[GeoNode-users] geoserver error
Paolo Corti pcorti at gmail.com
Thu Sep 28 11:20:11 PDT 2017
Could you attach a larger portion of the log? From here it is not clear
that this error is the cause of GeoServer not being able to start.
Generally when I see bean errors most of the time is because the Java
process of the container of GeoServer (Tomcat or Jetty) is lacking RAM.
Having a lot of RAM in the server doesn't mean that it will be correctly
used by GeoServer, as it must be optimized (by default the GeoServer which
comes with GeoNode is using parameters which are not ideal for production):
http://docs.geoserver.org/latest/en/user/production/container.html
regards
p
On Thu, Sep 28, 2017 at 12:17 PM, Vicente <deluca.vicente at gmail.com> wrote:
> Please, look at these error lines. Do not they tell you anything?
> Caused by: java.lang.RuntimeException: Could not decode: EPSG: 4326
> at org.geoserver.importer.format.KMLFileFormat. <clinit>
> (KMLFileFormat.java:65)
> ... plus
> Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No
> "EPSG: 4326" code from the "European Petroleum Survey Group" authority
> found for the "IdentifiedObject" object.
> On Thu, Sep 28, 2017 at 1:15 PM, Vicente <deluca.vicente at gmail.com> wrote:
>> yes, I have 8GB, memory is not the problem
>> Then it must be the kml that I loaded
>> I'm ready to make a flush, could this solve it?
>> On Thu, Sep 28, 2017 at 1:03 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>> They are warnings and I don't think they are causing GeoServer to fail.
>>> For sure deleting the default admin GeoNode users won't cause this kind
>>> of problem.
>>> Are you running GeoServer with enough memory?
>>> p
>>> On Thu, Sep 28, 2017 at 11:52 AM, Vicente <deluca.vicente at gmail.com>
>>> wrote:
>>>> Sorry, maybe this is off-topic, my question is, Does removes some
>>>> projection stuff when I delete the admin (default) user?
>>>> The geoserver log error says
>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'raster'
>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'point'
>>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'line'
>>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'polygon'
>>>> 2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default workspace
>>>> geonode
>>>> 2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace
>>>> 'geonode'
>>>> 2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable
>>>> authority factory: European Petroleum Survey Group
>>>> 2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable
>>>> 2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable
>>>> 2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable
>>>> 2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable
>>>> 2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable
>>>> 2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] -
>>>> Invocation of destroy method failed on bean with name 'importer':
>>>> java.lang.NullPointerException
>>>> 2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] -
>>>> Invocation of destroy method failed on bean with name 'geoServerLoader':
>>>> 2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
>>>> initialization failed
>>>> org.springframework.beans.factory.BeanCreationException: Error
>>>> creating bean with name 'kmlFormat' defined in URL
>>>> [jar:file:/var/www/geo/httpdocs/geonode/geoserver/geoserver/
>>>> WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]:
>>>> Instantiation of bean failed; nested
>>>> Another thing I did was add a kml file, but it looked fine!
>>>> Some of the two things broke something in the geoserver.
>>>> Thank you!
>>>> On Wed, Sep 27, 2017 at 8:54 PM, Vicente <deluca.vicente at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> the #paver start command throws the following error,
>>>>> Error creating bean with name 'kmlFormat' defined in URL
>>>>> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/lib/gs-
>>>>> exception is java.lang.ExceptionInInitializerErro
>>>>> I think it might have happened after removing some admin users from
>>>>> geonode. It's possible?
>>>>> I added them again but the problem persists, I do not want to lose the
>>>>> information already loaded in the geoserver.
>>>>> Thank you!
>>>>> [image: MANTA] <http://www.estudiomanta.com/>
>>>>> Vicente Deluca
>>>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
>>>> Vicente Deluca
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
>> Vicente Deluca
> Vicente Deluca
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170928/61ea8df2/attachment-0001.html>
More information about the geonode-users mailing list
