[GeoNode-users] Configuring Remote Database with Geonode
Paolo Corti pcorti at gmail.com
Wed Apr 25 14:27:01 PDT 2018
It could be pre-seeded in GWC, though
p
On Thu, Apr 19, 2018 at 11:33 AM, Stefan Steiniger <sstein at geo.uzh.ch> wrote:
> Hi,
> sorry for the late response. Possible yes, but perhaps not recommendable. I
> have the DB on a different server (but same hub); and I find the response
> times by GeoNode/GeoServer, sometimes quite slow: because Geoserver has to
> fech the data from the Postgis database on the other server to render... and
> this seems to be a bottle neck if you have large layers (200-300MB).
> cheers,
> stefan
> On 4/18/18 09:21, Dave Kennewell wrote:
> Hi Jio,
> Yes, the method you describe should work and enable you to run geonode on a
> different server to your databases. Many instances are setup this way.
> Good luck!
> Dave
> On Wed, 18 Apr 2018, 16:13 DanielV [via OSGeo.org],
> <ml+s1560n5361875h40 at n6.nabble.com> wrote:
>> Hi Jio,
>> I'm not sure about that. Like you, I'm just a user so I don't know if it's
>> possible to move the database to some other host.
>> Cheers
>> Daniel
>> On Wed, Apr 18, 2018 at 5:01 AM Joshi, Jigeeshu <[hidden email]> wrote:
>>> Hi Daniel,
>>> Thank you for your input. Appreciate it !
>>> I have few things to clarify here:
>>> We have just started using Geonode so we do not have much data in Geonode
>>> database (on linux server). So, I was thinking  if it is possible to
>>> configure the postgresql database on windows server as the main/only Geonode
>>> database.
>>> Essentially, Geonode creates two databases ‘geonode’ and ‘geonode_data’.
>>> These can be migrated to DB on windows server . Point the Geoserver
>>> datastore to this DB.  And make changes in local_settings.py. In my
>>> understanding this will enable remote DB on windows server as the default
>>> database for Geonode. Please, correct me if I am wrong .
>>> Regards,
>>> Jio
>>> Von: Daniel Victoria [mailto:[hidden email]]
>>> Gesendet: Dienstag, 17. April 2018 22:00
>>> An: Joshi, Jigeeshu
>>> Cc: geonod[hidden email]
>>> Betreff: Re: [GeoNode-users] Configuring Remote Database with Geonode
>>> Hi Jio,
>>> I don't have documentation ready for this but it's possible to publish
>>> data that is hosted in another database. This is how i do it - not sure if
>>> it's the most correct way
>>> The steps are:
>>> 1) In GeoServer, create a store pointing to the PostGIS database that has
>>> the layers
>>> 2) In GeoServer, create and publish new layers that are contained inside
>>> your new store
>>> 3) In your geonode machine, run the command `geonode updatelayers
>>> --skip-geonode-registered`. This command will scan your GeoServer for new
>>> layers that are not registered in GeoNode and publish them.
>>> 4) Fill in metadata / user / access permisison information for each new
>>> layer created
>>> Cheers
>>> Daniel
>>> On Tue, Apr 17, 2018 at 5:49 AM Joshi, Jigeeshu <[hidden email]> wrote:
>>> Hi All,
>>> I have a quick question regarding geonode software architecture.
>>> We have installed geonode (standard deployment) on a clean linux server
>>> which we have hired and is located outside our organization. However, we
>>> already have a postgresql database on Windows server maintained at our
>>> organization. Is it possible to have geonode use the postgresql database (on
>>> windows server) in our organization so that we do not have to maintain two
>>> databases ?  If possible , kindly provide documentation link for further
>>> information on configuration steps.
>>> Regards,
>>> Jio
>>> geonode-users mailing list
>>> [hidden email]
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> [hidden email]
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Configuring-Remote-Database-with-Geonode-tp5361694p5361875.html
>> To unsubscribe from GeoNode users, click here.
>> NAML
> geonode-users at lists.osgeo.org
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
