[GeoNode-users] [GeoNode-devel] GeoNode 2.8.0 is out!
Elton Davis Turin Espinoza eturine at uni.pe
Mon Apr 16 10:10:48 PDT 2018
Hi all,
I just installed Geonode 2.8 stable and it is not operational, in the
installation process is message out 'ImportError: No module named
geonode.settings'.
Can you please tell me how to make it work?
I executed:
sudo add-apt-repository ppa: geonode / stable
sudo apt-get update
sudo apt-get install geonode
sudo geonode-updateip 35.229.115.147
Please help me
Thank you
Elton
2018-04-03 16:01 GMT-05:00 Paolo Corti <pcorti at gmail.com>:
> Excellent
> Thanks Alessio and to all GeoNode developers, users and the rest of
> the community, it is a great project!
> Paolo
> On Tue, Apr 3, 2018 at 4:06 PM, Lewis, Benjamin <blewis at cga.harvard.edu>
> wrote:
> > Thanks Alessio and the global geonode team!
> > From: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] On
> Behalf
> > Of Alessio Fabiani
> > Sent: Tuesday, April 3, 2018 7:31 AM
> > To: geonode-users <geonode-users at lists.osgeo.org>; geonode-devel
> > <geonode-devel at lists.osgeo.org>
> > Subject: [GeoNode-users] GeoNode 2.8.0 is out!
> > Dear all,
> > GeoNode release 2.8.0 is out!
> > Installing from apt on Ubuntu 16.04
> > In order to test it through APT, on a clean Ubuntu 16.04 instance run:
> > sudo apt-add-repository ppa:geonode/testing
> > sudo apt update -y
> > sudo apt upgrade -y
> > sudo apt install geonode
> > Few notes on finalizing the setup (this will be improved on next release)
> > 1) Update your default map crs to 3857
> >   sudo nano /etc/geonode/local_settings.py
> >     DEFAULT_MAP_CRS = "EPSG:3857"
> >     DEFAULT_LAYER_FORMAT = "image/png8"
> >   sudo service apache2 restart
> > 2) Restart Tomcat in order to allow GeoServer to reload the configuration
> >   sudo service apache tomcat8 restart
> > Setting up your custom project
> > Please follow instructions from
> > https://github.com/GeoNode/geonode-project#using-a-
> python-virtual-environment
> > Upgrading from 2.6.x release
> > If you would like to update from a 2.6.x development version, please
> take a
> > look at the following document (still not definitive)
> > http://docs.geonode.org/en/master/tutorials/install_and_
> admin/geonode_update/26_to_27/index.html#update-from-
> geonode-2-6-3-to-geonode-2-7
> > Other type of setup / installer
> > Docker and Windows installers won't be ready by the announcement of the
> > official release.
> > There are still many issues with those two packages, preventing us to
> > publish stable versions of them.
> > Regards,
> > Alessio Fabiani
> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V
> > for more information.
> > Ing. Alessio Fabiani
> > @alfa7691
> > Founder/Technical Lead
> > GeoSolutions S.A.S.
> > Via di Montramito 3/A
> > 55054  Massarosa (LU)
> > Italy
> > phone: +39 0584 962313
> > fax:     +39 0584 1660272
> > mob:   +39 331 6233686
> > http://www.geo-solutions.it
> > http://twitter.com/geosolutions_it
> > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> > Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i
> > file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> > utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> > finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio
> > senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> > via e-mail e di procedere alla distruzione del messaggio stesso,
> > cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo
> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo
> per
> > finalità diverse, costituisce comportamento contrario ai principi dettati
> > dal D.Lgs. 196/2003.
> > The information in this message and/or attachments, is intended solely
> for
> > the attention and use of the named addressee(s) and may be confidential
> or
> > proprietary in nature or covered by the provisions of privacy act
> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> > Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> > copying, distribution, or either dissemination, either whole or partial,
> is
> > strictly forbidden except previous formal approval of the named
> > addressee(s). If you are not the intended recipient, please contact
> > immediately the sender by telephone, fax or e-mail and delete the
> > information in this message that has been received in error. The sender
> does
> > not give any warranty or accept liability as the content, accuracy or
> > completeness of sent messages and accepts no responsibility  for changes
> > made after they were sent or for other risks which arise as a result of
> > e-mail transmission, viruses, etc.
> > geonode-devel mailing list
> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
"Este mensaje y sus anexos van dirigidos exclusivamente a la persona o
entidad que se muestra como destinatario/s y pueden contener datos
personales y/o información confidencial, sometida a secreto profesional o
cuya divulgación esté prohibida en la legislación
 vigente. Que
<http://www.ctic.uni.edu.pe/>da prohibida, toda divulgación, reproducción u
otra acción
al respecto por parte de personas o entidades  distintas al
destinatario/s. Si ha recibido este mensaje por error, por favor,
contáctenos a la siguiente dirección de correo electrónico
 lpdp at uni.edu.pe
<mailto:lpdp at uni.edu.pe> y proceda a su eliminación.
En cumplimiento a
lo establecido en la Ley de Protección de Datos
Personales - Ley N° 29733,
le informamos que sus datos personales
obtenidos son almacenados bajo la
confidencialidad y las medidas de
seguridad legalmente establecidas y no
serán cedidos ni
 compartidos con empresas ni entidades ajenas a la
Universidad Nacional
de Ingeniería. Si lo desea, usted podrá ejercitar los
derechos de
actualización, inclusión, rectificación, supresión u
oposición, enviando
 un mensaje al correo electrónico anteriormente
señalado e indicando en el "Asunto" el derecho que desea ejercer"
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180416/f806982a/attachment.html>
More information about the geonode-users mailing list
