[GeoNode-users] Preferred installation method for productin
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 10 02:01:12 PDT 2018
Sorry I was speaking in general.
Deb package for APT must be refactored in order to take into account older
versions of geonode.
My idea is:
1- For versions prior of 2.8 I would envisage a "Conflicts" declaration so
that update won't install geonode at all if an older version is already
present, thus forcing the user to either clean-up the system or re-install
from scratch
2- For versions major of 2.8 the deb should be refactored in order to just
update the source code instead of trying to reinstall everything
Notice that the same applies to geoserver-geonode package.
Unfortunately this requires a considerable amount of work.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-04-10 10:38 GMT+02:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>:
> Dear Alessio,
> I strongly suggest to install GeoNode by following this procedure
> https://github.com/GeoNode/geonode-project#using-a-
> python-virtual-environment
> now I´m a bit puzzled as Daniel was not asking for theming (with project)
> but installing by apt and
> to make sure apt upgrade does not break things, right?
> An automatic
>> package upgrade process did not finish and my GeoNode install went the way
>> of the Dodo.
> I though about installing using the PPA repo and then turning the
>> repository off from my sources.list, to prevent unwanted upgrades.
> Correct me if I´m wrong but virtualenv will not protect him here ?
> Best regards,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 10.04.2018 um 09:29 schrieb Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
> Regards,
> Alessio Fabiani
> http://goo.gl/it488V for more information.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-04-09 21:08 GMT+02:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>
>> Hi Daniel,
>> repository off from my sources.list, to prevent unwanted upgrades. Does
>> that sounds like a good idea?
>> yes this is how we ha a quite and peacful life for several years.
>> > only run security patches. f.e. have a look here:
>> https://serverfault.com/questions/270260/how-do-you-use-apt-
>> get-to-only-install-critical-security-updates-on-ubuntu
>> cheers,
>> toni
>> Am 09.04.2018 um 21:00 schrieb geonode-users-request at lists.osgeo.org:
>> Message: 3
>> Date: Mon, 09 Apr 2018 14:47:25 +0000
>> From: Daniel Victoria <daniel.victoria at gmail.com>
>> To: geonode-users <geonode-users at lists.osgeo.org>
>> Subject: [GeoNode-users] Preferred installation method for productin
>> Message-ID:
>> <CA+irsJiruoBVYRFeaZM8vtOY__W+d+iXukVJUar4yBOExdLL-A at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Hi List,
>> Couple of days ago I had a mishap with my GeoNode server. An automatic
>> of the Dodo.
>> I'm now in the process of reinstalling the server and registering the data
>> back (good thing I did not loose any data). So my question is, what is the
>> preferred installation method?
>> Thanks
>> Daniel
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180410/c445ab7c/attachment-0001.html>
More information about the geonode-users mailing list
