handler_script
SERVER_SIGNATURE
REQUEST_METHOD
'GET'
PATH_INFO
u'/maps/35'
SystemRoot
'C:\\Windows'
QUERY_STRING
wsgi.errors
<mod_wsgi.Log object at 0x11015B88>
HTTP_USER_AGENT
'Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/62.0.3202.75 Safari/537.36'
HTTP_CONNECTION
'keep-alive'
HTTP_REFERER
'http://10.240.14.253/maps/?limit=100&offset=0'
SERVER_NAME
'10.240.14.253'
REMOTE_ADDR
'10.240.14.19'
mod_wsgi.request_handler
'wsgi-script'
apache.version
(2, 4, 10)
wsgi.url_scheme
'http'
PATH_TRANSLATED
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\wsgi.py\\maps\\35'
SERVER_PORT
'80'
mod_wsgi.version
(4, 4, 21)
SERVER_ADDR
'10.240.14.253'
DOCUMENT_ROOT
'C:/GeoNode-2.6.x/geonode-2.6.x/geonode'
mod_wsgi.process_group
CONTEXT_DOCUMENT_ROOT
COMSPEC
'C:\\Windows\\system32\\cmd.exe'
mod_wsgi.path_info
'/maps/35'
SCRIPT_FILENAME
'C:/GeoNode-2.6.x/geonode-2.6.x/geonode/wsgi.py'
SERVER_ADMIN
'webmaster at example.org'
wsgi.input
<mod_wsgi.Input object at 0x129A1BC0>
HTTP_HOST
'10.240.14.253'
CONTEXT_PREFIX
mod_wsgi.callable_object
'application'
wsgi.multithread
True
PATHEXT
'.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC'
REQUEST_URI
'/maps/35'
HTTP_ACCEPT
'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8'
WINDIR
'C:\\Windows'
wsgi.file_wrapper
wsgi.version
(1, 0)
GATEWAY_INTERFACE
'CGI/1.1'
wsgi.run_once
False
mod_wsgi.script_name
REMOTE_PORT
'49999'
HTTP_ACCEPT_LANGUAGE
'es-ES,es;q=0.9'
REQUEST_SCHEME
'http'
CSRF_COOKIE_USED
True
mod_wsgi.script_start
'1509565715352539'
HTTP_UPGRADE_INSECURE_REQUESTS
'1'
mod_wsgi.application_group
'localhost|'
mod_wsgi.script_reloading
'1'
mod_wsgi.request_start
'1509565715352539'
CSRF_COOKIE
u'uqa3WGQiktOATVPh3szwzVhRTVtgSoA8'
HTTP_ACCEPT_ENCODING
'gzip, deflate'
Settings
Using settings module geonode.settings
Setting
Value
_DEFAULT_LOCALE_PATHS
('C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\locale',)
CASCADE_WORKSPACE
'geonode'
DEFAULT_WORKSPACE
'geonode'
ACCOUNT_USER_DISPLAY
<function <lambda> at 0x0A8426B0>
DATABASES
{'datastore': {'ATOMIC_REQUESTS': False,
               'AUTOCOMMIT': True,
               'CONN_MAX_AGE': 0,
               'ENGINE': 'django.contrib.gis.db.backends.postgis',
               'HOST': 'localhost',
               'NAME': 'geonode_imports',
               'OPTIONS': {},
               'PASSWORD': u'********************',
               'PORT': '5454',
               'TEST': {'CHARSET': None,
                        'COLLATION': None,
                        'MIRROR': None,
                        'NAME': None},
               'TIME_ZONE': 'America/Chicago',
               'USER': 'geonode'},
'default': {'ATOMIC_REQUESTS': False,
             'AUTOCOMMIT': True,
             'CONN_MAX_AGE': 0,
             'ENGINE': 'django.db.backends.postgresql_psycopg2',
             'NAME': 'geonode',
             'OPTIONS': {},
             'PORT': '5454',
                      'COLLATION': None,
                      'MIRROR': None,
                      'NAME': None},
             'USER': 'geonode'}}
AWS_QUERYSTRING_AUTH
False
CELERY_CREATE_MISSING_QUEUES
True
GEONODE_CONTRIB_APPS
('geonode.contrib.dynamic',
'geonode.contrib.exif',
'geonode.contrib.favorite',
'geonode.contrib.geogig',
'geonode.contrib.geosites',
'geonode.contrib.nlp',
'geonode.contrib.slack',
'geonode.contrib.metadataxsl')
CSRF_COOKIE_SECURE
False
CELERY_DEFAULT_QUEUE
'default'
UPLOADER
{'BACKEND': 'geonode.rest',
'OPTIONS': {'GEOGIG_ENABLED': False,
             'MOSAIC_ENABLED': False,
             'TIME_ENABLED': False}}
LANGUAGE_CODE
'en'
LICENSES
{'DETAIL': 'above', 'ENABLED': True, 'METADATA': 'verbose'}
MANAGERS
DOWNLOAD_FORMATS_METADATA
['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO']
BROKER_URL
'django://'
SILENCED_SYSTEM_CHECKS
DEFAULT_CHARSET
'utf-8'
IGNORABLE_404_URLS
CELERY_DEFAULT_EXCHANGE_TYPE
'direct'
GDAL_LIBRARY_PATH
'C:\\GeoNode-2.6.x\\GDAL\\gdal111.dll'
DEFAULT_MAP_CENTER
(0, 0)
ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
3
TIME_INPUT_FORMATS
('%H:%M:%S', '%H:%M:%S.%f', '%H:%M')
ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
None
ACCOUNT_INVITE_USER_URL
u'account_invite_user'
REGISTRATION_OPEN
0
ALLOWED_HOSTS
['localhost', 'django', '10.240.14.253']
EMAIL_HOST
'localhost'
DOWNLOAD_FORMATS_RASTER
['JPEG',
'PDF',
'PNG',
'ArcGrid',
'GeoTIFF',
'Gtopo30',
'ImageMosaic',
'KML',
'View in Google Earth',
'Tiles',
'GML',
'GZIP']
AUTH_EXEMPT_URLS
WSGI_APPLICATION
None
EMAIL_SUBJECT_PREFIX
'[Django] '
SERVER_EMAIL
'root at localhost'
SECURE_HSTS_SECONDS
0
STATICFILES_FINDERS
('django.contrib.staticfiles.finders.FileSystemFinder',
'django.contrib.staticfiles.finders.AppDirectoriesFinder')
NOTIFICATION_QUEUE_ALL
False
S3_MEDIA_ENABLED
False
CELERY_IMPORTS
('geonode.tasks.deletion', 'geonode.tasks.update', 'geonode.tasks.email')
SESSION_COOKIE_DOMAIN
None
SESSION_COOKIE_NAME
'sessionid'
GEOSERVER_PUBLIC_LOCATION
'http://10.240.14.253:8080/geoserver/'
AWS_STORAGE_BUCKET_NAME
AWS_BUCKET_NAME
SECURE_REDIRECT_EXEMPT
ACCOUNT_USE_AUTH_AUTHENTICATE
False
EMAIL_SSL_KEYFILE
FILE_UPLOAD_DIRECTORY_PERMISSIONS
None
X_FRAME_OPTIONS
'SAMEORIGIN'
FILE_UPLOAD_PERMISSIONS
None
ACCOUNT_TIMEZONES
[('Africa/Abidjan', 'Africa/Abidjan'),
('Africa/Accra', 'Africa/Accra'),
('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
('Africa/Algiers', 'Africa/Algiers'),
('Africa/Asmara', 'Africa/Asmara'),
('Africa/Asmera', 'Africa/Asmera'),
('Africa/Bamako', 'Africa/Bamako'),
('Africa/Bangui', 'Africa/Bangui'),
('Africa/Banjul', 'Africa/Banjul'),
('Africa/Bissau', 'Africa/Bissau'),
('Africa/Blantyre', 'Africa/Blantyre'),
('Africa/Brazzaville', 'Africa/Brazzaville'),
('Africa/Bujumbura', 'Africa/Bujumbura'),
('Africa/Cairo', 'Africa/Cairo'),
('Africa/Casablanca', 'Africa/Casablanca'),
('Africa/Ceuta', 'Africa/Ceuta'),
('Africa/Conakry', 'Africa/Conakry'),
('Africa/Dakar', 'Africa/Dakar'),
('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
('Africa/Djibouti', 'Africa/Djibouti'),
('Africa/Douala', 'Africa/Douala'),
('Africa/El_Aaiun', 'Africa/El_Aaiun'),
('Africa/Freetown', 'Africa/Freetown'),
('Africa/Gaborone', 'Africa/Gaborone'),
('Africa/Harare', 'Africa/Harare'),
('Africa/Johannesburg', 'Africa/Johannesburg'),
('Africa/Juba', 'Africa/Juba'),
('Africa/Kampala', 'Africa/Kampala'),
('Africa/Khartoum', 'Africa/Khartoum'),
('Africa/Kigali', 'Africa/Kigali'),
('Africa/Kinshasa', 'Africa/Kinshasa'),
('Africa/Lagos', 'Africa/Lagos'),
('Africa/Libreville', 'Africa/Libreville'),
('Africa/Lome', 'Africa/Lome'),
('Africa/Luanda', 'Africa/Luanda'),
('Africa/Lubumbashi', 'Africa/Lubumbashi'),
('Africa/Lusaka', 'Africa/Lusaka'),
('Africa/Malabo', 'Africa/Malabo'),
('Africa/Maputo', 'Africa/Maputo'),
('Africa/Maseru', 'Africa/Maseru'),
('Africa/Mbabane', 'Africa/Mbabane'),
('Africa/Mogadishu', 'Africa/Mogadishu'),
('Africa/Monrovia', 'Africa/Monrovia'),
('Africa/Nairobi', 'Africa/Nairobi'),
('Africa/Ndjamena', 'Africa/Ndjamena'),
('Africa/Niamey', 'Africa/Niamey'),
('Africa/Nouakchott', 'Africa/Nouakchott'),
('Africa/Ouagadougou', 'Africa/Ouagadougou'),
('Africa/Porto-Novo', 'Africa/Porto-Novo'),
('Africa/Sao_Tome', 'Africa/Sao_Tome'),
('Africa/Timbuktu', 'Africa/Timbuktu'),
('Africa/Tripoli', 'Africa/Tripoli'),
('Africa/Tunis', 'Africa/Tunis'),
('Africa/Windhoek', 'Africa/Windhoek'),
('America/Adak', 'America/Adak'),
('America/Anchorage', 'America/Anchorage'),
('America/Anguilla', 'America/Anguilla'),
('America/Antigua', 'America/Antigua'),
('America/Araguaina', 'America/Araguaina'),
('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
('America/Argentina/Salta', 'America/Argentina/Salta'),
('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
('America/Aruba', 'America/Aruba'),
('America/Asuncion', 'America/Asuncion'),
('America/Atikokan', 'America/Atikokan'),
('America/Atka', 'America/Atka'),
('America/Bahia', 'America/Bahia'),
('America/Bahia_Banderas', 'America/Bahia_Banderas'),
('America/Barbados', 'America/Barbados'),
('America/Belem', 'America/Belem'),
('America/Belize', 'America/Belize'),
('America/Blanc-Sablon', 'America/Blanc-Sablon'),
('America/Boa_Vista', 'America/Boa_Vista'),
('America/Bogota', 'America/Bogota'),
('America/Boise', 'America/Boise'),
('America/Buenos_Aires', 'America/Buenos_Aires'),
('America/Cambridge_Bay', 'America/Cambridge_Bay'),
('America/Campo_Grande', 'America/Campo_Grande'),
('America/Cancun', 'America/Cancun'),
('America/Caracas', 'America/Caracas'),
('America/Catamarca', 'America/Catamarca'),
('America/Cayenne', 'America/Cayenne'),
('America/Cayman', 'America/Cayman'),
('America/Chicago', 'America/Chicago'),
('America/Chihuahua', 'America/Chihuahua'),
('America/Coral_Harbour', 'America/Coral_Harbour'),
('America/Cordoba', 'America/Cordoba'),
('America/Costa_Rica', 'America/Costa_Rica'),
('America/Creston', 'America/Creston'),
('America/Cuiaba', 'America/Cuiaba'),
('America/Curacao', 'America/Curacao'),
('America/Danmarkshavn', 'America/Danmarkshavn'),
('America/Dawson', 'America/Dawson'),
('America/Dawson_Creek', 'America/Dawson_Creek'),
('America/Denver', 'America/Denver'),
('America/Detroit', 'America/Detroit'),
('America/Dominica', 'America/Dominica'),
('America/Edmonton', 'America/Edmonton'),
('America/Eirunepe', 'America/Eirunepe'),
('America/El_Salvador', 'America/El_Salvador'),
('America/Ensenada', 'America/Ensenada'),
('America/Fort_Nelson', 'America/Fort_Nelson'),
('America/Fort_Wayne', 'America/Fort_Wayne'),
('America/Fortaleza', 'America/Fortaleza'),
('America/Glace_Bay', 'America/Glace_Bay'),
('America/Godthab', 'America/Godthab'),
('America/Goose_Bay', 'America/Goose_Bay'),
('America/Grand_Turk', 'America/Grand_Turk'),
('America/Grenada', 'America/Grenada'),
('America/Guadeloupe', 'America/Guadeloupe'),
('America/Guatemala', 'America/Guatemala'),
('America/Guayaquil', 'America/Guayaquil'),
('America/Guyana', 'America/Guyana'),
('America/Halifax', 'America/Halifax'),
('America/Havana', 'America/Havana'),
('America/Hermosillo', 'America/Hermosillo'),
('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
('America/Indiana/Knox', 'America/Indiana/Knox'),
('America/Indiana/Marengo', 'America/Indiana/Marengo'),
('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
('America/Indiana/Vevay', 'America/Indiana/Vevay'),
('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
('America/Indiana/Winamac', 'America/Indiana/Winamac'),
('America/Indianapolis', 'America/Indianapolis'),
('America/Inuvik', 'America/Inuvik'),
('America/Iqaluit', 'America/Iqaluit'),
('America/Jamaica', 'America/Jamaica'),
('America/Jujuy', 'America/Jujuy'),
('America/Juneau', 'America/Juneau'),
('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
('America/Knox_IN', 'America/Knox_IN'),
('America/Kralendijk', 'America/Kralendijk'),
('America/La_Paz', 'America/La_Paz'),
('America/Lima', 'America/Lima'),
('America/Los_Angeles', 'America/Los_Angeles'),
('America/Louisville', 'America/Louisville'),
('America/Lower_Princes', 'America/Lower_Princes'),
('America/Maceio', 'America/Maceio'),
('America/Managua', 'America/Managua'),
('America/Manaus', 'America/Manaus'),
('America/Marigot', 'America/Marigot'),
('America/Martinique', 'America/Martinique'),
('America/Matamoros', 'America/Matamoros'),
('America/Mazatlan', 'America/Mazatlan'),
('America/Mendoza', 'America/Mendoza'),
('America/Menominee', 'America/Menominee'),
('America/Merida', 'America/Merida'),
('America/Metlakatla', 'America/Metlakatla'),
('America/Mexico_City', 'America/Mexico_City'),
('America/Miquelon', 'America/Miquelon'),
('America/Moncton', 'America/Moncton'),
('America/Monterrey', 'America/Monterrey'),
('America/Montevideo', 'America/Montevideo'),
('America/Montreal', 'America/Montreal'),
('America/Montserrat', 'America/Montserrat'),
('America/Nassau', 'America/Nassau'),
('America/New_York', 'America/New_York'),
('America/Nipigon', 'America/Nipigon'),
('America/Nome', 'America/Nome'),
('America/Noronha', 'America/Noronha'),
('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
('America/North_Dakota/Center', 'America/North_Dakota/Center'),
('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
('America/Ojinaga', 'America/Ojinaga'),
('America/Panama', 'America/Panama'),
('America/Pangnirtung', 'America/Pangnirtung'),
('America/Paramaribo', 'America/Paramaribo'),
('America/Phoenix', 'America/Phoenix'),
('America/Port-au-Prince', 'America/Port-au-Prince'),
('America/Port_of_Spain', 'America/Port_of_Spain'),
('America/Porto_Acre', 'America/Porto_Acre'),
('America/Porto_Velho', 'America/Porto_Velho'),
('America/Puerto_Rico', 'America/Puerto_Rico'),
('America/Rainy_River', 'America/Rainy_River'),
('America/Rankin_Inlet', 'America/Rankin_Inlet'),
('America/Recife', 'America/Recife'),
('America/Regina', 'America/Regina'),
('America/Resolute', 'America/Resolute'),
('America/Rio_Branco', 'America/Rio_Branco'),
('America/Rosario', 'America/Rosario'),
('America/Santa_Isabel', 'America/Santa_Isabel'),
('America/Santarem', 'America/Santarem'),
('America/Santiago', 'America/Santiago'),
('America/Santo_Domingo', 'America/Santo_Domingo'),
('America/Sao_Paulo', 'America/Sao_Paulo'),
('America/Scoresbysund', 'America/Scoresbysund'),
('America/Shiprock', 'America/Shiprock'),
('America/Sitka', 'America/Sitka'),
('America/St_Barthelemy', 'America/St_Barthelemy'),
('America/St_Johns', 'America/St_Johns'),
('America/St_Kitts', 'America/St_Kitts'),
('America/St_Lucia', 'America/St_Lucia'),
('America/St_Thomas', 'America/St_Thomas'),
('America/St_Vincent', 'America/St_Vincent'),
('America/Swift_Current', 'America/Swift_Current'),
('America/Tegucigalpa', 'America/Tegucigalpa'),
('America/Thule', 'America/Thule'),
('America/Thunder_Bay', 'America/Thunder_Bay'),
('America/Tijuana', 'America/Tijuana'),
('America/Toronto', 'America/Toronto'),
('America/Tortola', 'America/Tortola'),
('America/Vancouver', 'America/Vancouver'),
('America/Virgin', 'America/Virgin'),
('America/Whitehorse', 'America/Whitehorse'),
('America/Winnipeg', 'America/Winnipeg'),
('America/Yakutat', 'America/Yakutat'),
('America/Yellowknife', 'America/Yellowknife'),
('Antarctica/Casey', 'Antarctica/Casey'),
('Antarctica/Davis', 'Antarctica/Davis'),
('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
('Antarctica/Macquarie', 'Antarctica/Macquarie'),
('Antarctica/Mawson', 'Antarctica/Mawson'),
('Antarctica/McMurdo', 'Antarctica/McMurdo'),
('Antarctica/Palmer', 'Antarctica/Palmer'),
('Antarctica/Rothera', 'Antarctica/Rothera'),
('Antarctica/South_Pole', 'Antarctica/South_Pole'),
('Antarctica/Syowa', 'Antarctica/Syowa'),
('Antarctica/Troll', 'Antarctica/Troll'),
('Antarctica/Vostok', 'Antarctica/Vostok'),
('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
('Asia/Aden', 'Asia/Aden'),
('Asia/Almaty', 'Asia/Almaty'),
('Asia/Amman', 'Asia/Amman'),
('Asia/Anadyr', 'Asia/Anadyr'),
('Asia/Aqtau', 'Asia/Aqtau'),
('Asia/Aqtobe', 'Asia/Aqtobe'),
('Asia/Ashgabat', 'Asia/Ashgabat'),
('Asia/Ashkhabad', 'Asia/Ashkhabad'),
('Asia/Atyrau', 'Asia/Atyrau'),
('Asia/Baghdad', 'Asia/Baghdad'),
('Asia/Bahrain', 'Asia/Bahrain'),
('Asia/Baku', 'Asia/Baku'),
('Asia/Bangkok', 'Asia/Bangkok'),
('Asia/Barnaul', 'Asia/Barnaul'),
('Asia/Beirut', 'Asia/Beirut'),
('Asia/Bishkek', 'Asia/Bishkek'),
('Asia/Brunei', 'Asia/Brunei'),
('Asia/Calcutta', 'Asia/Calcutta'),
('Asia/Chita', 'Asia/Chita'),
('Asia/Choibalsan', 'Asia/Choibalsan'),
('Asia/Chongqing', 'Asia/Chongqing'),
('Asia/Chungking', 'Asia/Chungking'),
('Asia/Colombo', 'Asia/Colombo'),
('Asia/Dacca', 'Asia/Dacca'),
('Asia/Damascus', 'Asia/Damascus'),
('Asia/Dhaka', 'Asia/Dhaka'),
('Asia/Dili', 'Asia/Dili'),
('Asia/Dubai', 'Asia/Dubai'),
('Asia/Dushanbe', 'Asia/Dushanbe'),
('Asia/Famagusta', 'Asia/Famagusta'),
('Asia/Gaza', 'Asia/Gaza'),
('Asia/Harbin', 'Asia/Harbin'),
('Asia/Hebron', 'Asia/Hebron'),
('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
('Asia/Hong_Kong', 'Asia/Hong_Kong'),
('Asia/Hovd', 'Asia/Hovd'),
('Asia/Irkutsk', 'Asia/Irkutsk'),
('Asia/Istanbul', 'Asia/Istanbul'),
('Asia/Jakarta', 'Asia/Jakarta'),
('Asia/Jayapura', 'Asia/Jayapura'),
('Asia/Jerusalem', 'Asia/Jerusalem'),
('Asia/Kabul', 'Asia/Kabul'),
('Asia/Kamchatka', 'Asia/Kamchatka'),
('Asia/Karachi', 'Asia/Karachi'),
('Asia/Kashgar', 'Asia/Kashgar'),
('Asia/Kathmandu', 'Asia/Kathmandu'),
('Asia/Katmandu', 'Asia/Katmandu'),
('Asia/Khandyga', 'Asia/Khandyga'),
('Asia/Kolkata', 'Asia/Kolkata'),
('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
('Asia/Kuching', 'Asia/Kuching'),
('Asia/Kuwait', 'Asia/Kuwait'),
('Asia/Macao', 'Asia/Macao'),
('Asia/Macau', 'Asia/Macau'),
('Asia/Magadan', 'Asia/Magadan'),
('Asia/Makassar', 'Asia/Makassar'),
('Asia/Manila', 'Asia/Manila'),
('Asia/Muscat', 'Asia/Muscat'),
('Asia/Nicosia', 'Asia/Nicosia'),
('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
('Asia/Novosibirsk', 'Asia/Novosibirsk'),
('Asia/Omsk', 'Asia/Omsk'),
('Asia/Oral', 'Asia/Oral'),
('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
('Asia/Pontianak', 'Asia/Pontianak'),
('Asia/Pyongyang', 'Asia/Pyongyang'),
('Asia/Qatar', 'Asia/Qatar'),
('Asia/Qyzylorda', 'Asia/Qyzylorda'),
('Asia/Rangoon', 'Asia/Rangoon'),
('Asia/Riyadh', 'Asia/Riyadh'),
('Asia/Saigon', 'Asia/Saigon'),
('Asia/Sakhalin', 'Asia/Sakhalin'),
('Asia/Samarkand', 'Asia/Samarkand'),
('Asia/Seoul', 'Asia/Seoul'),
('Asia/Shanghai', 'Asia/Shanghai'),
('Asia/Singapore', 'Asia/Singapore'),
('Asia/Srednekolymsk', 'Asia/Srednekolymsk'),
('Asia/Taipei', 'Asia/Taipei'),
('Asia/Tashkent', 'Asia/Tashkent'),
('Asia/Tbilisi', 'Asia/Tbilisi'),
('Asia/Tehran', 'Asia/Tehran'),
('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
('Asia/Thimbu', 'Asia/Thimbu'),
('Asia/Thimphu', 'Asia/Thimphu'),
('Asia/Tokyo', 'Asia/Tokyo'),
('Asia/Tomsk', 'Asia/Tomsk'),
('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
('Asia/Urumqi', 'Asia/Urumqi'),
('Asia/Ust-Nera', 'Asia/Ust-Nera'),
('Asia/Vientiane', 'Asia/Vientiane'),
('Asia/Vladivostok', 'Asia/Vladivostok'),
('Asia/Yakutsk', 'Asia/Yakutsk'),
('Asia/Yangon', 'Asia/Yangon'),
('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
('Asia/Yerevan', 'Asia/Yerevan'),
('Atlantic/Azores', 'Atlantic/Azores'),
('Atlantic/Bermuda', 'Atlantic/Bermuda'),
('Atlantic/Canary', 'Atlantic/Canary'),
('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
('Atlantic/Faeroe', 'Atlantic/Faeroe'),
('Atlantic/Faroe', 'Atlantic/Faroe'),
('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
('Atlantic/Madeira', 'Atlantic/Madeira'),
('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
('Atlantic/St_Helena', 'Atlantic/St_Helena'),
('Atlantic/Stanley', 'Atlantic/Stanley'),
('Australia/ACT', 'Australia/ACT'),
('Australia/Adelaide', 'Australia/Adelaide'),
('Australia/Brisbane', 'Australia/Brisbane'),
('Australia/Broken_Hill', 'Australia/Broken_Hill'),
('Australia/Canberra', 'Australia/Canberra'),
('Australia/Currie', 'Australia/Currie'),
('Australia/Darwin', 'Australia/Darwin'),
('Australia/Eucla', 'Australia/Eucla'),
('Australia/Hobart', 'Australia/Hobart'),
('Australia/LHI', 'Australia/LHI'),
('Australia/Lindeman', 'Australia/Lindeman'),
('Australia/Lord_Howe', 'Australia/Lord_Howe'),
('Australia/Melbourne', 'Australia/Melbourne'),
('Australia/NSW', 'Australia/NSW'),
('Australia/North', 'Australia/North'),
('Australia/Perth', 'Australia/Perth'),
('Australia/Queensland', 'Australia/Queensland'),
('Australia/South', 'Australia/South'),
('Australia/Sydney', 'Australia/Sydney'),
('Australia/Tasmania', 'Australia/Tasmania'),
('Australia/Victoria', 'Australia/Victoria'),
('Australia/West', 'Australia/West'),
('Australia/Yancowinna', 'Australia/Yancowinna'),
('Brazil/Acre', 'Brazil/Acre'),
('Brazil/DeNoronha', 'Brazil/DeNoronha'),
('Brazil/East', 'Brazil/East'),
('Brazil/West', 'Brazil/West'),
('CET', 'CET'),
('CST6CDT', 'CST6CDT'),
('Canada/Atlantic', 'Canada/Atlantic'),
('Canada/Central', 'Canada/Central'),
('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
('Canada/Eastern', 'Canada/Eastern'),
('Canada/Mountain', 'Canada/Mountain'),
('Canada/Newfoundland', 'Canada/Newfoundland'),
('Canada/Pacific', 'Canada/Pacific'),
('Canada/Saskatchewan', 'Canada/Saskatchewan'),
('Canada/Yukon', 'Canada/Yukon'),
('Chile/Continental', 'Chile/Continental'),
('Chile/EasterIsland', 'Chile/EasterIsland'),
('Cuba', 'Cuba'),
('EET', 'EET'),
('EST', 'EST'),
('EST5EDT', 'EST5EDT'),
('Egypt', 'Egypt'),
('Eire', 'Eire'),
('Etc/GMT', 'Etc/GMT'),
('Etc/GMT+0', 'Etc/GMT+0'),
('Etc/GMT+1', 'Etc/GMT+1'),
('Etc/GMT+10', 'Etc/GMT+10'),
('Etc/GMT+11', 'Etc/GMT+11'),
('Etc/GMT+12', 'Etc/GMT+12'),
('Etc/GMT+2', 'Etc/GMT+2'),
('Etc/GMT+3', 'Etc/GMT+3'),
('Etc/GMT+4', 'Etc/GMT+4'),
('Etc/GMT+5', 'Etc/GMT+5'),
('Etc/GMT+6', 'Etc/GMT+6'),
('Etc/GMT+7', 'Etc/GMT+7'),
('Etc/GMT+8', 'Etc/GMT+8'),
('Etc/GMT+9', 'Etc/GMT+9'),
('Etc/GMT-0', 'Etc/GMT-0'),
('Etc/GMT-1', 'Etc/GMT-1'),
('Etc/GMT-10', 'Etc/GMT-10'),
('Etc/GMT-11', 'Etc/GMT-11'),
('Etc/GMT-12', 'Etc/GMT-12'),
('Etc/GMT-13', 'Etc/GMT-13'),
('Etc/GMT-14', 'Etc/GMT-14'),
('Etc/GMT-2', 'Etc/GMT-2'),
('Etc/GMT-3', 'Etc/GMT-3'),
('Etc/GMT-4', 'Etc/GMT-4'),
('Etc/GMT-5', 'Etc/GMT-5'),
('Etc/GMT-6', 'Etc/GMT-6'),
('Etc/GMT-7', 'Etc/GMT-7'),
('Etc/GMT-8', 'Etc/GMT-8'),
('Etc/GMT-9', 'Etc/GMT-9'),
('Etc/GMT0', 'Etc/GMT0'),
('Etc/Greenwich', 'Etc/Greenwich'),
('Etc/UCT', 'Etc/UCT'),
('Etc/UTC', 'Etc/UTC'),
('Etc/Universal', 'Etc/Universal'),
('Etc/Zulu', 'Etc/Zulu'),
('Europe/Amsterdam', 'Europe/Amsterdam'),
('Europe/Andorra', 'Europe/Andorra'),
('Europe/Astrakhan', 'Europe/Astrakhan'),
('Europe/Athens', 'Europe/Athens'),
('Europe/Belfast', 'Europe/Belfast'),
('Europe/Belgrade', 'Europe/Belgrade'),
('Europe/Berlin', 'Europe/Berlin'),
('Europe/Bratislava', 'Europe/Bratislava'),
('Europe/Brussels', 'Europe/Brussels'),
('Europe/Bucharest', 'Europe/Bucharest'),
('Europe/Budapest', 'Europe/Budapest'),
('Europe/Busingen', 'Europe/Busingen'),
('Europe/Chisinau', 'Europe/Chisinau'),
('Europe/Copenhagen', 'Europe/Copenhagen'),
('Europe/Dublin', 'Europe/Dublin'),
('Europe/Gibraltar', 'Europe/Gibraltar'),
('Europe/Guernsey', 'Europe/Guernsey'),
('Europe/Helsinki', 'Europe/Helsinki'),
('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
('Europe/Istanbul', 'Europe/Istanbul'),
('Europe/Jersey', 'Europe/Jersey'),
('Europe/Kaliningrad', 'Europe/Kaliningrad'),
('Europe/Kiev', 'Europe/Kiev'),
('Europe/Kirov', 'Europe/Kirov'),
('Europe/Lisbon', 'Europe/Lisbon'),
('Europe/Ljubljana', 'Europe/Ljubljana'),
('Europe/London', 'Europe/London'),
('Europe/Luxembourg', 'Europe/Luxembourg'),
('Europe/Madrid', 'Europe/Madrid'),
('Europe/Malta', 'Europe/Malta'),
('Europe/Mariehamn', 'Europe/Mariehamn'),
('Europe/Minsk', 'Europe/Minsk'),
('Europe/Monaco', 'Europe/Monaco'),
('Europe/Moscow', 'Europe/Moscow'),
('Europe/Nicosia', 'Europe/Nicosia'),
('Europe/Oslo', 'Europe/Oslo'),
('Europe/Paris', 'Europe/Paris'),
('Europe/Podgorica', 'Europe/Podgorica'),
('Europe/Prague', 'Europe/Prague'),
('Europe/Riga', 'Europe/Riga'),
('Europe/Rome', 'Europe/Rome'),
('Europe/Samara', 'Europe/Samara'),
('Europe/San_Marino', 'Europe/San_Marino'),
('Europe/Sarajevo', 'Europe/Sarajevo'),
('Europe/Saratov', 'Europe/Saratov'),
('Europe/Simferopol', 'Europe/Simferopol'),
('Europe/Skopje', 'Europe/Skopje'),
('Europe/Sofia', 'Europe/Sofia'),
('Europe/Stockholm', 'Europe/Stockholm'),
('Europe/Tallinn', 'Europe/Tallinn'),
('Europe/Tirane', 'Europe/Tirane'),
('Europe/Tiraspol', 'Europe/Tiraspol'),
('Europe/Ulyanovsk', 'Europe/Ulyanovsk'),
('Europe/Uzhgorod', 'Europe/Uzhgorod'),
('Europe/Vaduz', 'Europe/Vaduz'),
('Europe/Vatican', 'Europe/Vatican'),
('Europe/Vienna', 'Europe/Vienna'),
('Europe/Vilnius', 'Europe/Vilnius'),
('Europe/Volgograd', 'Europe/Volgograd'),
('Europe/Warsaw', 'Europe/Warsaw'),
('Europe/Zagreb', 'Europe/Zagreb'),
('Europe/Zaporozhye', 'Europe/Zaporozhye'),
('Europe/Zurich', 'Europe/Zurich'),
('GB', 'GB'),
('GB-Eire', 'GB-Eire'),
('GMT', 'GMT'),
('GMT+0', 'GMT+0'),
('GMT-0', 'GMT-0'),
('GMT0', 'GMT0'),
('Greenwich', 'Greenwich'),
('HST', 'HST'),
('Hongkong', 'Hongkong'),
('Iceland', 'Iceland'),
('Indian/Antananarivo', 'Indian/Antananarivo'),
('Indian/Chagos', 'Indian/Chagos'),
('Indian/Christmas', 'Indian/Christmas'),
('Indian/Cocos', 'Indian/Cocos'),
('Indian/Comoro', 'Indian/Comoro'),
('Indian/Kerguelen', 'Indian/Kerguelen'),
('Indian/Mahe', 'Indian/Mahe'),
('Indian/Maldives', 'Indian/Maldives'),
('Indian/Mauritius', 'Indian/Mauritius'),
('Indian/Mayotte', 'Indian/Mayotte'),
('Indian/Reunion', 'Indian/Reunion'),
('Iran', 'Iran'),
('Israel', 'Israel'),
('Jamaica', 'Jamaica'),
('Japan', 'Japan'),
('Kwajalein', 'Kwajalein'),
('Libya', 'Libya'),
('MET', 'MET'),
('MST', 'MST'),
('MST7MDT', 'MST7MDT'),
('Mexico/BajaNorte', 'Mexico/BajaNorte'),
('Mexico/BajaSur', 'Mexico/BajaSur'),
('Mexico/General', 'Mexico/General'),
('NZ', 'NZ'),
('NZ-CHAT', 'NZ-CHAT'),
('Navajo', 'Navajo'),
('PRC', 'PRC'),
('PST8PDT', 'PST8PDT'),
('Pacific/Apia', 'Pacific/Apia'),
('Pacific/Auckland', 'Pacific/Auckland'),
('Pacific/Bougainville', 'Pacific/Bougainville'),
('Pacific/Chatham', 'Pacific/Chatham'),
('Pacific/Chuuk', 'Pacific/Chuuk'),
('Pacific/Easter', 'Pacific/Easter'),
('Pacific/Efate', 'Pacific/Efate'),
('Pacific/Enderbury', 'Pacific/Enderbury'),
('Pacific/Fakaofo', 'Pacific/Fakaofo'),
('Pacific/Fiji', 'Pacific/Fiji'),
('Pacific/Funafuti', 'Pacific/Funafuti'),
('Pacific/Galapagos', 'Pacific/Galapagos'),
('Pacific/Gambier', 'Pacific/Gambier'),
('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
('Pacific/Guam', 'Pacific/Guam'),
('Pacific/Honolulu', 'Pacific/Honolulu'),
('Pacific/Johnston', 'Pacific/Johnston'),
('Pacific/Kiritimati', 'Pacific/Kiritimati'),
('Pacific/Kosrae', 'Pacific/Kosrae'),
('Pacific/Kwajalein', 'Pacific/Kwajalein'),
('Pacific/Majuro', 'Pacific/Majuro'),
('Pacific/Marquesas', 'Pacific/Marquesas'),
('Pacific/Midway', 'Pacific/Midway'),
('Pacific/Nauru', 'Pacific/Nauru'),
('Pacific/Niue', 'Pacific/Niue'),
('Pacific/Norfolk', 'Pacific/Norfolk'),
('Pacific/Noumea', 'Pacific/Noumea'),
('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
('Pacific/Palau', 'Pacific/Palau'),
('Pacific/Pitcairn', 'Pacific/Pitcairn'),
('Pacific/Pohnpei', 'Pacific/Pohnpei'),
('Pacific/Ponape', 'Pacific/Ponape'),
('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
('Pacific/Rarotonga', 'Pacific/Rarotonga'),
('Pacific/Saipan', 'Pacific/Saipan'),
('Pacific/Samoa', 'Pacific/Samoa'),
('Pacific/Tahiti', 'Pacific/Tahiti'),
('Pacific/Tarawa', 'Pacific/Tarawa'),
('Pacific/Tongatapu', 'Pacific/Tongatapu'),
('Pacific/Truk', 'Pacific/Truk'),
('Pacific/Wake', 'Pacific/Wake'),
('Pacific/Wallis', 'Pacific/Wallis'),
('Pacific/Yap', 'Pacific/Yap'),
('Poland', 'Poland'),
('Portugal', 'Portugal'),
('ROC', 'ROC'),
('ROK', 'ROK'),
('Singapore', 'Singapore'),
('Turkey', 'Turkey'),
('UCT', 'UCT'),
('US/Alaska', 'US/Alaska'),
('US/Aleutian', 'US/Aleutian'),
('US/Arizona', 'US/Arizona'),
('US/Central', 'US/Central'),
('US/East-Indiana', 'US/East-Indiana'),
('US/Eastern', 'US/Eastern'),
('US/Hawaii', 'US/Hawaii'),
('US/Indiana-Starke', 'US/Indiana-Starke'),
('US/Michigan', 'US/Michigan'),
('US/Mountain', 'US/Mountain'),
('US/Pacific', 'US/Pacific'),
('US/Pacific-New', 'US/Pacific-New'),
('US/Samoa', 'US/Samoa'),
('UTC', 'UTC'),
('Universal', 'Universal'),
('W-SU', 'W-SU'),
('WET', 'WET'),
('Zulu', 'Zulu')]
FILE_UPLOAD_HANDLERS
('django.core.files.uploadhandler.MemoryFileUploadHandler',
'django.core.files.uploadhandler.TemporaryFileUploadHandler')
DEFAULT_CONTENT_TYPE
'text/html'
DEBUG_STATIC
0
ACCOUNT_APPROVAL_REQUIRED
0
BING_API_KEY
DATABASE_URL
'sqlite:///C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\development.db'
APPEND_SLASH
True
FIRST_DAY_OF_WEEK
0
DATABASE_ROUTERS
DEFAULT_TABLESPACE
STAMEN_BASEMAPS
False
GEOSERVER_LOCATION
YEAR_MONTH_FORMAT
'F Y'
STATICFILES_STORAGE
'django.contrib.staticfiles.storage.StaticFilesStorage'
CACHES
{'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION
1
CKAN_ORIGINS
[{'css_class': 'hdx',
  'label': 'Humanitarian Data Exchange (HDX)',
  'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}&notes={abstract}&caveats={caveats}'}]
SLACK_WEBHOOK_URLS
['https://hooks.slack.com/services/T000/B000/XX']
ACCOUNT_EMAIL_CONFIRMATION_EMAIL
0
SESSION_COOKIE_PATH
ALT_OSM_BASEMAPS
False
USE_X_FORWARDED_HOST
False
ACCOUNT_OPEN_SIGNUP
True
ROOT_URLCONF
'geonode.urls'
CATALOGUE
{'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
             'URL': 'http://localhost:8000/catalogue/csw'}}
MAPBOX_ACCESS_TOKEN
MISSING_THUMBNAIL
'geonode/img/missing_thumb.png'
FILE_UPLOAD_TEMP_DIR
None
MIDDLEWARE_CLASSES
('django.middleware.common.CommonMiddleware',
'django.contrib.sessions.middleware.SessionMiddleware',
'django.contrib.messages.middleware.MessageMiddleware',
'django.middleware.locale.LocaleMiddleware',
'pagination.middleware.PaginationMiddleware',
'django.middleware.csrf.CsrfViewMiddleware',
'django.contrib.auth.middleware.AuthenticationMiddleware',
'django.middleware.clickjacking.XFrameOptionsMiddleware',
'django.contrib.auth.middleware.SessionAuthenticationMiddleware',
'oauth2_provider.middleware.OAuth2TokenMiddleware')
USE_I18N
1
THOUSAND_SEPARATOR
SECRET_KEY
MODELTRANSLATION_FALLBACK_LANGUAGES
('en',)
LANGUAGE_COOKIE_NAME
'django_language'
OGC_SERVER
{'default': {'BACKEND': 'geonode.geoserver',
             'BACKEND_WRITE_ENABLED': True,
             'DATASTORE': '',
             'GEOGIG_DATASTORE_DIR': '',
             'GEONODE_SECURITY_ENABLED': True,
             'LOCATION': 'http://10.240.14.253:8080/geoserver/',
             'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
             'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
             'LOG_FILE': 'C:\\GeoNode-2.6.x\\geonode-2.6.x/geoserver/data/logs/geoserver.log',
             'MAPFISH_PRINT_ENABLED': True,
             'PRINT_NG_ENABLED': True,
             'PUBLIC_LOCATION': 'http://10.240.14.253/geoserver/',
             'TIMEOUT': 300,
             'USER': 'admin',
             'WMST_ENABLED': False,
             'WPS_ENABLED': False}}
ACCOUNT_REMEMBER_ME_EXPIRY
315360000
ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
DEFAULT_MAP_CRS
'EPSG:900913'
EMAIL_USE_SSL
False
ACCOUNT_EMAIL_UNIQUE
True
THESAURI
LOGGING_CONFIG
'logging.config.dictConfig'
_DEFAULT_LANGUAGES
(('en', 'English'),
('es', 'Espa\xc3\xb1ol'),
('it', 'Italiano'),
('fr', 'Fran\xc3\xa7ais'),
('de', 'Deutsch'),
('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
('id', 'Bahasa Indonesia'),
('zh-cn', '\xe4\xb8\xad\xe6\x96\x87'),
('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe8\xaa\x9e'),
('fa', 'Persian'),
('ar', 'Arabic'),
('bn', 'Bengali'),
('ne', 'Nepali'),
('sq', 'Albanian'),
('af', 'Afrikaans'),
('sw', 'Swahili'),
('pt', 'Portuguese'),
('pt-br', 'Portuguese (Brazil)'),
('ru', 'Russian'),
('vi', 'Vietnamese'),
('ko', '\xed\x95\x9c\xea\xb5\xad\xec\x96\xb4'),
('am', 'Amharic'),
('km', 'Khmer'),
('pl', 'Polish'),
('sv', 'Swedish'),
('th', '\xe0\xb9\x84\xe0\xb8\x97\xe0\xb8\xa2'),
('uk', 'Ukranian'),
('si', 'Sinhala'),
('ta', 'Tamil'),
('tl', 'Tagalog'))
TEMPLATE_LOADERS
('django.template.loaders.filesystem.Loader',
'django.template.loaders.app_directories.Loader')
GEOS_LIBRARY_PATH
'C:\\GeoNode-2.6.x\\GDAL\\geos_c.dll'
TASTYPIE_DEFAULT_FORMATS
['json']
TEMPLATE_DEBUG
False
AUTO_GENERATE_AVATAR_SIZES
(20, 30, 32, 40, 50, 65, 70, 80, 100, 140, 200, 240)
CSRF_COOKIE_NAME
'csrftoken'
THEME_ACCOUNT_CONTACT_EMAIL
'admin at example.com'
'default'
OAUTH2_PROVIDER
{'CLIENT_ID_GENERATOR_CLASS': 'oauth2_provider.generators.ClientIdGenerator',
'SCOPES': {'groups': 'Access to your groups',
            'read': 'Read scope',
            'write': 'Write scope'}}
CELERY_DEFAULT_ROUTING_KEY
ACCOUNT_LOGIN_REDIRECT_URL
u'/'
TWITTER_HASHTAGS
['geonode']
CELERY_ALWAYS_EAGER
True
EMAIL_TIMEOUT
None
MODIFY_TOPICCATEGORY
0
SIGNING_BACKEND
'django.core.signing.TimestampSigner'
SESSION_COOKIE_SECURE
False
NLP_ENABLED
False
ACCOUNT_LOGIN_URL
u'account_login'
MESSAGE_STORAGE
'django.contrib.messages.storage.fallback.FallbackStorage'
CACHE_TIME
0
SECURE_BROWSER_XSS_FILTER
False
PYCSW
{'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
                                        'contact_email': 'Email Address',
                                        'contact_name': 'Organization Name',
                                        'date': 'YYYY-MM-DD',
                                        'default_language': 'eng',
                                        'enabled': 'true',
                                        'gemet_keywords': 'Utility and governmental services',
                                        'languages_supported': 'eng,gre',
                                        'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
                   'metadata:main': {'contact_address': 'Mailing Address',
                                     'contact_city': 'City',
                                     'contact_country': 'Country',
                                     'contact_fax': '+xx-xxx-xxx-xxxx',
                                     'contact_hours': 'Hours of Service',
                                     'contact_instructions': 'During hours of service. Off on weekends.',
                                     'contact_name': 'Lastname, Firstname',
                                     'contact_phone': '+xx-xxx-xxx-xxxx',
                                     'contact_position': 'Position Title',
                                     'contact_postalcode': 'Zip or Postal Code',
                                     'contact_role': 'pointOfContact',
                                     'contact_stateorprovince': 'Administrative Area',
                                     'contact_url': 'Contact URL',
                                     'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing, and collaborative use of geospatial data',
                                     'identification_accessconstraints': 'None',
                                     'identification_fees': 'None',
                                     'identification_keywords': 'sdi, catalogue, discovery, metadata, GeoNode',
                                     'identification_keywords_type': 'theme',
                                     'identification_title': 'GeoNode Catalogue',
                                     'provider_name': 'Organization Name',
                                     'provider_url': 'http://localhost:8000/'}}}
CSRF_COOKIE_DOMAIN
None
FILE_CHARSET
'utf-8'
DEBUG
1
SECURE_SSL_REDIRECT
False
LANGUAGE_COOKIE_DOMAIN
None
AWS_ACCESS_KEY_ID
DEFAULT_FILE_STORAGE
'django.core.files.storage.FileSystemStorage'
INSTALLED_APPS
('modeltranslation',
'django.contrib.auth',
'django.contrib.contenttypes',
'django.contrib.sessions',
'django.contrib.sites',
'django.contrib.admin',
'django.contrib.sitemaps',
'django.contrib.staticfiles',
'django.contrib.messages',
'django.contrib.humanize',
'django.contrib.gis',
'pagination',
'taggit',
'treebeard',
'friendlytagloader',
'geoexplorer',
'leaflet',
'django_extensions',
'autocomplete_light',
'mptt',
'djcelery',
'storages',
'pinax_theme_bootstrap_account',
'pinax_theme_bootstrap',
'django_forms_bootstrap',
'account',
'avatar',
'dialogos',
'agon_ratings',
'announcements',
'actstream',
'user_messages',
'tastypie',
'polymorphic',
'guardian',
'oauth2_provider',
'geonode.people',
'geonode.base',
'geonode.layers',
'geonode.maps',
'geonode.proxy',
'geonode.security',
'geonode.social',
'geonode.catalogue',
'geonode.documents',
'geonode.api',
'geonode.groups',
'geonode.services',
'geonode.upload',
'geonode.tasks')
LANGUAGES_BIDI
('he', 'ar', 'fa', 'ur')
USE_L10N
1
SITEURL
'http://10.240.14.253/'
STATIC_ROOT
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\static_root'
SECURE_HSTS_INCLUDE_SUBDOMAINS
False
GEONODE_APPS
('geonode.people',
'geonode.base',
'geonode.layers',
'geonode.maps',
'geonode.proxy',
'geonode.security',
'geonode.social',
'geonode.api',
'geonode.groups',
'geonode.services',
'geonode.upload',
'geonode.tasks')
LEAFLET_CONFIG
{'PLUGINS': {u'ALL': {u'css': <leaflet.utils.ListWithLazyItems object at 0x0A62E3D0>,
                      u'js': <leaflet.utils.ListWithLazyItems object at 0x1051B6B0>},
             u'__default__': {u'css': <leaflet.utils.ListWithLazyItems object at 0x1051B710>,
                              u'js': <leaflet.utils.ListWithLazyItems object at 0x1051B790>},
             u'__is_normalized__': True,
             'esri-leaflet': {'auto-include': True,
                              u'css': <leaflet.utils.ListWithLazyItems object at 0x1051B7B0>,
                              'js': <leaflet.utils.ListWithLazyItems object at 0x1051B7D0>},
             u'forms': {u'auto-include': False,
                        u'css': <leaflet.utils.ListWithLazyItems object at 0x1051B550>,
                        u'js': <leaflet.utils.ListWithLazyItems object at 0x0A62E4B0>},
             'leaflet-fullscreen': {'auto-include': True,
                                    'css': <leaflet.utils.ListWithLazyItems object at 0x1051B6D0>,
                                    'js': <leaflet.utils.ListWithLazyItems object at 0x1051B730>}},
'RESET_VIEW': False,
'SRID': 3857,
'TILES': [('Watercolor',
            'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png',
            'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a>          — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">          CC-BY-SA</a>'),
           ('Toner Lite',
            'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png',
            'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a>          — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">          CC-BY-SA</a>')]}
DOWNLOAD_FORMATS_VECTOR
['JPEG',
'PDF',
'PNG',
'Zipped Shapefile',
'GML 2.0',
'GML 3.1.1',
'CSV',
'Excel',
'GeoJSON',
'KML',
'Tiles']
PREPEND_WWW
False
SECURE_PROXY_SSL_HEADER
None
AUTH_IP_WHITELIST
TWITTER_CARD
True
ACCOUNT_PASSWORD_RESET_REDIRECT_URL
LANGUAGE_COOKIE_AGE
None
SESSION_COOKIE_HTTPONLY
True
AWS_SECRET_ACCESS_KEY
DEBUG_PROPAGATE_EXCEPTIONS
False
INTERNAL_IPS
DEFAULT_ANONYMOUS_VIEW_PERMISSION
1
_DEFAULT_SECRET_KEY
MONTH_DAY_FORMAT
'F j'
ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
u'account_login'
LOGIN_URL
'/account/login/'
SESSION_EXPIRE_AT_BROWSER_CLOSE
False
SEARCH_FILTERS
{'CATEGORIES_ENABLED': True,
'DATE_ENABLED': True,
'EXTENT_ENABLED': True,
'H_KEYWORDS_ENABLED': u'********************',
'KEYWORDS_ENABLED': u'********************',
'OWNERS_ENABLED': True,
'REGION_ENABLED': True,
'TEXT_ENABLED': True,
'TYPE_ENABLED': True,
'T_KEYWORDS_ENABLED': u'********************'}
OPENGRAPH_ENABLED
True
OGP_URL
'http://geodata.tufts.edu/solr/select'
CELERY_EAGER_PROPAGATES_EXCEPTIONS
True
TIME_FORMAT
'P'
CELERY_IGNORE_RESULT
True
SERVICE_UPDATE_INTERVAL
0
AUTH_USER_MODEL
'people.Profile'
DATE_INPUT_FORMATS
('%Y-%m-%d',
'%m/%d/%Y',
'%m/%d/%y',
'%b %d %Y',
'%b %d, %Y',
'%d %b %Y',
'%d %b, %Y',
'%B %d %Y',
'%B %d, %Y',
'%d %B %Y',
'%d %B, %Y')
ACCOUNT_LOGOUT_REDIRECT_URL
u'/'
SESSION_SERIALIZER
'django.contrib.sessions.serializers.PickleSerializer'
HAYSTACK_SEARCH
False
AUTHENTICATION_BACKENDS
('oauth2_provider.backends.OAuth2Backend',
'django.contrib.auth.backends.ModelBackend',
'guardian.backends.ObjectPermissionBackend')
EMAIL_HOST_PASSWORD
CELERY_DISABLE_RATE_LIMITS
True
PASSWORD_RESET_TIMEOUT_DAYS
SESSION_FILE_PATH
None
CACHE_MIDDLEWARE_ALIAS
'default'
SESSION_SAVE_EVERY_REQUEST
False
NUMBER_GROUPING
0
SHORT_DATETIME_FORMAT
'm/d/Y P'
SESSION_ENGINE
'django.contrib.sessions.backends.db'
CELERY_RESULT_BACKEND
None
ACCOUNT_DELETION_MARK_CALLBACK
<function account_delete_mark at 0x0983CC70>
CSRF_COOKIE_PATH
LOGIN_REDIRECT_URL
'/accounts/profile/'
TEMPLATE_STRING_IF_INVALID
NLP_LIBRARY_PATH
'/opt/MITIE/mitielib'
ACCOUNT_DELETION_EXPUNGE_HOURS
48
PROJECT_ROOT
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode'
DECIMAL_SEPARATOR
API_INCLUDE_REGIONS_COUNT
CELERY_SEND_EVENTS
False
EXIF_ENABLED
False
NOSE_ARGS
['--nocapture', '--detailed-errors']
LOCALE_PATHS
NLP_MODEL_PATH
'/opt/MITIE/MITIE-models/english/ner_model.dat'
PASSWORD_HASHERS
PROXY_ALLOWED_HOSTS
LOCAL_MEDIA_URL
'/uploaded/'
CARTODB_BASEMAPS
False
SOCIAL_ORIGINS
[{'css_class': 'email',
  'label': 'Email',
  'url': 'mailto:?subject={name}&body={url}'},
{'css_class': 'fb',
  'label': 'Facebook',
  'url': 'http://www.facebook.com/sharer.php?u={url}'},
{'css_class': 'tw',
  'label': 'Twitter',
  'url': 'https://twitter.com/share?url={url}&hashtags={hashtags}'},
{'css_class': 'gp',
  'label': 'Google +',
  'url': 'https://plus.google.com/share?url={url}'}]
LOGOUT_URL
'/account/logout/'
MAP_BASELAYERS
[{'source': {'ptype': 'gxp_wmscsource',
             'restUrl': '/gs/rest',
             'title': 'Local Geoserver',
             'url': 'http://10.240.14.253/geoserver/wms'}},
{'args': ['No background'],
  'fixed': True,
  'group': 'background',
  'name': 'background',
  'source': {'ptype': 'gxp_olsource'},
  'type': 'OpenLayers.Layer',
  'visibility': False},
{'fixed': True,
  'name': 'mapnik',
  'source': {'ptype': 'gxp_osmsource'},
  'type': 'OpenLayers.Layer.OSM',
  'visibility': True},
{'fixed': True,
  'name': 'AerialWithLabels',
  'source': {'apiKey': 'fYroKGkrUuqZwDhpHmjl~0KqenPX8fqWFJeW9dsZDeQ~AlCniTPYlbb0PcCiLYIztyboiTbKCU4HpoM3UmuCLwlQt1Zfe3a9rRrMa7yU-Lno',
             'ptype': 'gxp_bingsource'},
  'visibility': False}]
EMAIL_USE_TLS
False
ACCOUNT_LANGUAGES
[('en', u'English'),
('es', u'espa\xf1ol'),
('it', u'italiano'),
('fr', u'fran\xe7ais'),
('de', u'Deutsch'),
('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
('id', u'Bahasa Indonesia'),
('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'),
('ja', u'\u65e5\u672c\u8a9e'),
('fa', u'\u0641\u0627\u0631\u0633\u06cc'),
('ar', u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'),
('bn', u'\u09ac\u09be\u0982\u09b2\u09be'),
('ne', u'\u0928\u0947\u092a\u093e\u0932\u0940'),
('sq', u'shqip'),
('af', u'Afrikaans'),
('sw', u'Kiswahili'),
('pt', u'Portugu\xeas'),
('pt-br', u'Portugu\xeas Brasileiro'),
('ru', u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'),
('vi', u'Ti\xea\u0301ng Vi\xea\u0323t'),
('ko', u'\ud55c\uad6d\uc5b4'),
('am', 'Amharic'),
('km', u'Khmer'),
('pl', u'polski'),
('sv', u'svenska'),
('th', u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'),
('uk', u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'),
('si', 'sinhala'),
('ta', u'tamil'),
('tl', 'tagalog')]
FIXTURE_DIRS
ABSOLUTE_URL_OVERRIDES
DATE_FORMAT
'N j, Y'
NLP_LOCATION_THRESHOLD
1.0
CSRF_FAILURE_VIEW
'django.views.csrf.csrf_failure'
SKIP_PERMS_FILTER
False
ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
MEDIA_ROOT
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\uploaded'
AGON_RATINGS_CATEGORY_CHOICES
{'documents.Document': {'document': 'How good is this document?'},
'layers.Layer': {'layer': 'How good is this layer?'},
'maps.Map': {'map': 'How good is this map?'}}
SECURE_CONTENT_TYPE_NOSNIFF
False
DEFAULT_EXCEPTION_REPORTER_FILTER
'django.views.debug.SafeExceptionReporterFilter'
ADMINS
FORMAT_MODULE_PATH
None
DEFAULT_FROM_EMAIL
'webmaster at localhost'
STATICFILES_DIRS
['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\static']
MEDIA_URL
'/uploaded/'
DATETIME_FORMAT
'N j, Y, P'
TEMPLATE_DIRS
ALLOWED_DOCUMENT_TYPES
['doc',
'docx',
'gif',
'jpg',
'jpeg',
'ods',
'odt',
'odp',
'pdf',
'png',
'ppt',
'pptx',
'rar',
'sld',
'tif',
'tiff',
'txt',
'xls',
'xlsx',
'xml',
'zip',
'gz',
'qml']
NOTIFICATION_LANGUAGE_MODULE
'account.Account'
ACCOUNT_DELETION_EXPUNGE_CALLBACK
<function account_delete_expunge at 0x0983CC30>
RESOURCE_PUBLISHING
False
ACCOUNT_HOOKSET
<account.hooks.AccountDefaultHookSet object at 0x0983B710>
PROXY_URL
'/proxy/?url='
SITE_ID
1
DISALLOWED_USER_AGENTS
ALLOWED_INCLUDE_ROOTS
API_LIMIT_PER_PAGE
THUNDERFOREST_BASEMAPS
False
ACCOUNT_SETTINGS_REDIRECT_URL
u'account_settings'
USE_THOUSAND_SEPARATOR
False
EXTRA_LANG_INFO
{'am': {'bidi': False,
        'code': 'am',
        'name': 'Amharic',
        'name_local': 'Amharic'},
'si': {'bidi': False,
        'code': 'si',
        'name': 'Sinhala',
        'name_local': 'sinhala'},
'ta': {'bidi': False, 'code': 'ta', 'name': 'Tamil', 'name_local': u'tamil'},
'tl': {'bidi': False,
        'code': 'tl',
        'name': 'Tagalog',
        'name_local': 'tagalog'}}
SRID
{'DETAIL': 'never'}
LOGGING
{'disable_existing_loggers': True,
'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
'formatters': {'simple': {'format': '%(message)s'},
                'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
'handlers': {'console': {'class': 'logging.StreamHandler',
                          'formatter': 'simple',
                          'level': 'ERROR'},
              'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
                              'filters': ['require_debug_false'],
                              'level': 'ERROR'},
              'null': {'class': 'django.utils.log.NullHandler',
                       'level': 'ERROR'}},
'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
             'geonode': {'handlers': ['console'], 'level': 'ERROR'},
             'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
             'owslib': {'handlers': ['console'], 'level': 'ERROR'},
             'pycsw': {'handlers': ['console'], 'level': 'ERROR'}},
'version': 1}
_DEFAULT_STATICFILES_DIRS
BASEMAP
{'fixed': True,
TWITTER_SITE
'@GeoNode'
SLACK_ENABLED
False
TEMPLATES
[{'APP_DIRS': True,
  'BACKEND': 'django.template.backends.django.DjangoTemplates',
  'DIRS': ['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\templates'],
  'NAME': 'GeoNode Project Templates',
  'OPTIONS': {'context_processors': ['django.contrib.auth.context_processors.auth',
                                     'django.core.context_processors.debug',
                                     'django.core.context_processors.i18n',
                                     'django.core.context_processors.tz',
                                     'django.core.context_processors.media',
                                     'django.core.context_processors.static',
                                     'django.core.context_processors.request',
                                     'django.contrib.messages.context_processors.messages',
                                     'account.context_processors.account',
                                     'geonode.context_processors.resource_urls',
                                     'geonode.geoserver.context_processors.geoserver_urls'],
              'debug': 1}}]
TEST_RUNNER
'django_nose.NoseTestSuiteRunner'
ACTSTREAM_SETTINGS
{'FETCH_RELATIONS': True,
'GFK_FETCH_DEPTH': 1,
'USE_JSONFIELD': True,
'USE_PREFETCH': False}
MODELTRANSLATION_LANGUAGES
['en']
HAYSTACK_FACET_COUNTS
False
SHORT_DATE_FORMAT
'm/d/Y'
CACHE_MIDDLEWARE_KEY_PREFIX
AWS_S3_BUCKET_DOMAIN
'.s3.amazonaws.com'
TIME_ZONE
'America/Chicago'
FILE_UPLOAD_MAX_MEMORY_SIZE
2621440
LOCAL_GEOSERVER
SESSION_CACHE_ALIAS
'default'
EMAIL_BACKEND
'django.core.mail.backends.smtp.EmailBackend'
ANONYMOUS_USER_ID
'-1'
DEFAULT_MAP_ZOOM
0
TEMPLATE_CONTEXT_PROCESSORS
('django.contrib.auth.context_processors.auth',
'django.template.context_processors.debug',
'django.template.context_processors.i18n',
'django.template.context_processors.media',
'django.template.context_processors.static',
'django.template.context_processors.tz',
'django.contrib.messages.context_processors.messages')
LOCKDOWN_GEONODE
0
S3_STATIC_ENABLED
False
SESSION_COOKIE_AGE
1209600
SETTINGS_MODULE
'geonode.settings'
GUARDIAN_GET_INIT_ANONYMOUS_USER
'geonode.people.models.get_anonymous_user_instance'
USE_ETAGS
False
SOCIAL_BUTTONS
True
LANGUAGES
(('en', 'English'),
('it', 'Italiano'),
('de', 'Deutsch'),
('fa', 'Persian'),
('ar', 'Arabic'),
('bn', 'Bengali'),
('ne', 'Nepali'),
('sq', 'Albanian'),
('sw', 'Swahili'),
('ru', 'Russian'),
('am', 'Amharic'),
('km', 'Khmer'),
('pl', 'Polish'),
('sv', 'Swedish'),
('uk', 'Ukranian'),
('si', 'Sinhala'),
('ta', 'Tamil'),
('tl', 'Tagalog'))
CELERY_TASK_RESULT_EXPIRES
1
DEFAULT_INDEX_TABLESPACE
CSRF_COOKIE_AGE
31449600
STATIC_URL
'/static/'
EMAIL_PORT
25
LAYER_PREVIEW_LIBRARY
'geoext'
USE_TZ
False
DEFAULT_SEARCH_SIZE
10
CLIENT_RESULTS_LIMIT
100
TEST_NON_SERIALIZED_APPS
USE_QUEUE
0
MODELTRANSLATION_DEFAULT_LANGUAGE
'en'
ACCOUNT_SIGNUP_REDIRECT_URL
u'/'
LANGUAGE_COOKIE_PATH
MIGRATION_MODULES
CACHE_MIDDLEWARE_SECONDS
600
EMAIL_SSL_CERTFILE
None
ACCOUNT_CREATE_ON_SAVE
True
VERSION
'2.6'
CSRF_COOKIE_HTTPONLY
False
DATETIME_INPUT_FORMATS
('%Y-%m-%d %H:%M:%S',
'%Y-%m-%d %H:%M:%S.%f',
'%Y-%m-%d %H:%M',
'%Y-%m-%d',
'%m/%d/%Y %H:%M:%S',
'%m/%d/%Y %H:%M:%S.%f',
'%m/%d/%Y %H:%M',
'%m/%d/%Y',
'%m/%d/%y %H:%M:%S',
'%m/%d/%y %H:%M:%S.%f',
'%m/%d/%y %H:%M',
'%m/%d/%y')
ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
0
FORCE_SCRIPT_NAME
None
SECURE_SSL_HOST
None
EMAIL_HOST_USER
MAX_DOCUMENT_SIZE
2
You're seeing this error because you have DEBUG = True in your Django settings file. Change that to False, and Django will display a standard page generated by the handler for this status code.
Abel Quesi
[its] Information Technology & Services
Mariano Moreno 746 Cuerpo 2 1° “A”– Lujan (CP: 6700)  Buenos Aires – Argentina
+54-2323-435160 / 61 – Fax: +54-2323-435161
aquesi at itssaconsulting.com - www.itssaconsulting.com
Descripción: Descripción: C:\Users\aquesi\Documents\ISO_veritas_1.jpg
  _____
Este mensaje y sus adjuntos son confidenciales y de uso exclusivo para el usuario de la dirección de correo electrónico a quien esta dirigido. Puede contener información amparada por el secreto profesional. Si hubiese recibido este mensaje por error, por favor informe tal situación al emisor, devolviéndole el correo electrónico y eliminándolo de su sistema, no pudiendo en tal caso copiar, enviar, revelar el contenido o utilizar alguna parte de este mensaje o de sus adjuntos. No se garantiza la seguridad o la exactitud de las comunicaciones por Internet debido a que la información puede ser interceptada, modificada, perdida, llegar tarde o contener virus. El emisor, por lo tanto, no acepta responsabilidad por errores u omisiones en el texto de este mensaje que surjan a partir de una transmisión por Internet.
  _____
De: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] En nombre de Abel Quesi
Enviado el: martes, 31 de octubre de 2017 03:27 p.m.
Para: geonode-users at lists.osgeo.org
Asunto: [GeoNode-users] User (no SuperUser) dont can view layers in Goserver
Hi! How are you?
The super users can view all layers, but the simple users or staff don’t can view the layers.
What will be the problem?
Thank you
Regards
Abel Quesi
  _____
  _____
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171101/143ffefc/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171101/143ffefc/attachment-0001.jpg>
More information about the geonode-users mailing list
