[GeoNode-users] GeoNode-Project: migration and createsuperuser (Julierme Pinheiro)
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed Aug 8 12:37:15 PDT 2018
Hi Francesco,
Yes, I did. And I was having a lot of issues will all commands paver reset,
paver setup, paver sync and paver start.
Here what I did: as I installed GeoNode Production using [1], I decided to
fall the setup for GeoNode Development according to [2].
I have GeoNode Production running in a virtualenv named geonode placed in
/home/geonode/my_geonode (GeoNode Production)
And I have GeoNode Development running in the same virtualenv (geonode)
placed in /home/geonode/geonode_proj (GeoNode Development)
After all setup for GeoNode Development which is up and running, without
making any change to geonode.conf, I started tomcat8 and apache2 and
realized that my GeoNode Production website is pointing to GeoNode
Development website. Could you tell me why? I did not make any change at
all to geonode.conf since the first time I started tomcat8 and apache2.
But, anyway, I have made a lot of changes to geonode.conf, but I can not
get Production pointing to the write database.
Any hint on that will be very appreciated.
Kind Regards
Julierme
[1]
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
[2]
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html
On Wed, Aug 8, 2018 at 3:08 AM, francesco bartoli <xbartolone at gmail.com>
wrote:
> Hi Julierme,
> did you run "paver setup" before at the beginning when you bootstrapped
> your dev environment?
> Il giorno mer 8 ago 2018 alle ore 00:28 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear Francesco,
>> Thank you very much for your reply. I see. That was one of my mistakes. I
>> was settings  different environments for GeoNode Production (GP at 2.8.0)
>> and GeoNode Development (GD at 2.8.0).
>> Now, Because I already have GP running smoothly, I assumed that the GP
>> and GD requirements are installed  and I checked one by one and I got only
>> two requirements mismatching.
>> requirements already installed for GP
>> requirements for GD not installed                        (requirements
>> GP x GD)
>> pip freeze | grep -i Django
>> Django==1.8.19
>> Django==1.8.19                                                 Match
>> pip freeze | grep -i six
>> six==1.10.0
>> six==1.10.0                                                        Match
>> django-cuser==201
>> django-cuser==2017.3.16                                   Match
>> django-model-utils==3.1.1
>> django-model-utils==3.1.1                                  Match
>> Shapely==1.5.17.post1
>> Shapely==1.5.17                                                Match
>> *OWSLib==0.15.0
>> OWSLib==0.16.0    *                                           *MisMatch*
>> pyshp==1.2.12
>> pyshp==1.2.12                                                    Match
>> celery==4.1.0
>> celery==4.1.0                                                      Match
>> numpy==1.13.1
>> numpy==1.13.1                                                   Match
>> proj==0.1.0
>> proj==0.1.0                                                         Match
>> *pyproj==1.9.5.1
>> pyproj==1.9.3 *
>> *MisMatch*
>> pygdal==2.2.1.3
>> pygdal==2.2.1.3                                                  Match
>> inflection==0.3.1
>> inflection==0.3.1                                                 Match
>> backports.functools-lru-cache==1.5
>> backports.functools-lru-cache>=1.2.1                  Attend
>> arrow==0.12.1
>> arrow==0.12.1                                                    Match
>> django-haystack==2.7.0
>> django-haystack==2.7.0                                      Match
>> django-oauth-toolkit==0.12.0
>> django-oauth-toolkit==0.12.0                               Match
>> django-autocomplete-light==2.3.3
>> django-autocomplete-light==2.3.3                         Match
>> oauthlib==2.0.1
>>    oauthlib==2.0.1
>> Match
>> pycsw==2.0.3
>> pycsw==2.0.3                                                      Match
>> lxml==3.6.2
>> lxml==3.6.2                                                         Match
>> flake8==2.5.4
>> flake8==2.5.4                                                      Match
>> pyflakes==0.8.1
>> pyflakes==0.8.1
>> Match
>> python-dateutil==2.6.1
>> python-dateutil==2.6.1                                            Match
>> Assuming that the requirements for GD were installed based on the list
>> above, I went straight to the command line (pip install -e .
>> --no-warn-conflicts).
>> The command ran well. Successfully installed my-geonode
>> With GP and GD virrtualenv activated I am trying to run paver reset and
>> hitting the following error:
>> (geonode) geo at gis:/home/my_geonode/my_geonode$ paver reset
>> ---> pavement.reset
>> ---> pavement.stop
>> ---> pavement.stop_geoserver
>> Stopping geoserver (process number 20499)
>> sleep 30
>> Stopping geoserver (process number 20501)
>> [Errno 3] No such process
>> ---> pavement.stop_qgis_server
>> Stopping GeoNode ...
>> ---> pavement.stop_django
>> rm -rf /home/geo/Envs/geonode/local/lib/python2.7/site-packages/
>> geonode/development.db
>> rm -rf my_geonode/development.db
>> rm -rf my_geonode/uploaded/*
>> [Errno 2] No such file or directory: path('geoserver/data/global.xml')
>> [Errno 2] No such file or directory: path('geoserver/data/security/
>> filter/geonode-oauth2/config.xml')
>> [Errno 2] No such file or directory: path('geoserver/data/security/role/geonode
>> REST role service/config.xml')
>> Any hint in what is causing these errors will be very appreciated.
>> Thank you very much for your time in advance
>> Kind regards
>> Julierme
>> On Thu, Aug 2, 2018 at 1:27 PM, francesco bartoli <xbartolone at gmail.com>
>> wrote:
>>> Sorry blame myself to made a direct reply in the previous message!
>>> I think probably you have started with too many geonode setups but now
>>> just to figure out this once forever the trick for inheritance is based on
>>> the concept to have geonode (as a library) and geonode-project installed
>>> together in the same virtual environment.
>>> Once you get this then you can replace the geonode references with the
>>> same from the geonode-project.
>>> Hope this helps
>>> Francesco
>>> Il giorno gio 2 ago 2018 alle ore 18:06 Julierme Pinheiro <
>>>> Dear Francesco,
>>>> Sorry, I am just amazed the way GeoNode is built. You all do a
>>>> wonderful work. I used the term bridge because I have to environments
>>>> GeoNode Production and GeoNode-Project, and I have to connect ( please take
>>>> the term "bridge" out of consideration) these two environments through
>>>> Apache2 configuration.
>>>> Just to make sure that I was not doing anything wrong, I installed
>>>> geonode-project at 2.8.0 and geonode-project at 2.6.3.
>>>> I did just one change in site_base.css --> .home .jumbotron {
>>>> background: yellow }
>>>> I ran python manage.py collectstatic
>>>> And Lastly, I did as in <http://geonode.org/dev-workshop/#/8/3>,
>>>> geonode.conf
>>>>  WSGIScriptAlias / /home/sipam_geonode/geonode/geonode/wsgi.py  #
>>>> According to the third line after second "Warning" in
>>>> http://docs.geonode.org/en/master/tutorials/admin/
>>>> customize_lookfeel/customize/setup_admin.html
>>>>      <Directory "/home/sipam_geonode/geonode/geonode/"> # According to
>>>> the fourth bullet point in http://geonode.org/dev-workshop/#/8/3
>>>> #     <Directory "/home/geonode/my_geonode/my_geonode/">
>>>>          <Files wsgi.py>
>>>>              Order deny,allow
>>>>              Allow from all
>>>>              Require all granted
>>>>          </Files>
>>>>         Order allow,deny
>>>>         Options Indexes FollowSymLinks
>>>>         Allow from all
>>>>         IndexOptions FancyIndexing
>>>>     </Directory>
>>>>   <Directory "/home/sipam_geonode/"> # According to the fifth bullet
>>>>         Order allow,deny
>>>>         Allow from all
>>>>         Require all granted
>>>>     </Directory>
>>>> Within this configuration, GeoNode Production goes up and runs, but I
>>>> do not see inheritance.  So, I am not connecting them correctly.
>>>> Again I apologize for the term bridge.
>>>> Thank you very much for your time and help.
>>>> Kind regards
>>>> Julierme
>>>> On Thu, Aug 2, 2018 at 12:17 PM, francesco bartoli <
>>>> xbartolone at gmail.com> wrote:
>>>>> Responses inline.
>>>>> Il giorno gio 2 ago 2018 alle ore 15:22 Julierme Pinheiro <
>>>>>> Dear Francesco,
>>>>>> Thank you very much for your reply and resource suggestion. I am
>>>>>> taking a python course and as soon as I finished it, I will devour the
>>>>>> information in http://www.paolocorti.net/foss4g_2017_geonode_solr/.
>>>>>> <http://www.paolocorti.net/foss4g_2017_geonode_solr/>
>>>>>> Regarding Gdalinfo, I have gdal at 2.2.1 and pygdal at 2.2.1.3
>>>>>> geo at gis:~$ gdal-config --version
>>>>>> 2.2.1
>>>>>> 2.2.1
>>>>>> geo at gis:~$ pip show pygdal
>>>>>> Version: 2.2.1.3
>>>>> According to your command you have pygdal installed systemwide which
>>>>> doesn't mean you have it in each of the virtual environments. So for
>>>>> instance:
>>>>> (sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode$ pip freeze
>>>>> |grep -i gdal
>>>>> should tell you that no entry is listed. This means you have to run
>>>>> "pip install pygdal==2.2.1.3"
>>>>>> Before entering to the resource you sent me, let me just give some
>>>>>> more information about what I am trying to do. I created three virtualenv
>>>>>> for GeoNode-Project named by: my_geonode, geonode_project, and
>>>>>> sipam_geonode. Sorry if I am misunderstanding, but I think I can do that
>>>>>> without mixing the requirements  (requirements.txt) for each GeoNode
>>>>>> vesrion. Also I created three users /home/my_geonode; /home/geonode_project
>>>>>> and /home/sipam_geonode.
>>>>>> (my_geonode) geo at gis: /home/my_geonode/my_geonode  # contains
>>>>>> GeoNode-Project at 2.8.0. installed according to the pdf in attached.
>>>>>> Fine. GeoNode is up and running.
>>>>>> One issue only: I collected the static directory by running python
>>>>>> manage.py collectstatic, but I did not see css changes on the index.html.
>>>>>> site_base.css ---> .home .jumbotron { background: yellow }
>>>>>> (geonode_project) geo at gis: /home/geonode_project/my_geonode  #
>>>>>> contains GeoNode-Project at 2.9.0. installed according to
>>>>>> https://github.com/geosolutions-it/geonode-project
>>>>>> Issue1: paver sync
>>>>>> Response:
>>>>>>  pavement.sync
>>>>>>  python -W ignore manage.py makemigrations --noinput
>>>>>> Traceback (most recent call last):
>>>>>>   File "manage.py", line 31, in <module>
>>>>>>     execute_from_command_line(sys.argv)
>>>>>>   File "/home/geo/Envs/geonode_project/local/lib/python2.7/
>>>>>> site-packages/django/core/management/__init__.py", line 364, in
>>>>>>     utility.execute()
>>>>>> site-packages/django/core/management/__init__.py", line 356, in
>>>>>> execute
>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>> site-packages/django/core/management/base.py", line 283, in
>>>>>> run_from_argv
>>>>>>     self.execute(*args, **cmd_options)
>>>>>> site-packages/django/core/management/base.py", line 327, in execute
>>>>>>     self.check()
>>>>>> site-packages/django/core/management/base.py", line 359, in check
>>>>>>     include_deployment_checks=include_deployment_checks,
>>>>>> site-packages/django/core/management/base.py", line 346, in
>>>>>> _run_checks
>>>>>>     return checks.run_checks(**kwargs)
>>>>>> site-packages/django/core/checks/registry.py", line 81, in run_checks
>>>>>>     new_errors = check(app_configs=app_configs)
>>>>>> site-packages/django/core/checks/urls.py", line 16, in
>>>>>> check_url_config
>>>>>>     return check_resolver(resolver)
>>>>>> site-packages/django/core/checks/urls.py", line 26, in check_resolver
>>>>>>     return check_method()
>>>>>> site-packages/django/urls/resolvers.py", line 254, in check
>>>>>>     for pattern in self.url_patterns:
>>>>>> site-packages/django/utils/functional.py", line 35, in __get__
>>>>>>     res = instance.__dict__[self.name] = self.func(instance)
>>>>>> site-packages/django/urls/resolvers.py", line 405, in url_patterns
>>>>>>     patterns = getattr(self.urlconf_module, "urlpatterns",
>>>>>> self.urlconf_module)
>>>>>> site-packages/django/urls/resolvers.py", line 398, in urlconf_module
>>>>>>     return import_module(self.urlconf_name)
>>>>>>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>>>>>> import_module
>>>>>>     __import__(name)
>>>>>>   File "/home/geonode_project/my_geonode/my_geonode/urls.py", line
>>>>>> 24, in <module>
>>>>>>     from geonode.urls import urlpatterns
>>>>>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/urls.py",
>>>>>> line 89, in <module>
>>>>>>     url(r'^catalogue/', include('geonode.catalogue.urls')),
>>>>>> site-packages/django/conf/urls/__init__.py", line 50, in include
>>>>>>     urlconf_module = import_module(urlconf_module)
>>>>>> import_module
>>>>>>     __import__(name)
>>>>>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/urls.py",
>>>>>> line 22, in <module>
>>>>>>     from . import views
>>>>>>   File "/home/geo/Envs/geonode_project/src/geonode/geonode/catalogue/views.py",
>>>>>> line 29, in <module>
>>>>>>     from pycsw import server
>>>>>> site-packages/pycsw/__init__.py", line 35, in <module>
>>>>>>     __version__ = pkg_resources.require("pycsw")[0].version
>>>>>> site-packages/pkg_resources/__init__.py", line 892, in require
>>>>>>     needed = self.resolve(parse_requirements(requirements))
>>>>>> site-packages/pkg_resources/__init__.py", line 783, in resolve
>>>>>>     raise VersionConflict(dist, req).with_context(dependent_req)
>>>>>> pkg_resources.ContextualVersionConflict: (xmltodict 0.9.2
>>>>>> (/home/geo/Envs/geonode_project/lib/python2.7/site-packages),
>>>>>> Requirement.parse('xmltodict==0.10.2'), set(['pycsw']))
>>>>>> Captured Task Output:
>>>>>> ---> pavement.sync
>>>>>> Build failed running pavement.sync: Subprocess return code: 1
>>>>>> Issue2: paver start
>>>>>> *Note*: The issue seems to be related to xmltodict version. It is
>>>>>> installed xmltodict 0.9.2, but it requires xmltodict 0.10.2. My concern is
>>>>>> to try to upgrade the requirements version and get everything messed up.
>>>>>> (geonode_project) geo at gis:/home/geonode_project/my_geonode$ pip show
>>>>>> xmltodict
>>>>>> Version: 0.9.2
>>>>>> site-packages/django/utils/autoreload.py", line 228, in wrapper
>>>>>>     fn(*args, **kwargs)
>>>>>> site-packages/django/core/management/commands/runserver.py", line
>>>>>> 124, in inner_run
>>>>>>     self.check(display_num_errors=True)
>>>>>> _run_checks
>>>>>> check_url_config
>>>>>> import_module
>>>>>>     __import__(name)
>>>>>> 24, in <module>
>>>>>> import_module
>>>>>>     __import__(name)
>>>>>>     from . import views
>>>>>> GeoNode is now available.
>>>>>> (sipam_geonode) geo at gis: /home/sipam_geonode/my_geonode  # contains
>>>>>> GeoNode-Project at 2.6.x. installed according to http://geonode.org/dev-
>>>>>> workshop/#/2/3
>>>>>> Issues: python manage.py migrate
>>>>>>            python manage.py createsuperuser
>>>>>>            python manage.py shell
>>>>>> Response:
>>>>>>   File "manage.py", line 29, in <module>
>>>>>>   File "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-
>>>>>> packages/django/core/management/__init__.py", line 354, in
>>>>>>     utility.execute()
>>>>>> packages/django/core/management/__init__.py", line 328, in execute
>>>>>>     django.setup()
>>>>>>   File "/home/geo/Envs/sipam_geonode/local/lib/python2.7/site-packages/django/__init__.py",
>>>>>> line 18, in setup
>>>>>>     apps.populate(settings.INSTALLED_APPS)
>>>>>> packages/django/apps/registry.py", line 108, in populate
>>>>>>     app_config.import_models(all_models)
>>>>>> packages/django/apps/config.py", line 198, in import_models
>>>>>>     self.models_module = import_module(models_module_name)
>>>>>> import_module
>>>>>>     __import__(name)
>>>>>>   File "/home/sipam_geonode/geonode/geonode/base/models.py", line
>>>>>> 56, in <module>
>>>>>>     from geonode.utils import bbox_to_wkt
>>>>>>   File "/home/sipam_geonode/geonode/geonode/utils.py", line 30, in
>>>>>> <module>
>>>>>>     from osgeo import ogr
>>>>>> ImportError: No module named osgeo
>>>>>> What I am doing seems to be crazy (;. But I separated my project in
>>>>>> two parts, in one side I have GeoNode Production working fine and on the
>>>>>> other, I need to have GeoNode-project. My goal is to have geonode-project
>>>>>> working fine and make the connection between them. A bridge project started
>>>>>> from its land edges (;
>>>>> Regardless of the version you have chosen and the corresponding
>>>>> virtual environment please note that you definitively don't need the bridge
>>>>> at all.
>>>>> The scope of geonode-project is right to ease the life of a developer
>>>>> and basically everything is already bridged ;).
>>>>> Just to let's figure out if somehow the workshop is gone to make it
>>>>> confusing can you tell us where did you find such information to the need
>>>>> of a bridge?
>>>>> Maybe we can consider to rewrite that part.
>>>>>> Kind regards
>>>>>> Julierme
>>>>>> On Thu, Aug 2, 2018 at 7:51 AM, francesco bartoli <
>>>>>>> Hi Julierme,
>>>>>>> just to give you some quick ways to check what could be wrong.
>>>>>>> Check what GDAL version is installed or it isn't
>>>>>>> $ gdalinfo --version
>>>>>>> Check if the python bindings for GDAL are installed
>>>>>>> (virtual environment)
>>>>>>> $ python manage.py shell
>>>>>>> (geonode installed systemwide)
>>>>>>> $ geonode shell
>>>>>>> then in the interactive python shell
>>>>>>> Remember to make sure to match the GDAL binary version when you
>>>>>>> install the python bindings pygdal as already suggested by Toni.
>>>>>>> A great resource to improve your confidence to programming GeoNode
>>>>>>> with the interactive shell is the workshop from Paolo Corti:
>>>>>>> Il giorno gio 2 ago 2018 alle ore 12:27 Julierme Pinheiro <
>>>>>>>> Hi Toni,
>>>>>>>> Thank you very much for your reply. The problem remains even after
>>>>>>>> your suggested command lines. I will separate a brand new Ubuntu at 16.04LTS
>>>>>>>> machine and see what happens.
>>>>>>>> I appreciated your time and help.
>>>>>>>> Kind regards
>>>>>>>> Julierme
>>>>>>>> 2018-08-02 6:07 GMT-03:00 Toni Schönbuchner <
>>>>>>>> toni.schoenbuchner at csgis.de>:
>>>>>>>>> Hi Julierme,
>>>>>>>>> you´re on ubuntu, right? can you check:
>>>>>>>>> $ sudo apt-get install python-gdal gdal-bin libgdal20 libgdal-dev libgdal-devpython-gdal –y
>>>>>>>>> $ pip install pygdal==2.2.1.3
>>>>>>>>> Cheers,
>>>>>>>>> Toni
>>>>>>>>> CSGIS
>>>>>>>>> Kolonnadenstraße 1
>>>>>>>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>>>>>>>> 04109 Leipzig
>>>>>>>>> Mobil +49/ (0) 176 6680 3198
>>>>>>>>> Tel  +49/ (0) 341 24 04 738
>>>>>>>>> Fax  +49/ (0) 341 24 04 73
>>>>>>>>> Web http://csgis.de
>>>>>>>>> Hinweis gemäß § 33 BDSG
>>>>>>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses
>>>>>>>>> Dokument ist ausschließlich für den
>>>>>>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls
>>>>>>>>> Sie diese E-Mail versehentlich
>>>>>>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an
>>>>>>>>> und löschen Sie diese Nachricht
>>>>>>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>>>>>>> Vervielfältigung, Veränderung,
>>>>>>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>>>>>>> Am 01.08.2018 um 19:12 schrieb geonode-users-request at lists.
>>>>>>>>> osgeo.org:
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180808/95280f6a/attachment-0001.html>
More information about the geonode-users mailing list
