[GeoNode-users] Filtering Layer records for user
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Aug 14 01:16:57 PDT 2018
Hello Javier,
yes, it is possible but not directly through the GeoNode interface
currently.
If you are using the latest GeoServer version available (2.13.x) along with
GeoNode, you can add manually GeoFence [1] [2] rules, either for specific
Users or Groups, by which you can either:
1- limit the allowed area on a Layer
2- add an embedded CQL filter on a Layer
3- decide which attributes should be hidden or shown to the users and,
eventually, which ones must also be read-only or write attributes
[1] - http://docs.geoserver.org/stable/en/user/community/geofence/index.html
[2] -
http://docs.geoserver.org/stable/en/user/community/geofence-server/index.html
Il giorno mer 25 lug 2018 alle ore 19:28 Javier Urien <
javierurien at suremptec.com.ar> ha scritto:
> Hello,
>   I am trying to get some functionality for a customer.
>   What I am trying to accomplish is filter a layer records based on the
> user accessing the data. Is this possible without changing the code?
>   I believe that if i could append an OGC filter to every query on the
> layer it could be resolved. Is this possible? It would also be required
> that this filtering be applied at the server level for security reasons.
> Thanks in Advance
> Best Regards
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180814/5a33e712/attachment.html>
More information about the geonode-users mailing list
