[GeoNode-users] Is there any way to make geoserver in GeoNode 2.6.x work well with JARs?
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Nov 13 00:43:54 PST 2017
no need to rename JARs. You have to remove the *-SNAPSHOT ones and replace
with your owns.
However, I'm afraid that it is not working for other reasons. In that case
you will need some Java skills in order to understand what exactly your
customization is doing differently from a standard GeoServer.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Mon, Nov 13, 2017 at 9:35 AM, 许秋熹 <xqx930807 at gmail.com> wrote:
> hi,I want to make GeoNode 2.6.x to work with to work with my own geoserver
> 2.9.1 because our team have built some JARs relied on geoserver
> 2.9.1(geotools15.1).
> And we have installed GeoNode 2.6.x from Ubuntu 16.04 ppa. The geoserver
> version is 2.9-SNAPSHOT(from /usr/share/geoserver/WEB-INF/lib).
> Our JARs worked well with geoserver 2.9.1. but could not worked with the
> geoserver that GeoNode used.
> Can I rename the JARs in /usr/share/geoserver/WEB-INF/lib like
> 2.9-SNAPSHOT to 2.9.1
> 15-SNAPSHOT to 15.1
> that make it work ?
> Or is there any way to make GeoNode 2.6.x to work with my own geoserver
> 2.9.1?
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171113/44728e28/attachment.html>
More information about the geonode-users
