[GeoNode-users] problem with geonode catalog app
Aklilu Dinkneh akliludin at gmail.com
Mon Aug 13 14:40:19 PDT 2018
Thank you Paolo,
your suggested solution worked, very helpful!!
On Mon, Aug 13, 2018 at 8:30 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Strange, how did you install GeoNode and which version?
> You should be able to populate metadata standard items with this commands:
> python manage.py loaddata geonode/base/fixtures/initial_data.json
> or (depending on how you installed it):
> geonode loaddata geonode/base/fixtures/initial_data.json
> Hope this helps
> best
> Paolo
> On Mon, Aug 13, 2018 at 12:35 PM Aklilu Dinkneh <akliludin at gmail.com>
> wrote:
> > Dear All,
> > After installing geonode on a linux server i am having a problem with
> Geonode catalog app. Non of the standard metadata templates are available
> for metadata entry. when I check via django admin i see the category or
> region list is empty. can I reload the methada templates via manage.py? or
> how can I fix this?
> > I am using the default pyscw_local catalog csw
> > thank you for your help
> > Best regards
> > Aklilu
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180813/b4794532/attachment.html>
More information about the geonode-users mailing list
