[GeoNode-users] GeoNode migration from 2.4 to 2.8
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Aug 13 04:24:48 PDT 2018
Dear Muhammad,
the old version of GeoNode/GeoServer used an obsolete authentication method
which therefore is no more available on the new GeoServer versions.
The exception you are experiencing are caused, most probably, by some wrong
security/config.xml file on your geoserver data directory.
You should compare the security folder with the one provided with
http://build.geonode.org/geoserver/latest/data-2.13.x.zip
Also you should finalize your GeoNode configuration with OAuth2 by
following the guidelines here
http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html
Also this doc, nevertheless it is a bit outdated, could be useful in order
to make some comparison between old configuration files and new ones
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/index.html#
Il giorno lun 13 ago 2018 alle ore 11:55 Muhammad <mnabiahmad at gmail.com> ha
scritto:
> Hi All
> I am migrating GeoNode 2.4 to 28. For GeoServer data migration, I took
> GeoServer (version 2.7) data folder from GeoNode 2.4 vm and copied it to
> the GeoNode 2.8 vm (GeoServer 2.12.2). Now, when I restart tomcat,
> GeoServer does not start. In catalina.out file I can see an exception
> "GeoNodeAnonymousAuthFilterConfig" but have no idea why this exception is
> being raised
> The file /var/log/tomcat8/catalina.out shown in the following link
> https://bpaste.net/show/be0b362314b7
> Thanks and best regards
> Muhammad
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180813/c79f844a/attachment.html>
More information about the geonode-users mailing list
