[GeoNode-users] Customizing Geonode (Installed via apt-get) from Geonode-project Dev (Installed via Python Virtualenv)
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed Apr 18 10:04:26 PDT 2018
Hi Dave Kennewell,
First of all, thank you very much for your prompt reply.
I understood your highlights. And going back to your questions:
*The next steps to "fix" this depends on which database you want to use
long-term?*
The postgresql database used by my Geonode (installed via apt-get) is my
production database and I want to keep it.
*Does this sound right or do you think it is something else? *
I think you are right and how I could set my database to be Geonode
(apt-get) the long-term? Should this change be done through the wsgi.py?
My long-term database configuration installed via apt-get is set in the
/etc/geonode/local_settings.py.
My wsgi.py and local_settings.py in Geonode-Project (installed via Python
virtualenv), in the other hand, are available in
/etc/julierme_virtualenv/my_geonode/my_geonode/my_geonode/
So, how can I keep postgresql (long-term) installed via apt-get while I
change geonode.conf in order to use the layout of Geonode-Project?
Thank you very much for your time.
I appreciated it.
Julierme
2018-04-18 12:24 GMT-03:00 Dave Kennewell <davekennewell at gmail.com>:
> Hi Julierme,
> The missing maps and users suggests to me that geonode is now using a
> different database. If it is still working, but just with no maps or users,
> my guess is:
> Prior to configuring geonode.conf, you would have been using the default
> postgresql database that is installed with geonode via apt-get. This is
> likely where your 6 maps & 2 users currently reside.
> After configuring geonode.conf, you will likely be using
> your_geonode_project.wsgi.py, which will point to
> your_geonode_project.settings. This settings file will override the default
> postgresql database with whatever you have in there (either in
> your_geonode_project.settings or local_settings.py)
> long-term?
> regards
> Dave
> On 18 April 2018 at 19:13, juliermeopensourcedeveloper [via OSGeo.org] <
> ml+s1560n5361932h7 at n6.nabble.com> wrote:
>> Dear all,
>> I just finished configuring *geonode.conf* in order to customize Geonode
>> main layout (installed via apt-get) based on changes made through
>> Geonode-Project Dev layout (installed via Python Virtualenv). Before
>> configuring *geonode.conf*, I had 6 Maps and 2 users in my Geonode and
>> after applying Geonode-Project Dev layout by changing *geonode.conf*, I
>> faced the following problems:
>> 1 - The 6 Maps and 2 Users I had in Geonode are gone;
>> 2 - I am unable to log in even with Geonode default credentials;
>> Could someone tell me why I am facing these problems and figure out one
>> way to fix them?
>> Thank you very much for your time and patience in advance.
>> Best Regards
>> Julierme
>> geonode-users mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5361932&i=0>
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Customizing-Geonode-
>> Installed-via-apt-get-from-Geonode-project-Dev-Installed-
>> via-Python-Virtualenv-tp5361932.html
>> To unsubscribe from GeoNode users, click here
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185389&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OXwtOTI1NjEyMTk0>
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> geonode-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180418/ad754b70/attachment.html>
More information about the geonode-users mailing list
