[GeoNode-users] Configuring Remote Database with Geonode
Daniel Victoria daniel.victoria at gmail.com
Wed Apr 18 05:12:34 PDT 2018
Hi Jio,
I'm not sure about that. Like you, I'm just a user so I don't know if it's
possible to move the database to some other host.
Cheers
Daniel
On Wed, Apr 18, 2018 at 5:01 AM Joshi, Jigeeshu <
Jigeeshu.Joshi at ils-forschung.de> wrote:
> Hi Daniel,
> Thank you for your input. Appreciate it !
> I have few things to clarify here:
> We have just started using Geonode so we do not have much data in Geonode
> database (on linux server). So, I was thinking  if it is possible to
> configure the postgresql database on windows server as the main/only
> Geonode database.
> Essentially, Geonode creates two databases ‘geonode’ and ‘geonode_data’.
> These can be migrated to DB on windows server . Point the Geoserver
> datastore to this DB.  And make changes in local_settings.py. In my
> understanding this will enable remote DB on windows server as the default
> database for Geonode. Please, correct me if I am wrong .
> Regards,
> Jio
> *Von:* Daniel Victoria [mailto:daniel.victoria at gmail.com]
> *Gesendet:* Dienstag, 17. April 2018 22:00
> *An:* Joshi, Jigeeshu
> *Cc:* geonode-users at lists.osgeo.org
> *Betreff:* Re: [GeoNode-users] Configuring Remote Database with Geonode
> Hi Jio,
> I don't have documentation ready for this but it's possible to publish
> data that is hosted in another database. This is how i do it - not sure if
> it's the most correct way
> The steps are:
> 1) In GeoServer, create a store pointing to the PostGIS database that has
> the layers
> 2) In GeoServer, create and publish new layers that are contained inside
> your new store
> 3) In your geonode machine, run the command `geonode updatelayers
> --skip-geonode-registered`. This command will scan your GeoServer for new
> layers that are not registered in GeoNode and publish them.
> 4) Fill in metadata / user / access permisison information for each new
> layer created
> Cheers
> Daniel
> On Tue, Apr 17, 2018 at 5:49 AM Joshi, Jigeeshu <
> Hi All,
> I have a quick question regarding geonode software architecture.
> We have installed geonode (standard deployment) on a clean linux server
> which we have hired and is located outside our organization. However, we
> already have a postgresql database on Windows server maintained at our
> organization. Is it possible to have geonode use the postgresql database
> (on windows server) in our organization so that we do not have to maintain
> two databases ?  If possible , kindly provide documentation link for
> further information on configuration steps.
> Regards,
> Jio
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180418/d721f84a/attachment-0001.html>
More information about the geonode-users mailing list
