[GeoNode-users] Customizing Geonode (Installed via apt-get) from Geonode-project Dev
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Mon Apr 23 07:26:22 PDT 2018
Hi Dave Kennewell,
greetings from Brazil.
The grep just finished. The response is many settings. py files.
My first attempt, I chose one that is in
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/basic_project/
I commented out the configuration:
#DATABASES = {
# "default": {
# "ENGINE": "django.db.backends.sqlite3", # Add
"postgresql_psycopg2", "postgresql", "mysql", "sqlite3" or "oracle".
# "NAME": "dev.db", # Or path to database file
if using sqlite3.
# "USER": "", # Not used with sqlite3.
# "PASSWORD": "", # Not used with sqlite3.
# "HOST": "", # Set to empty string for
localhost. Not used with sqlite3.
# "PORT": "", # Set to empty string for
default. Not used with sqlite3.
RESPONSE to settings.DATABASES
{'default': {'ENGINE': 'django.db.backends.sqlite3', 'ATOMIC_REQUESTS':
False, 'CONN_MAX_AGE': 600, 'HOST': '', 'USER': '', 'PASSWORD': '',
'OPTIONS': {}, 'AUTOCOMMIT': True, 'NAME':
'/etc/julierme_virtualenv/my_geonode/local/lib/python2.7/site-packages/geonode/development.db',
'TIME_ZONE': 'UTC', 'PORT': '', 'TEST': {'COLLATION': None, 'CHARSET':
None, 'NAME': None, 'MIRROR': None}}}
Second attempt:
DATABASES = {
"default": {
"ENGINE":
"django.db.backends.postgresql_psycopg2", # Add
"NAME": "geonode",
# Or path to database file if using sqlite3.
"USER": "geonode",
"PASSWORD": "DBImAITC",
"HOST": "localhost",
# Set to empty string for localhost. Not used with
sqlite3.
"PORT":
"5432",
# Set to empty string for default. Not used with sqlite3.
Bellow find the response to the whole < grep -r
"django.db.backends.sqlite3" "/" > command. Do you suggest a change for any
of the settings.py listed in the grep?
/etc/... is related to my_geonode (Geonode-Project Dev) and /usr/... is
related to my Geonode (Apt-get) long-term project.
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/dj_database_url.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/oauth2_provider/tests/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/oauth2_provider/tests/settings.py:
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/rest_framework_nested/runtests/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/rest_framework_nested/runtests/settings.py:
'ENGINE': 'django.db.backends.sqlite3', # 'postgresql_psycopg2',
'postgresql', 'mysql', 'sqlite3', 'oracle'.
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/__init__.py,sha256=47DEQpj8HBSa-_TImW-5JCeuQeRkm5NMpJWZG3hSuFU,0
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/base.py,sha256=Pe0K8CP7vI_7ZvzdqfIxlYESjVGU-TAU5LUhX2rDtk0,17462
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/client.py,sha256=Rg8Bwfj68kI78bjH2bEDQfAL008rCegtk7gIqg3NpFU,305
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/creation.py,sha256=7byYbLiaJKs7yvTLkMa36J2eD7kPlHBOVa8mvpBRq7U,3297
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/features.py,sha256=G9NPPhgpknJBUrj0-pn8tHgBO5ThgeW6HEJ1KwdXshw,2631
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/introspection.py,sha256=ROCqblFqWMBo4AhqHTKNZq5BRFy_2LguFd9AEmSwn20,11019
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/operations.py,sha256=Ov8yrILHFrmWiNU3E3PHmDjny2QgL16ujUk9OWazEi0,8655
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/schema.py,sha256=uvPssUfC8DxEzhgNkwgOBcMFmsTdw69hyxap_GvGpJg,11377
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/utils.py,sha256=x1hTKZrG2MkU5f7HUGnVXE3tJWXT4J6C528QzSAB03Q,389
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/base.pyc,,
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/operations.pyc,,
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/introspection.pyc,,
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/schema.pyc,,
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/client.pyc,,
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/features.pyc,,
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/__init__.pyc,,
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/utils.pyc,,
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/creation.pyc,,
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/treebeard/tests/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/treebeard/tests/settings.py:
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/testproject/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/testproject/settings.py:
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/geonode/contrib/geosites/README.md:
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/geonode/contrib/geosites/site_template/local_settings_template.py:
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/geonode/geoserver/tests.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/geonode/geoserver/tests.py:
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/geonode/tests/bdd/conftest.py:
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/geonode/tests/bdd/conftest.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/dj_database_url.py:
'sqlite': 'django.db.backends.sqlite3',
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/dj_pagination/tests/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/dj_pagination/tests/settings.py:
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/static_project/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/static_project/settings.py:
"ENGINE": "django.db.backends.sqlite3", # Add "postgresql_psycopg2",
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/zero_project/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/zero_project/settings.py:
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/account_project/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/account_project/settings.py:
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/basic_project/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pinax/projects/basic_project/settings.py:
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pytest_django/db_reuse.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pytest_django/live_server_helper.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pytest_django/db_reuse.py:
if connection.settings_dict['ENGINE'] == 'django.db.backends.sqlite3':
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pytest_django/live_server_helper.py:
if (conn.settings_dict['ENGINE'] == 'django.db.backends.sqlite3' and
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pytest_django/fixtures.py:
if db_settings['ENGINE'] == 'django.db.backends.sqlite3':
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pytest_django/fixtures.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/actstream/runtests/settings.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/actstream/runtests/manage.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/actstream/runtests/settings.py:ENGINE
= os.environ.get('DATABASE_ENGINE', 'django.db.backends.sqlite3')
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/actstream/runtests/manage.py:engine
engine = 'django.db.backends.sqlite3'
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/__init__.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/schema.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/base.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/features.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/client.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/introspection.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/operations.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/utils.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/db/backends/sqlite3/creation.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/features.py:from
django.db.backends.sqlite3.features import \
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/base.py:from
django.db.backends.sqlite3.base import (
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/introspection.py:from
django.db.backends.sqlite3.introspection import (
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/client.py:from
django.db.backends.sqlite3.client import DatabaseClient
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/operations.py:from
django.db.backends.sqlite3.operations import DatabaseOperations
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/schema.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/base.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/adapter.py:from
django.db.backends.sqlite3.base import Database
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/adapter.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/schema.py:from
django.db.backends.sqlite3.schema import DatabaseSchemaEditor
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/features.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/client.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/introspection.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/operations.pyc
matches
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/creation.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/contrib/gis/db/backends/spatialite/creation.py:from
django.db.backends.sqlite3.creation import DatabaseCreation
Binary file
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/conf/project_template/project_name/settings.pyc
matches
/etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/django/conf/project_template/project_name/settings.py:
grep: /run/user/1000/gvfs: Permission denied
Binary file
/run/log/journal/18ac8792d324491caeaf131039b9cd97/system.journal matches
/usr/local/lib/python2.7/dist-packages/geonode/contrib/geosites/README.md:
/usr/local/lib/python2.7/dist-packages/geonode/contrib/geosites/site_template/local_settings_template.py:
Binary file
/usr/local/lib/python2.7/dist-packages/geonode/geoserver/tests.pyc matches
/usr/local/lib/python2.7/dist-packages/geonode/geoserver/tests.py:
/usr/local/lib/python2.7/dist-packages/geonode/tests/bdd/conftest.py:
Binary file
/usr/local/lib/python2.7/dist-packages/geonode/tests/bdd/conftest.pyc
matches
Binary file /usr/lib/python2.7/dist-packages/dj_database_url.pyc matches
Binary file
/usr/lib/python2.7/dist-packages/oauth2_provider/tests/settings.pyc matches
/usr/lib/python2.7/dist-packages/oauth2_provider/tests/settings.py:
Binary file
/usr/lib/python2.7/dist-packages/rest_framework_nested/runtests/settings.pyc
matches
/usr/lib/python2.7/dist-packages/rest_framework_nested/runtests/settings.py:
Binary file /usr/lib/python2.7/dist-packages/treebeard/tests/settings.pyc
matches
/usr/lib/python2.7/dist-packages/treebeard/tests/settings.py:
Binary file /usr/lib/python2.7/dist-packages/testproject/settings.pyc
matches
/usr/lib/python2.7/dist-packages/testproject/settings.py: 'ENGINE':
/usr/lib/python2.7/dist-packages/dj_database_url.py: 'sqlite':
Binary file
/usr/lib/python2.7/dist-packages/dj_pagination/tests/settings.pyc matches
/usr/lib/python2.7/dist-packages/dj_pagination/tests/settings.py:
Binary file
/usr/lib/python2.7/dist-packages/actstream/runtests/settings.pyc matches
Binary file /usr/lib/python2.7/dist-packages/actstream/runtests/manage.pyc
matches
/usr/lib/python2.7/dist-packages/actstream/runtests/settings.py:ENGINE =
/usr/lib/python2.7/dist-packages/actstream/runtests/manage.py:engine =
/usr/lib/python2.7/dist-packages/actstream/runtests/manage.py: engine =
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/__init__.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/schema.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.pyc matches
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/features.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/client.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/introspection.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/operations.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/utils.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/creation.pyc
matches
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/features.py:from
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/base.py:from
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/introspection.py:from
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/client.py:from
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/operations.py:from
Binary file
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/schema.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/base.pyc
matches
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/adapter.py:from
Binary file
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/adapter.pyc
matches
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/schema.py:from
Binary file
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/features.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/client.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/introspection.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/operations.pyc
matches
Binary file
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/creation.pyc
matches
/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/creation.py:from
Binary file
/usr/lib/python2.7/dist-packages/django/conf/project_template/project_name/settings.pyc
matches
/usr/lib/python2.7/dist-packages/django/conf/project_template/project_name/settings.py:
Thank you for your time and help.
Best regards
Julierme
2018-04-19 12:03 GMT-03:00 Dave Kennewell <davekennewell at gmail.com>:
> OK, great Julierme, we're getting there!
> I'm guessing you want to run Django & geonode from this virtualenv, so
> let's figure that out.
> You need to find in which settings file sets the
> "django.db.backends.sqlite3" in your code, and then comment this section
> out.
> If you can't find it, try something like:
> grep -r "django.db.backends.sqlite3" "/"
> which will search all files under your root directory "/" for this text.
> You might need a coffee while you wait, and might need to use sudo to avoid
> getting a bunch of "permission denied" messages.
> On 19 April 2018 at 18:42, Julierme Pinheiro <juliermeopensourcedeveloper@
> gmail.com> wrote:
>> Looking at the ALLOWED_HOSTS and PROXY_ALLOWED_HOSTS in the settings.py
>> in my_geonode (Geonode-project DEV)
>> ALLOWED_HOSTS = ['localhost', 'django', '172.21.14.45'] if
>> os.getenv('ALLOWED_HOSTS') is None \
>> else re.split(r' *[,|:|;] *', os.getenv('ALLOWED_HOSTS'))
>> PROXY_ALLOWED_HOSTS += ('nominatim.openstreetmap.org', '172.21.14.45',)
>> I am not sure if that configuration is missing something.
>> Kind regards
>> Julierme
>> 2018-04-19 11:17 GMT-03:00 Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com>:
>>> Dear Toni Schonbuchner and Dave Kennewell,
>>> Thank you very much for your reply.
>>> First if I did not misunderstand Toni suggestion, I tried the following:
>>> *1 - Commenting out <# ENGINE': '', # Empty ENGINE name disables> from
>>> local_settings.py in my_geonode (Geonode-Project Dev virtualenv)*
>>> Result: the problem remains
>>> *2 - Uncommenting out < ENGINE': '', # Empty ENGINE name disables> from
>>> local_settings.py in my_geonode (Geonode-Project Dev virtualenv) and
>>> inserting the line < ENGINE': '', # Empty ENGINE name disables> in
>>> local_settings.py from Geonode (Geonode apt-get)*.
>>> However, I got a new response to Dave Kennewell suggestion after
>>> activating my_geonode virtualenv:
>>> *settings.DATABASES*
>>> 'OPTIONS': {}, 'AUTOCOMMIT': True, 'NAME': '/etc/julierme_virtualenv/my_g
>>> I think there is no database being used.
>>> I also have to make some few notes:
>>> *1 - ALLOWED_HOSTS, PROXY_ALLOWED_HOSTS and POSTGIS_VERSION are
>>> commented out in local_settings.py in my_geonode (Geonode-Project Dev)*
>>> *2 - Geoserver Port is 8080 in Geonode(apt-get) and 6060 in
>>> my_geonode(Geonode-Project Dev), but both are running fine.*
>>> Thank you very much for your time and patience.
>>> I appreciated it.
>>> Julierme
>>> 2018-04-19 4:29 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de
>>>> Dear Julierme,
>>>> I haven´t followed the whole thread but have a look at this comment:
>>>> 'ENGINE': '', # Empty ENGINE name disables
>>>> See if things change if you set ENGINE to geonode in your project.
>>>> Best regards,
>>>> Toni
>>>> CSGIS
>>>> Kolonnadenstraße 1
>>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>>> 04109 Leipzig
>>>> Mobil +49/ (0) 176 6680 3198
>>>> Tel +49/ (0) 341 24 04 738
>>>> Fax +49/ (0) 341 24 04 73
>>>> Web http://csgis.de
>>>> Hinweis gemäß § 33 BDSG
>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>>> ausschließlich für den
>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>>> diese E-Mail versehentlich
>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>>> löschen Sie diese Nachricht
>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>> Vervielfältigung, Veränderung,
>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>> Am 18.04.2018 um 21:13 schrieb geonode-users-request at lists.osgeo.org:
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180423/81fbed5b/attachment-0001.html>
More information about the geonode-users
