[GeoNode-users] How do I enable the "Create Layer" application?
Paolo Corti pcorti at gmail.com
Wed Oct 25 07:40:40 PDT 2017
Hi
createlayer is available only in latest source code, not in 2.6.x
Sorry about it
regards
p
On Wed, Oct 25, 2017 at 10:31 AM, Joe Hotchkiss
<joe.hotchkiss at envsys.co.uk> wrote:
> http://docs.geonode.org/en/master/tutorials/users/managing_layers/create.html
> states:
> In GeoNode it is possible to create empty layers, that can be populated with
> features at a later stage using the mapping client editing tools.
> This is possible using the createlayer application, which can be enabled if
> GeoNode is installed with PostGIS.
> Once the application is enabled in GeoNode you will be able to create an
> empty layer by browsing to “Data > Create Layer”.
> I have GeoNode 2.6.3 installed and running.  The geonode and geonode_data
> databases exist, and geonode_data has the postgis extension.
> What do I need to do to 'enable the application in GeoNode'?
> Joe Hotchkiss
> Software Developer
> Environment Systems
> Tel: +44 (0) 1970 626688
> www.envsys.co.uk
> The information contained in this e-mail is intended only for the use of the
> person(s) to whom it is addressed and may contain confidential or privileged
> information. If you have received this e-mail in error please contact the
> sender and delete the material without copying, distributing or disclosing
> the content. All reasonable precautions have been taken to ensure that this
> e-mail is free from any virus, however, the recipient should verify this to
> be the case. Please 'think before you print'
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
