[GeoNode-users] Customizing Geonode (Installed via apt-get) from Geonode-project Dev (Installed via Python Virtualenv)
Dave Kennewell davekennewell at gmail.com
Wed Apr 18 10:16:52 PDT 2018
OK, I think you can simply delete the "DATABASES = {...}" lines from
my_geonode/settings.py which I suspect is overriding the default postgres
database with something else.
Don't forget to restart apache2 after changing the settings - this will
reload them through wsgi - "sudo service apache2 restart"
If you want to check exactly which settings are being used by your
geonode-project:
:~$ cd  /etc/julierme_virtualenv/my_geonode/my_geonode/
:~$ python manage.py shell
>>>from django.conf import settings
>>>settings.DATABASES
 should give you all the relevant database configuration that your project
is actually using.
On 18 April 2018 at 21:04, Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Dave Kennewell,
> First of all, thank you very much for your prompt reply.
> I understood your highlights. And going back to your questions:
> *The next steps to "fix" this depends on which database you want to use
> long-term?*
> The postgresql database used by my Geonode (installed via apt-get) is my
> production database and I want to keep it.
> *Does this sound right or do you think it is something else? *
> I think you are right and how I could set my database to be Geonode
> (apt-get) the long-term? Should this change be done through the wsgi.py?
> My long-term database configuration installed via apt-get is set in the
> /etc/geonode/local_settings.py.
> My wsgi.py and local_settings.py in Geonode-Project (installed via Python
> virtualenv), in the other hand, are available in
> /etc/julierme_virtualenv/my_geonode/my_geonode/my_geonode/
> So, how can I keep postgresql (long-term) installed via apt-get while I
> change geonode.conf in order to use the layout of Geonode-Project?
> Thank you very much for your time.
> I appreciated it.
> Julierme
> 2018-04-18 12:24 GMT-03:00 Dave Kennewell <davekennewell at gmail.com>:
>> Hi Julierme,
>> The missing maps and users suggests to me that geonode is now using a
>> different database. If it is still working, but just with no maps or users,
>> my guess is:
>> Prior to configuring geonode.conf, you would have been using the default
>> postgresql database that is installed with geonode via apt-get. This is
>> likely where your 6 maps & 2 users currently reside.
>> After configuring geonode.conf, you will likely be using
>> your_geonode_project.wsgi.py, which will point to
>> your_geonode_project.settings. This settings file will override the default
>> postgresql database with whatever you have in there (either in
>> your_geonode_project.settings or local_settings.py)
>> long-term?
>> regards
>> Dave
>> On 18 April 2018 at 19:13, juliermeopensourcedeveloper [via OSGeo.org] <
>> ml+s1560n5361932h7 at n6.nabble.com> wrote:
>>> Dear all,
>>> I just finished configuring *geonode.conf* in order to customize
>>> Geonode main layout (installed via apt-get) based on changes made through
>>> Geonode-Project Dev layout (installed via Python Virtualenv). Before
>>> configuring *geonode.conf*, I had 6 Maps and 2 users in my Geonode and
>>> after applying Geonode-Project Dev layout by changing *geonode.conf*, I
>>> faced the following problems:
>>> 1 - The 6 Maps and 2 Users I had in Geonode are gone;
>>> 2 - I am unable to log in even with Geonode default credentials;
>>> Could someone tell me why I am facing these problems and figure out one
>>> way to fix them?
>>> Thank you very much for your time and patience in advance.
>>> Best Regards
>>> Julierme
>>> geonode-users mailing list
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5361932&i=0>
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> If you reply to this email, your message will be added to the discussion
>>> below:
>>> http://osgeo-org.1560.x6.nabble.com/Customizing-Geonode-Inst
>>> alled-via-apt-get-from-Geonode-project-Dev-Installed-via-
>>> Python-Virtualenv-tp5361932.html
>>> To unsubscribe from GeoNode users, click here
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185389&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OXwtOTI1NjEyMTk0>
>>> NAML
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> geonode-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180418/6bf4bd76/attachment-0001.html>
More information about the geonode-users mailing list
