[GeoNode-users] Geonode-Project Inherited by Geonode Production
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Fri Aug 17 09:25:14 PDT 2018
Hi Alessio,
Thank you very much for your reply and  explanation. I can see all your
highlights when, according to [1] / fourth marker bullet, I use the WSGI.py
of geonode-project <WSGIScriptAlias /
/home/geonode/geonode_proj/geonode_proj/wsgi.py>.
I see site_base.css, site_index.html and site_base.html being used.
However, pointing to geonode-project wsgi.py, it will retrieve
geonode-project settings.py. And there is a problem, because I need the
production settings.py.
In the other hand, If I point to geonode production wsgi.py, it will
retrieve production settings.py, and that is what I want. Furthermore, yet,
using production wsgi.py,  I created an Alias to geonode-project
static_root folder in order to have apache2 retrieving  site_base.css
<Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root> and
fine, site_base.css is being inherited, while production wsgi.py is being
used.
The same analogy, pointing to production wsgi.py which retrieves
production's settings.py, I created an Alias to geonode_project
subdirectories in order to get its urls.py and templates and I added the
<Directory>:
    Alias /geonode_proj/ /home/geonode/geonode_proj/geonode_proj/
    Alias /templates/ /home/geonode/geonode_proj/geonode_proj/templates/
    Alias /site_index.html
/home/geonode/geonode_proj/geonode_proj/templates/site_index.html
    Alias /site_base.html
/home/geonode/geonode_proj/geonode_proj/templates/site_base.html
    Alias /geonode_base.html
/home/geonode/geonode_proj/geonode_proj/templates/geonode_base.htm
    Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root/
 <Directory "/home/geonode/geonode_proj/geonode_proj/">
        Order allow,deny
        Options Indexes FollowSymLinks
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/geonode_proj/geonode_proj/templates/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/geonode_proj/geonode_proj/static_root/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
Final Response: Using geonode production wsgi.py, and Alias to
geonode_project/static_root and Alias to geonode_project/templates, geonode
production retrieves site_base.css in geonode_project, but geonode_project
site_index.html, site_base.html and geonode_base.html.
Hypotheses: geonode-production still using its default site_index.html,
Test: I copied geonode-project site_index.html, site_base.html  to
geonode-production's template folder.
Result: geonode-production site changed.
Conclusions: according to the Result, Test and Final Response, I concluded
that using geonode-production's wsgi, and Alias to geonode-project
static_root and templates, geonode-production changes its css, but its
templates (index and base (footer and header)).
What I understood so far:
1 - Geonode Production installed in a virtualenv
2 - Geonode Project installed in the same Geonode Production virtualenv
3 - How to change Production site
3.1 - Edit site_base.css in geonode_project/static
3.2 - Edit site_index.html and site_base.html in geonode_project/templates
3.3 - Collect the files through python manage.py collectstatic
4 - Edit geonode.conf # http://geonode.org/dev-workshop/#/8/3
4.1 .Fourth bullet in # http://geonode.org/dev-workshop/#/8/3.  - edit
/etc/apache2/sites-enabled/geonode.conf replacing the wsgi path to the
my_geonode/my_geonode/wsgi.py
In here, says to point to geonode-project wsgi.py, but doing that,
production settings.py is out of the flow, if I am not wrong. Though I see
all the changes done through site_base.css, site_index.html, site_base.html.
4.2. Fifth bullet  in # http://geonode.org/dev-workshop/#/8/3 -
<Directory "/path/to/my_geonode/">
     Order allow,deny
     Require all granted
</Directory>
I did all that except, I am pointing to geonode production wsgi.py in order
to use production settings.py. Besides the Alias created to geonode-project
to have its static_root and templates. CSS is being retrieved, but
site_index.html and site_base.html.
Thank you very much for your time and patience.
Kind regards
Julierme
[1] http://geonode.org/dev-workshop/#/8/3
On Fri, Aug 17, 2018 at 5:32 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hello Julierme,
> I'm going to start providing to you some pointers on how geonode-project
> Django template overrides GeoNode core ones.
> 1. The main URL entry "site_index.html"
> This is the very first thing to consider. geonode-project overrides the
> default GeoNode main index through the "urls.py" file. Instead of using the
> default GeoNode one, it says to Django to use its own defined here
> https://github.com/geosolutions-it/geonode-project/blob/master/project_
> name/templates/site_index.html
> 2. "site_index.html"
> This one inherits from GeoNode "index.html"
> see https://github.com/geosolutions-it/geonode-
> project/blob/master/project_name/templates/site_index.html#L1
> Nevertheless geonode-project also overrides the "geonode_base.html" (see
> name/templates/geonode_base.html ) which inherits the local
> "site_base.html" (see https://github.com/geosolutions-it/geonode-
> project/blob/master/project_name/templates/site_base.html )
> 3. "site_base.html"
> The geonode-project "site_base.html" inherits the GeoNode "base.html"
> Il giorno gio 16 ago 2018 alle ore 22:09 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear users and contributors,
>> I am still trying to figure out the way Apache2/geonode.conf is
>> configured in order to have geonode production inheriting the changes in
>> geonode-project, mainly ./geonode_proj/static_root/css/site_base.css and
>> ./geonode_proj/templates/site_index.html and site_base.html.
>> Based on [1]  I added the following lines to  the geonode.conf which
>> default configuration is found in [2]:
>>     Alias /site_index.html /home/geonode/geonode_proj/
>>     Alias /site_base.html /home/geonode/geonode_proj/
>> ############################### New Configuration for site inheritance
>>     <Directory "/home/geonode/geonode_proj/">
>>         Order allow,deny
>>         Allow from all
>>         Require all granted
>>     </Directory>
>>         Order allow,deny
>>         Allow from all
>>         Require all granted
>>     </Directory>
>>         Order allow,deny
>>         Allow from all
>>         Require all granted
>>     </Directory>
>>          <Files wsgi.py>
>>              Order deny,allow
>>              Allow from all
>>              Require all granted
>>          </Files>
>>         Order allow,deny
>>         Allow from all
>>         IndexOptions FancyIndexing
>>     </Directory>
>> ###########################################3
>> Within this configuration, geonode production is inheriting the
>> site_base.css in ./geonode-proj/static_root/css/, but site_index.html
>> and site_base.html.
>> I also have to mention that WSGI being used is production WSGIScriptAlias
>> / /home/geonode/my_geonode/my_geonode/wsgi.py.
>> My first guest is: although I have created all the Alias path (including
>> the templates directory) as showed above, Apache2 still looking for the
>> site_index.html and site_base.html in the production folder
>> /home/geonode/my_geonode/my_geonode/templates/.
>> One thing I can not understand is: I created the Alias for
>> geonode-project static_root and Apache is doing exactly what I want:
>> getting the site_base.css. But why is not doing for the geonode_project
>> templates.
>> To test my first guest, I copied site_index.html and site_base.html to
>> production path /home/geonode/my_geonode/my_geonode/templates and the
>> response was a request to site_base.html, but site_index.html.
>> Lastly, I have to say that I have production and geonode-project in the
>> same virtualenv.
>> I am very confused. Could someone give me a hint on that please? And my
>> apologies for bringing this topic to discussion again.
>> Thank you for your time in advance
>> Kind regards
>> Julierme
>> [1] https://docs.djangoproject.com/en/2.1/howto/deployment/wsgi/modwsgi/
>> [2] http://docs.geonode.org/en/master/tutorials/install_and_
>> admin/geonode_install/setup_configure_httpd.html
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A -
> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>  Massarosa
> (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180817/2546c724/attachment-0001.html>
More information about the geonode-users mailing list
