[GeoNode-users] GeoNode-Project: migration and createsuperuser (Julierme Pinheiro)
francesco bartoli xbartolone at gmail.com
Tue Aug 7 23:08:06 PDT 2018
Hi Julierme,
did you run "paver setup" before at the beginning when you bootstrapped
your dev environment?
Il giorno mer 8 ago 2018 alle ore 00:28 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Dear Francesco,
> Thank you very much for your reply. I see. That was one of my mistakes. I
> was settings  different environments for GeoNode Production (GP at 2.8.0)
> and GeoNode Development (GD at 2.8.0).
> Now, Because I already have GP running smoothly, I assumed that the GP and
> GD requirements are installed  and I checked one by one and I got only two
> requirements mismatching.
> requirements already installed for GP
> requirements for GD not installed                        (requirements GP x
> GD)
> pip freeze | grep -i Django
> Django==1.8.19
> Django==1.8.19                                                 Match
> pip freeze | grep -i six
> six==1.10.0
> six==1.10.0                                                        Match
> django-cuser==201
> django-cuser==2017.3.16                                   Match
> django-model-utils==3.1.1
> django-model-utils==3.1.1                                  Match
> Shapely==1.5.17.post1
> Shapely==1.5.17                                                Match
> *OWSLib==0.15.0
> OWSLib==0.16.0    *                                           *MisMatch*
> pyshp==1.2.12
> pyshp==1.2.12                                                    Match
> celery==4.1.0
> celery==4.1.0                                                      Match
> numpy==1.13.1
> numpy==1.13.1                                                   Match
> proj==0.1.0
> proj==0.1.0                                                         Match
> *pyproj==1.9.5.1
> pyproj==1.9.3 *                                                 *MisMatch*
> pygdal==2.2.1.3
> pygdal==2.2.1.3                                                  Match
> inflection==0.3.1
> inflection==0.3.1                                                 Match
> backports.functools-lru-cache==1.5
> backports.functools-lru-cache>=1.2.1                  Attend
> arrow==0.12.1
> arrow==0.12.1                                                    Match
> django-haystack==2.7.0
> django-haystack==2.7.0                                      Match
> django-oauth-toolkit==0.12.0
> django-oauth-toolkit==0.12.0                               Match
> django-autocomplete-light==2.3.3
> django-autocomplete-light==2.3.3                         Match
> oauthlib==2.0.1
> oauthlib==2.0.1                                                   Match
> pycsw==2.0.3
> pycsw==2.0.3                                                      Match
> lxml==3.6.2
> lxml==3.6.2                                                         Match
> flake8==2.5.4
> flake8==2.5.4                                                      Match
> pyflakes==0.8.1
> pyflakes==0.8.1                                                      Match
> python-dateutil==2.6.1
> python-dateutil==2.6.1                                            Match
> Assuming that the requirements for GD were installed based on the list
> above, I went straight to the command line (pip install -e .
> --no-warn-conflicts).
> The command ran well. Successfully installed my-geonode
> With GP and GD virrtualenv activated I am trying to run paver reset and
> hitting the following error:
> (geonode) geo at gis:/home/my_geonode/my_geonode$ paver reset
> ---> pavement.reset
> ---> pavement.stop
> ---> pavement.stop_geoserver
> Stopping geoserver (process number 20499)
> sleep 30
> Stopping geoserver (process number 20501)
> [Errno 3] No such process
> ---> pavement.stop_qgis_server
> Stopping GeoNode ...
> ---> pavement.stop_django
> rm -rf
> /home/geo/Envs/geonode/local/lib/python2.7/site-packages/geonode/development.db
> rm -rf my_geonode/development.db
> rm -rf my_geonode/uploaded/*
> [Errno 2] No such file or directory: path('geoserver/data/global.xml')
> path('geoserver/data/security/filter/geonode-oauth2/config.xml')
> path('geoserver/data/security/role/geonode REST role service/config.xml')
> Any hint in what is causing these errors will be very appreciated.
> Thank you very much for your time in advance
> Kind regards
> Julierme
> On Thu, Aug 2, 2018 at 1:27 PM, francesco bartoli <xbartolone at gmail.com>
> wrote:
>> Sorry blame myself to made a direct reply in the previous message!
>> I think probably you have started with too many geonode setups but now
>> just to figure out this once forever the trick for inheritance is based on
>> the concept to have geonode (as a library) and geonode-project installed
>> together in the same virtual environment.
>> Once you get this then you can replace the geonode references with the
>> same from the geonode-project.
>> Hope this helps
>> Francesco
>> Il giorno gio 2 ago 2018 alle ore 18:06 Julierme Pinheiro <
>>> Dear Francesco,
>>> Sorry, I am just amazed the way GeoNode is built. You all do a wonderful
>>> work. I used the term bridge because I have to environments GeoNode
>>> Production and GeoNode-Project, and I have to connect ( please take the
>>> term "bridge" out of consideration) these two environments through Apache2
>>> configuration.
>>> Just to make sure that I was not doing anything wrong, I installed
>>> geonode-project at 2.8.0 and geonode-project at 2.6.3.
>>> I did just one change in site_base.css --> .home .jumbotron {
>>> background: yellow }
>>> I ran python manage.py collectstatic
>>> And Lastly, I did as in <http://geonode.org/dev-workshop/#/8/3>,
>>> geonode.conf
>>>  WSGIScriptAlias / /home/sipam_geonode/geonode/geonode/wsgi.py  #
>>> According to the third line after second "Warning" in
>>> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html
>>>      <Directory "/home/sipam_geonode/geonode/geonode/"> # According to
>>> the fourth bullet point in http://geonode.org/dev-workshop/#/8/3
>>> #     <Directory "/home/geonode/my_geonode/my_geonode/">
>>>          <Files wsgi.py>
>>>              Order deny,allow
>>>              Allow from all
>>>              Require all granted
>>>          </Files>
>>>         Order allow,deny
>>>         Options Indexes FollowSymLinks
>>>         Allow from all
>>>         IndexOptions FancyIndexing
>>>     </Directory>
>>>   <Directory "/home/sipam_geonode/"> # According to the fifth bullet
>>>         Order allow,deny
>>>         Allow from all
>>>         Require all granted
>>>     </Directory>
>>> Within this configuration, GeoNode Production goes up and runs, but I do
>>> not see inheritance.  So, I am not connecting them correctly.
>>> Again I apologize for the term bridge.
>>> Thank you very much for your time and help.
>>> Kind regards
>>> Julierme
>>> On Thu, Aug 2, 2018 at 12:17 PM, francesco bartoli <xbartolone at gmail.com
>>> > wrote:
>>>> Responses inline.
>>>> Il giorno gio 2 ago 2018 alle ore 15:22 Julierme Pinheiro <
>>>>> Dear Francesco,
>>>>> Thank you very much for your reply and resource suggestion. I am
>>>>> taking a python course and as soon as I finished it, I will devour the
>>>>> information in http://www.paolocorti.net/foss4g_2017_geonode_solr/.
>>>>> <http://www.paolocorti.net/foss4g_2017_geonode_solr/>
>>>>> Regarding Gdalinfo, I have gdal at 2.2.1 and pygdal at 2.2.1.3
>>>>> geo at gis:~$ gdal-config --version
>>>>> 2.2.1
>>>>> 2.2.1
>>>>> geo at gis:~$ pip show pygdal
>>>>> Version: 2.2.1.3
>>>> According to your command you have pygdal installed systemwide which
>>>> doesn't mean you have it in each of the virtual environments. So for
>>>> instance:
>>>> (sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode$ pip freeze
>>>> |grep -i gdal
>>>> should tell you that no entry is listed. This means you have to run
>>>> "pip install pygdal==2.2.1.3"
>>>>> Before entering to the resource you sent me, let me just give some
>>>>> more information about what I am trying to do. I created three virtualenv
>>>>> for GeoNode-Project named by: my_geonode, geonode_project, and
>>>>> sipam_geonode. Sorry if I am misunderstanding, but I think I can do that
>>>>> without mixing the requirements  (requirements.txt) for each GeoNode
>>>>> vesrion. Also I created three users /home/my_geonode; /home/geonode_project
>>>>> and /home/sipam_geonode.
>>>>> (my_geonode) geo at gis: /home/my_geonode/my_geonode  # contains
>>>>> GeoNode-Project at 2.8.0. installed according to the pdf in attached.
>>>>> Fine. GeoNode is up and running.
>>>>> One issue only: I collected the static directory by running python
>>>>> manage.py collectstatic, but I did not see css changes on the index.html.
>>>>> site_base.css ---> .home .jumbotron { background: yellow }
>>>>> (geonode_project) geo at gis: /home/geonode_project/my_geonode  #
>>>>> contains GeoNode-Project at 2.9.0. installed according to
>>>>> https://github.com/geosolutions-it/geonode-project
>>>>> Issue1: paver sync
>>>>> Response:
>>>>>  pavement.sync
>>>>>  python -W ignore manage.py makemigrations --noinput
>>>>> Traceback (most recent call last):
>>>>>   File "manage.py", line 31, in <module>
>>>>>     execute_from_command_line(sys.argv)
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>> line 364, in execute_from_command_line
>>>>>     utility.execute()
>>>>>   File
>>>>> line 356, in execute
>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>> line 283, in run_from_argv
>>>>>     self.execute(*args, **cmd_options)
>>>>>   File
>>>>> line 327, in execute
>>>>>     self.check()
>>>>>   File
>>>>> line 359, in check
>>>>>     include_deployment_checks=include_deployment_checks,
>>>>>   File
>>>>> line 346, in _run_checks
>>>>>     return checks.run_checks(**kwargs)
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/registry.py",
>>>>> line 81, in run_checks
>>>>>     new_errors = check(app_configs=app_configs)
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/checks/urls.py",
>>>>> line 16, in check_url_config
>>>>>     return check_resolver(resolver)
>>>>>   File
>>>>> line 26, in check_resolver
>>>>>     return check_method()
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/urls/resolvers.py",
>>>>> line 254, in check
>>>>>     for pattern in self.url_patterns:
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/functional.py",
>>>>> line 35, in __get__
>>>>>     res = instance.__dict__[self.name] = self.func(instance)
>>>>>   File
>>>>> line 405, in url_patterns
>>>>>     patterns = getattr(self.urlconf_module, "urlpatterns",
>>>>> self.urlconf_module)
>>>>>   File
>>>>> line 35, in __get__
>>>>>   File
>>>>> line 398, in urlconf_module
>>>>>     return import_module(self.urlconf_name)
>>>>>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>>>>> import_module
>>>>>     __import__(name)
>>>>>   File "/home/geonode_project/my_geonode/my_geonode/urls.py", line 24,
>>>>> in <module>
>>>>>     from geonode.urls import urlpatterns
>>>>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/urls.py",
>>>>> line 89, in <module>
>>>>>     url(r'^catalogue/', include('geonode.catalogue.urls')),
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/conf/urls/__init__.py",
>>>>> line 50, in include
>>>>>     urlconf_module = import_module(urlconf_module)
>>>>> import_module
>>>>>     __import__(name)
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/urls.py",
>>>>> line 22, in <module>
>>>>>     from . import views
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/views.py",
>>>>> line 29, in <module>
>>>>>     from pycsw import server
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pycsw/__init__.py",
>>>>> line 35, in <module>
>>>>>     __version__ = pkg_resources.require("pycsw")[0].version
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/pkg_resources/__init__.py",
>>>>> line 892, in require
>>>>>     needed = self.resolve(parse_requirements(requirements))
>>>>>   File
>>>>> line 783, in resolve
>>>>>     raise VersionConflict(dist, req).with_context(dependent_req)
>>>>> pkg_resources.ContextualVersionConflict: (xmltodict 0.9.2
>>>>> (/home/geo/Envs/geonode_project/lib/python2.7/site-packages),
>>>>> Requirement.parse('xmltodict==0.10.2'), set(['pycsw']))
>>>>> Captured Task Output:
>>>>> ---> pavement.sync
>>>>> Build failed running pavement.sync: Subprocess return code: 1
>>>>> Issue2: paver start
>>>>> *Note*: The issue seems to be related to xmltodict version. It is
>>>>> installed xmltodict 0.9.2, but it requires xmltodict 0.10.2. My concern is
>>>>> to try to upgrade the requirements version and get everything messed up.
>>>>> (geonode_project) geo at gis:/home/geonode_project/my_geonode$ pip show
>>>>> xmltodict
>>>>> Version: 0.9.2
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/utils/autoreload.py",
>>>>> line 228, in wrapper
>>>>>     fn(*args, **kwargs)
>>>>>   File
>>>>> "/home/geo/Envs/geonode_project/local/lib/python2.7/site-packages/django/core/management/commands/runserver.py",
>>>>> line 124, in inner_run
>>>>>     self.check(display_num_errors=True)
>>>>>   File
>>>>> line 359, in check
>>>>>   File
>>>>>   File
>>>>>   File
>>>>>   File
>>>>>   File
>>>>> line 254, in check
>>>>>   File
>>>>> line 35, in __get__
>>>>>   File
>>>>>   File
>>>>> line 35, in __get__
>>>>>   File
>>>>> import_module
>>>>>     __import__(name)
>>>>> in <module>
>>>>>   File
>>>>> line 50, in include
>>>>> import_module
>>>>>     __import__(name)
>>>>>   File
>>>>>     from . import views
>>>>>   File
>>>>>   File
>>>>>   File
>>>>>   File
>>>>> GeoNode is now available.
>>>>> (sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode  # contains
>>>>> GeoNode-Project at 2.6.x. installed according to
>>>>> http://geonode.org/dev-workshop/#/2/3
>>>>> Issues: python manage.py migrate
>>>>>            python manage.py createsuperuser
>>>>>            python manage.py shell
>>>>> Response:
>>>>>   File "manage.py", line 29, in <module>
>>>>>   File
>>>>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>> line 354, in execute_from_command_line
>>>>>     utility.execute()
>>>>>   File
>>>>> line 328, in execute
>>>>>     django.setup()
>>>>>   File
>>>>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/__init__.py",
>>>>> line 18, in setup
>>>>>     apps.populate(settings.INSTALLED_APPS)
>>>>>   File
>>>>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/registry.py",
>>>>> line 108, in populate
>>>>>     app_config.import_models(all_models)
>>>>>   File
>>>>> "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/apps/config.py",
>>>>> line 198, in import_models
>>>>>     self.models_module = import_module(models_module_name)
>>>>> import_module
>>>>>     __import__(name)
>>>>>   File "/home/sipam_geonode/geonode/geonode/base/models.py", line 56,
>>>>> in <module>
>>>>>     from geonode.utils import bbox_to_wkt
>>>>>   File "/home/sipam_geonode/geonode/geonode/utils.py", line 30, in
>>>>> <module>
>>>>>     from osgeo import ogr
>>>>> ImportError: No module named osgeo
>>>>> What I am doing seems to be crazy (;. But I separated my project in
>>>>> two parts, in one side I have GeoNode Production working fine and on the
>>>>> other, I need to have GeoNode-project. My goal is to have geonode-project
>>>>> working fine and make the connection between them. A bridge project started
>>>>> from its land edges (;
>>>> Regardless of the version you have chosen and the corresponding virtual
>>>> environment please note that you definitively don't need the bridge at all.
>>>> The scope of geonode-project is right to ease the life of a developer
>>>> and basically everything is already bridged ;).
>>>> Just to let's figure out if somehow the workshop is gone to make it
>>>> confusing can you tell us where did you find such information to the need
>>>> of a bridge?
>>>> Maybe we can consider to rewrite that part.
>>>>> Kind regards
>>>>> Julierme
>>>>> On Thu, Aug 2, 2018 at 7:51 AM, francesco bartoli <
>>>>> xbartolone at gmail.com> wrote:
>>>>>> Hi Julierme,
>>>>>> just to give you some quick ways to check what could be wrong.
>>>>>> Check what GDAL version is installed or it isn't
>>>>>> $ gdalinfo --version
>>>>>> Check if the python bindings for GDAL are installed
>>>>>> (virtual environment)
>>>>>> $ python manage.py shell
>>>>>> (geonode installed systemwide)
>>>>>> $ geonode shell
>>>>>> then in the interactive python shell
>>>>>> Remember to make sure to match the GDAL binary version when you
>>>>>> install the python bindings pygdal as already suggested by Toni.
>>>>>> A great resource to improve your confidence to programming GeoNode
>>>>>> with the interactive shell is the workshop from Paolo Corti:
>>>>>> Il giorno gio 2 ago 2018 alle ore 12:27 Julierme Pinheiro <
>>>>>>> Hi Toni,
>>>>>>> Thank you very much for your reply. The problem remains even after
>>>>>>> your suggested command lines. I will separate a brand new Ubuntu at 16.04LTS
>>>>>>> machine and see what happens.
>>>>>>> I appreciated your time and help.
>>>>>>> Kind regards
>>>>>>> Julierme
>>>>>>> 2018-08-02 6:07 GMT-03:00 Toni Schönbuchner <
>>>>>>> toni.schoenbuchner at csgis.de>:
>>>>>>>> Hi Julierme,
>>>>>>>> you´re on ubuntu, right? can you check:
>>>>>>>> $ sudo apt-get install python-gdal gdal-bin libgdal20 libgdal-dev libgdal-devpython-gdal –y
>>>>>>>> $ pip install pygdal==2.2.1.3
>>>>>>>> Cheers,
>>>>>>>> Toni
>>>>>>>> CSGIS
>>>>>>>> Kolonnadenstraße 1
>>>>>>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>>>>>>> 04109 Leipzig
>>>>>>>> Mobil +49/ (0) 176 6680 3198
>>>>>>>> Tel  +49/ (0) 341 24 04 738
>>>>>>>> Fax  +49/ (0) 341 24 04 73
>>>>>>>> Web http://csgis.de
>>>>>>>> Hinweis gemäß § 33 BDSG
>>>>>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument
>>>>>>>> ist ausschließlich für den
>>>>>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls
>>>>>>>> Sie diese E-Mail versehentlich
>>>>>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an
>>>>>>>> und löschen Sie diese Nachricht
>>>>>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>>>>>> Vervielfältigung, Veränderung,
>>>>>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>>>>>> Am 01.08.2018 um 19:12 schrieb
>>>>>>>> geonode-users-request at lists.osgeo.org:
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180808/705dccb9/attachment-0001.html>
More information about the geonode-users mailing list
