[GeoNode-users] Stable ppa throws an ImportError during GeoNode postinstall
Dave Kennewell
davekennewell at gmail.com
Tue Apr 17 07:17:04 PDT 2018
Hi all,
I've started new thread so this doesn't get lost, but it follows on from
Elton's issues in the "Geonode 2.8.0 is out!" thread.
I just ran an install script that is usually super-dependable, and got the
same error as Elton when the script runs "sudo apt-get install geonode".
I'm using the stable ppa on Ubuntu 16.04 (clean EC2 image).
Here is the log output:
Creating config file /etc/logrotate.d/tomcat8 with new version
Setting up tomcat8-admin (8.0.32-1ubuntu1.5) ...
Setting up geoserver-geonode (2.12.2-4) ...
Setting up geonode (2.8.0+thefinal0) ...
Sourcing /usr/share/geonode/config-post.sh as the configuration file
Step: 'once specified
Running GeoNode initial configuration ...
CREATE EXTENSION
CREATE ROLE
Step: 'post specified
Running GeoNode postinstall ...
File "/usr/bin/pip", line 9, in <module>
from pip import main
ImportError: cannot import name main
File "<string>", line 1, in <module>
ImportError: No module named geonode
File "/usr/bin/django-admin", line 9, in <module>
load_entry_point('Django==1.8.19', 'console_scripts', 'django-admin')()
File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
utility.execute()
line 303, in execute
settings.INSTALLED_APPS
File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py",
line 48, in __getattr__
self._setup(name)
line 44, in _setup
self._wrapped = Settings(settings_module)
line 92, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
__import__(name)
ImportError: No module named geonode.settings
Is anyone else experiencing this issue with the stable apt-get install?
thanks
Dave
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180417/2b96f4e0/attachment.html>
More information about the geonode-users
