[GeoNode-users] Customizing Geonode (Installed via apt-get) from Geonode-project Dev (Installed via Python Virtualenv)
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Wed Apr 18 12:13:01 PDT 2018
Hi Dave Kennewell,
First, let me introduce you the DATABASES configuration to:
*1 - Geonode (apt-get)*
DATABASE_ENGINE = 'postgresql_psycopg2'
DATABASE_NAME = 'geonode'
DATABASE_USER = 'geonode'
DATABASE_PASSWORD = 'DBImAITC'
DATABASE_HOST = 'localhost'
DATABASE_PORT = '5432'
DATABASES = {
'default': {
'ENGINE': 'django.db.backends.postgresql_psycopg2',
'NAME': DATABASE_NAME,
'USER': DATABASE_USER,
'PASSWORD': DATABASE_PASSWORD,
'HOST': DATABASE_HOST,
'PORT': DATABASE_PORT,
'CONN_TOUT': 900,
# vector datastore for uploads
'datastore': {
'ENGINE': 'django.contrib.gis.db.backends.postgis',
'NAME': 'geonode_data',
'CONN_TOUT': 900,
*2 - Geonode-Project (Virtualenv)*
DATABASES = {
'default': {
'NAME': 'geonode',
'USER': 'geonode',
'PASSWORD': 'geonode',
'HOST' : 'localhost',
'PORT' : '5432',
'CONN_TOUT': 900,
'datastore' : {
'ENGINE': '', # Empty ENGINE name disables
'USER' : 'geonode',
'PASSWORD' : 'geonode',
'PORT' : '5432',
'CONN_TOUT': 900,
>From both DB configuration, I realized one difference: "the database
password"
I made some tests which are found bellow with their results:
*Test 1: geonode.conf (default created by apt-get installation)*
:~$ cd /etc/julierme_virtualenv/my_geonode/my_geonode/
:~$ python manage.py shell
>>>from django.conf import settings
>>>settings.DATABASES
{'default': {'ENGINE': 'django.db.backends.postgresql_psycopg2',
'AUTOCOMMIT': True, 'ATOMIC_REQUESTS': False, 'NAME': 'geonode',
'CONN_MAX_AGE': 0, 'CONN_TOUT': 900, 'TIME_ZONE': 'UTC', 'OPTIONS': {},
'HOST': 'localhost', 'USER': 'geonode', 'TEST': {'COLLATION': None,
'CHARSET': None, 'NAME': None, 'MIRROR': None}, 'PASSWORD': 'DBImAITC',
'PORT': '5432'}, 'datastore': {'ENGINE':
'django.contrib.gis.db.backends.postgis', 'NAME': 'geonode_data',
'CONN_TOUT': 900, 'HOST': 'localhost', 'USER': 'geonode', 'PASSWORD':
'DBImAITC', 'PORT': '5432'}}
*Test 2: geonode.conf (changed according to Geonode-Project WITHOUT
commenting DATABASES = {...} )*
>>>settings.DATABASES
*Test 3: geonode.conf (changed according to Geonode-Project commenting
>>>settings.DATABASES
I may be wrong, but from these tests I have concluded that the database
being used is always the Geonode (apt-get), because of the password showed
in settings.DATABASES ('PASSWORD': 'DBImAITC').
What else could be? I am still thinking about.
I appreciated your time.
Kind Regards
Julierme
2018-04-18 14:16 GMT-03:00 Dave Kennewell <davekennewell at gmail.com>:
> OK, I think you can simply delete the "DATABASES = {...}" lines from
> my_geonode/settings.py which I suspect is overriding the default postgres
> database with something else.
> Don't forget to restart apache2 after changing the settings - this will
> reload them through wsgi - "sudo service apache2 restart"
> If you want to check exactly which settings are being used by your
> geonode-project:
> >>>settings.DATABASES
> should give you all the relevant database configuration that your project
> is actually using.
> On 18 April 2018 at 21:04, Julierme Pinheiro <juliermeopensourcedeveloper@
> gmail.com> wrote:
>> Hi Dave Kennewell,
>> First of all, thank you very much for your prompt reply.
>> I understood your highlights. And going back to your questions:
>> *The next steps to "fix" this depends on which database you want to use
>> long-term?*
>> The postgresql database used by my Geonode (installed via apt-get) is my
>> production database and I want to keep it.
>> *Does this sound right or do you think it is something else? *
>> I think you are right and how I could set my database to be Geonode
>> (apt-get) the long-term? Should this change be done through the wsgi.py?
>> My long-term database configuration installed via apt-get is set in the
>> /etc/geonode/local_settings.py.
>> My wsgi.py and local_settings.py in Geonode-Project (installed via Python
>> virtualenv), in the other hand, are available in
>> /etc/julierme_virtualenv/my_geonode/my_geonode/my_geonode/
>> So, how can I keep postgresql (long-term) installed via apt-get while I
>> change geonode.conf in order to use the layout of Geonode-Project?
>> Thank you very much for your time.
>> I appreciated it.
>> Julierme
>> 2018-04-18 12:24 GMT-03:00 Dave Kennewell <davekennewell at gmail.com>:
>>> Hi Julierme,
>>> The missing maps and users suggests to me that geonode is now using a
>>> different database. If it is still working, but just with no maps or users,
>>> my guess is:
>>> Prior to configuring geonode.conf, you would have been using the default
>>> postgresql database that is installed with geonode via apt-get. This is
>>> likely where your 6 maps & 2 users currently reside.
>>> After configuring geonode.conf, you will likely be using
>>> your_geonode_project.wsgi.py, which will point to
>>> your_geonode_project.settings. This settings file will override the default
>>> postgresql database with whatever you have in there (either in
>>> your_geonode_project.settings or local_settings.py)
>>> long-term?
>>> regards
>>> Dave
>>> On 18 April 2018 at 19:13, juliermeopensourcedeveloper [via OSGeo.org] <
>>> ml+s1560n5361932h7 at n6.nabble.com> wrote:
>>>> Dear all,
>>>> I just finished configuring *geonode.conf* in order to customize
>>>> Geonode main layout (installed via apt-get) based on changes made through
>>>> Geonode-Project Dev layout (installed via Python Virtualenv). Before
>>>> configuring *geonode.conf*, I had 6 Maps and 2 users in my Geonode and
>>>> after applying Geonode-Project Dev layout by changing *geonode.conf*,
>>>> I faced the following problems:
>>>> 1 - The 6 Maps and 2 Users I had in Geonode are gone;
>>>> 2 - I am unable to log in even with Geonode default credentials;
>>>> Could someone tell me why I am facing these problems and figure out one
>>>> way to fix them?
>>>> Thank you very much for your time and patience in advance.
>>>> Best Regards
>>>> Julierme
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5361932&i=0>
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> If you reply to this email, your message will be added to the
>>>> discussion below:
>>>> http://osgeo-org.1560.x6.nabble.com/Customizing-Geonode-Inst
>>>> alled-via-apt-get-from-Geonode-project-Dev-Installed-via-Pyt
>>>> hon-Virtualenv-tp5361932.html
>>>> To unsubscribe from GeoNode users, click here
>>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185389&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OXwtOTI1NjEyMTk0>
>>>> NAML
>>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>> geonode-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180418/46cf0c54/attachment-0001.html>
More information about the geonode-users
