[GeoNode-users] geoserver error
Vicente
deluca.vicente at gmail.com
Thu Sep 28 11:51:02 PDT 2017
I attach two log files, one is the output of the paver start command, the
other is the log of the geoserver/data/logs/geoserver.log folder
I increased the memory in the command line that runs the jetty and the
problem persists.
The command line running the jetty worked perfectly until yesterday
thks!
On Thu, Sep 28, 2017 at 3:20 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Could you attach a larger portion of the log? From here it is not clear
> that this error is the cause of GeoServer not being able to start.
> Generally when I see bean errors most of the time is because the Java
> process of the container of GeoServer (Tomcat or Jetty) is lacking RAM.
> Having a lot of RAM in the server doesn't mean that it will be correctly
> used by GeoServer, as it must be optimized (by default the GeoServer which
> comes with GeoNode is using parameters which are not ideal for production):
> http://docs.geoserver.org/latest/en/user/production/container.html
> regards
> p
> On Thu, Sep 28, 2017 at 12:17 PM, Vicente <deluca.vicente at gmail.com>
> wrote:
>> Please, look at these error lines. Do not they tell you anything?
>> Caused by: java.lang.RuntimeException: Could not decode: EPSG: 4326
>> at org.geoserver.importer.format.KMLFileFormat. <clinit>
>> (KMLFileFormat.java:65)
>> ... plus
>> Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No
>> "EPSG: 4326" code from the "European Petroleum Survey Group" authority
>> found for the "IdentifiedObject" object.
>> On Thu, Sep 28, 2017 at 1:15 PM, Vicente <deluca.vicente at gmail.com>
>> wrote:
>>> yes, I have 8GB, memory is not the problem
>>> Then it must be the kml that I loaded
>>> I'm ready to make a flush, could this solve it?
>>> On Thu, Sep 28, 2017 at 1:03 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>> They are warnings and I don't think they are causing GeoServer to fail.
>>>> For sure deleting the default admin GeoNode users won't cause this kind
>>>> of problem.
>>>> Are you running GeoServer with enough memory?
>>>> p
>>>> On Thu, Sep 28, 2017 at 11:52 AM, Vicente <deluca.vicente at gmail.com>
>>>> wrote:
>>>>> Sorry, maybe this is off-topic, my question is, Does removes some
>>>>> projection stuff when I delete the admin (default) user?
>>>>> The geoserver log error says
>>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'raster'
>>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'point'
>>>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'line'
>>>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'polygon'
>>>>> 2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default
>>>>> workspace geonode
>>>>> 2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace
>>>>> 'geonode'
>>>>> 2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable
>>>>> authority factory: European Petroleum Survey Group
>>>>> 2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable
>>>>> 2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable
>>>>> 2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable
>>>>> 2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable
>>>>> 2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable
>>>>> 2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] -
>>>>> Invocation of destroy method failed on bean with name 'importer':
>>>>> java.lang.NullPointerException
>>>>> 2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] -
>>>>> Invocation of destroy method failed on bean with name 'geoServerLoader':
>>>>> 2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
>>>>> initialization failed
>>>>> org.springframework.beans.factory.BeanCreationException: Error
>>>>> creating bean with name 'kmlFormat' defined in URL
>>>>> [jar:file:/var/www/geo/httpdocs/geonode/geoserver/geoserver/
>>>>> WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]:
>>>>> Instantiation of bean failed; nested
>>>>> Another thing I did was add a kml file, but it looked fine!
>>>>> Some of the two things broke something in the geoserver.
>>>>> Thank you!
>>>>> On Wed, Sep 27, 2017 at 8:54 PM, Vicente <deluca.vicente at gmail.com>
>>>>> wrote:
>>>>>> Hi,
>>>>>> the #paver start command throws the following error,
>>>>>> Error creating bean with name 'kmlFormat' defined in URL
>>>>>> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/lib/gs-
>>>>>> exception is java.lang.ExceptionInInitializerErro
>>>>>> I think it might have happened after removing some admin users from
>>>>>> geonode. It's possible?
>>>>>> I added them again but the problem persists, I do not want to lose
>>>>>> the information already loaded in the geoserver.
>>>>>> Thank you!
>>>>>> [image: MANTA] <http://www.estudiomanta.com/>
>>>>>> Vicente Deluca
>>>>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
>>>>> Vicente Deluca
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Paolo Corti
>>>> Geospatial software developer
>>>> web: http://www.paolocorti.net
>>>> twitter: @capooti
>>>> skype: capooti
>>> Vicente Deluca
>> Vicente Deluca
> Paolo Corti
> twitter: @capooti
> skype: capooti
Vicente Deluca
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170928/5b47b778/attachment-0001.html>
---> pavement.start
---> pavement.start_geoserver
cd /var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/data
java -version
java version "1.7.0_151"
OpenJDK Runtime Environment (IcedTea 2.6.11) (7u151-2.6.11-1+deb7u1)
OpenJDK 64-Bit Server VM (build 24.151-b01, mixed mode)
java -Xmx512m -XX:MaxPermSize=256m -DGEOSERVER_DATA_DIR=/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/data -Dorg.eclipse.jetty.server.webapp.parentLoaderPriority=true -jar /var/www/geo.estudiomanta.com/httpdocs/geonode/downloaded/jetty-runner-8.1.8.v20121106.jar --port 8082 --log /var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/jetty.log /var/www/geo.estudiomanta.com/httpdocs/geonode/scripts/misc/jetty-runner.xml > /dev/null &
Starting GeoServer on http://localhost:8082/geoserver/
2017-09-27 21:27:13.844:INFO:omjr.Runner:Runner
2017-09-27 21:27:13.845:WARN:omjr.Runner:No tx manager found
2017-09-27 21:27:13.914:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
Null identity service, trying login service: null
Finding identity service: null
2017-09-27 21:27:14.363:INFO:oejsh.ContextHandler:started o.e.j.w.WebAppContext{/geoserver,file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/},../geoserver
2017-09-27 21:27:14.527:INFO:oejsh.ContextHandler:started o.e.j.w.WebAppContext{/geoserver,file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/},../geoserver
Sep 27, 2017 9:27:14 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
2017-09-27 21:27:14.702:INFO:oejsh.ContextHandler:started o.e.j.w.WebAppContext{/geoserver,file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/},../geoserver
2017-09-27 21:27:14.702:INFO:/geoserver:Initializing Spring root WebApplicationContext
Sep 27, 2017 9:27:16 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
2017-09-27 21:27:16.868:WARN:oejw.WebAppContext:Failed startup of context o.e.j.w.WebAppContext{/geoserver,file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/},../geoserver
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'kmlFormat' defined in URL [jar:file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:997)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:943)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:607)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:925)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:472)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:424)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:249)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1250)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:492)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172)
at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95)
at org.eclipse.jetty.server.Server.doStart(Server.java:277)
at org.mortbay.jetty.runner.Runner.run(Runner.java:504)
at org.mortbay.jetty.runner.Runner.main(Runner.java:625)
Caused by:
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:990)
Caused by:
java.lang.RuntimeException: Could not decode: EPSG:4326
at org.geoserver.importer.format.KMLFileFormat.<clinit>(KMLFileFormat.java:65)
Caused by:
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:951)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:316)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:390)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:520)
at org.geotools.referencing.CRS.decode(CRS.java:448)
at org.geoserver.importer.format.KMLFileFormat.<clinit>(KMLFileFormat.java:63)
2017-09-27 21:27:16.876:INFO:oejs.NCSARequestLog:Opened /var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/jetty.log
2017-09-27 21:27:16.884:WARN:oejuc.AbstractLifeCycle:FAILED SelectChannelConnector at 0.0.0.0:8082: java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:463)
at sun.nio.ch.Net.bind(Net.java:455)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:187)
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:316)
at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:265)
at org.eclipse.jetty.server.Server.doStart(Server.java:288)
2017-09-27 21:27:16.884:WARN:oejuc.AbstractLifeCycle:FAILED org.eclipse.jetty.server.Server at 79db5f5e: java.net.BindException: Address already in use
Usage: java [-DDEBUG] [-Djetty.home=dir] -jar jetty-runner.jar [--help|--version] [ server opts] [[ context opts] context ...]
Server Options:
--version - display version and exit
--log file - request log filename (with optional 'yyyy_mm_dd' wildcard
--out file - info/warn/debug log filename (with optional 'yyyy_mm_dd' wildcard
--port n - port to listen on (default 8080)
--stop-port n - port to listen for stop command
--stop-key n - security string for stop command (required if --stop-port is present)
--jar file - a jar to be added to the classloader
--jdbc classname properties jndiname - classname of XADataSource or driver; properties string; name to register in jndi
--lib dir - a directory of jars to be added to the classloader
--classes dir - a directory of classes to be added to the classloader
--txFile - override properties file for Atomikos
--stats [unsecure|realm.properties] - enable stats gathering servlet context
--config file - a jetty xml config file to use instead of command line options
Context Options:
--path /path - context path (default /)
context - WAR file, web app dir or context.xml file
The logs are available at /var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/jetty.log
GeoServer never started properly or timed out.It may still be running in the background.
Type: text/x-log
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170928/5b47b778/attachment-0001.bin>
More information about the geonode-users
