[GeoNode-users] Geonode-Project Inherited by Geonode Production
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Aug 20 02:44:28 PDT 2018
Hi Julierme,
few clarifications on how settings work. It might be useful for your use
case.
1. geonode-project settings
Settings are taken from wsgi.py mostly, pointed from your HTTPD
configuration file.
geonode-project by default tries to use it's own settings which inherits
(by default) from geonode.settings
see here
https://github.com/geosolutions-it/geonode-project/blob/master/project_name/wsgi.py#L38
this line will be converted into
os.environ.setdefault("DJANGO_SETTINGS_MODULE",
"your_custom_project.settings")
One solution to make it use directly the geonode settings (or other ones)
would be to just change this line. As an instance if you have a
"produtcion_settings.py" on geonode, you could write something like
"geonode.production_settings")
Or if you have your local_settings.py on GeoNode and you want to use that
ones you can write
os.environ.setdefault("DJANGO_SETTINGS_MODULE", "geonode.local_settings")
2. Django settings inheritance
In Django settings module can inherits from other ones. This is possible
through the "import" directive.
As an instance, typically, "local_settings" inherits from "settings" in
order to override some of the original properties. Nevertheless there exist
different policies around.
Currently geonode_project does:
a) If *no *geonode_project/local_settings.py exists, it inherits from
geonode/settings.py directly
https://github.com/geosolutions-it/geonode-project/blob/master/project_name/settings.py#L26
b) If geonode_project/local_settings.py exists, it inherits from those ones
https://github.com/geosolutions-it/geonode-project/blob/master/project_name/settings.py#L27
and local_settings.py (at least the sample ones, no need to use those ones)
inherits from geonode/settings.py
https://github.com/geosolutions-it/geonode-project/blob/master/project_name/local_settings.py.sample#L24
Hope this helps.
Il giorno ven 17 ago 2018 alle ore 18:25 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Hi Alessio,
> Thank you very much for your reply and  explanation. I can see all your
> highlights when, according to [1] / fourth marker bullet, I use the WSGI.py
> of geonode-project <WSGIScriptAlias /
> /home/geonode/geonode_proj/geonode_proj/wsgi.py>. I see site_base.css,
> site_index.html and site_base.html being used. However, pointing to
> geonode-project wsgi.py, it will retrieve geonode-project settings.py. And
> there is a problem, because I need the production settings.py.
> In the other hand, If I point to geonode production wsgi.py, it will
> retrieve production settings.py, and that is what I want. Furthermore, yet,
> using production wsgi.py,  I created an Alias to geonode-project
> static_root folder in order to have apache2 retrieving  site_base.css
> <Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root> and
> fine, site_base.css is being inherited, while production wsgi.py is being
> used.
> The same analogy, pointing to production wsgi.py which retrieves
> production's settings.py, I created an Alias to geonode_project
> subdirectories in order to get its urls.py and templates and I added the
> <Directory>:
>     Alias /geonode_proj/ /home/geonode/geonode_proj/geonode_proj/
>     Alias /templates/ /home/geonode/geonode_proj/geonode_proj/templates/
>     Alias /site_index.html
> /home/geonode/geonode_proj/geonode_proj/templates/site_index.html
>     Alias /site_base.html
> /home/geonode/geonode_proj/geonode_proj/templates/site_base.html
>     Alias /geonode_base.html
> /home/geonode/geonode_proj/geonode_proj/templates/geonode_base.htm
>     Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root/
>  <Directory "/home/geonode/geonode_proj/geonode_proj/">
>         Order allow,deny
>         Options Indexes FollowSymLinks
>         Allow from all
>         Require all granted
>     </Directory>
>     <Directory "/home/geonode/geonode_proj/geonode_proj/templates/">
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
>     <Directory "/home/geonode/geonode_proj/geonode_proj/static_root/">
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
> Final Response: Using geonode production wsgi.py, and Alias to
> geonode_project/static_root and Alias to geonode_project/templates, geonode
> production retrieves site_base.css in geonode_project, but geonode_project
> site_index.html, site_base.html and geonode_base.html.
> Hypotheses: geonode-production still using its default site_index.html,
> Test: I copied geonode-project site_index.html, site_base.html  to
> geonode-production's template folder.
> Result: geonode-production site changed.
> Conclusions: according to the Result, Test and Final Response, I concluded
> that using geonode-production's wsgi, and Alias to geonode-project
> static_root and templates, geonode-production changes its css, but its
> templates (index and base (footer and header)).
> What I understood so far:
> 1 - Geonode Production installed in a virtualenv
> 2 - Geonode Project installed in the same Geonode Production virtualenv
> 3 - How to change Production site
> 3.1 - Edit site_base.css in geonode_project/static
> 3.2 - Edit site_index.html and site_base.html in geonode_project/templates
> 3.3 - Collect the files through python manage.py collectstatic
> 4 - Edit geonode.conf # http://geonode.org/dev-workshop/#/8/3
> 4.1 .Fourth bullet in # http://geonode.org/dev-workshop/#/8/3.  - edit
> /etc/apache2/sites-enabled/geonode.conf replacing the wsgi path to the
> my_geonode/my_geonode/wsgi.py
> In here, says to point to geonode-project wsgi.py, but doing that,
> production settings.py is out of the flow, if I am not wrong. Though I see
> all the changes done through site_base.css, site_index.html, site_base.html.
> 4.2. Fifth bullet  in # http://geonode.org/dev-workshop/#/8/3 -
> <Directory "/path/to/my_geonode/">
>      Order allow,deny
>      Require all granted
> </Directory>
> I did all that except, I am pointing to geonode production wsgi.py in
> order to use production settings.py. Besides the Alias created to
> geonode-project to have its static_root and templates. CSS is being
> retrieved, but site_index.html and site_base.html.
> Thank you very much for your time and patience.
> Kind regards
> Julierme
> [1] http://geonode.org/dev-workshop/#/8/3
> On Fri, Aug 17, 2018 at 5:32 AM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hello Julierme,
>> I'm going to start providing to you some pointers on how geonode-project
>> Django template overrides GeoNode core ones.
>> 1. The main URL entry "site_index.html"
>> This is the very first thing to consider. geonode-project overrides the
>> default GeoNode main index through the "urls.py" file. Instead of using the
>> default GeoNode one, it says to Django to use its own defined here
>> https://github.com/geosolutions-it/geonode-project/blob/master/project_name/templates/site_index.html
>> 2. "site_index.html"
>> This one inherits from GeoNode "index.html"
>> see
>> https://github.com/geosolutions-it/geonode-project/blob/master/project_name/templates/site_index.html#L1
>> Nevertheless geonode-project also overrides the "geonode_base.html" (see
>> https://github.com/geosolutions-it/geonode-project/blob/master/project_name/templates/geonode_base.html
>> ) which inherits the local "site_base.html" (see
>> https://github.com/geosolutions-it/geonode-project/blob/master/project_name/templates/site_base.html
>> 3. "site_base.html"
>> The geonode-project "site_base.html" inherits the GeoNode "base.html"
>> Il giorno gio 16 ago 2018 alle ore 22:09 Julierme Pinheiro <
>>> Dear users and contributors,
>>> I am still trying to figure out the way Apache2/geonode.conf is
>>> configured in order to have geonode production inheriting the changes in
>>> geonode-project, mainly ./geonode_proj/static_root/css/site_base.css and
>>> ./geonode_proj/templates/site_index.html and site_base.html.
>>> Based on [1]  I added the following lines to  the geonode.conf which
>>> default configuration is found in [2]:
>>> ############################### New Configuration for site inheritance
>>>     <Directory "/home/geonode/geonode_proj/">
>>>         Order allow,deny
>>>         Allow from all
>>>         Require all granted
>>>     </Directory>
>>>         Order allow,deny
>>>         Allow from all
>>>         Require all granted
>>>     </Directory>
>>>         Order allow,deny
>>>         Allow from all
>>>         Require all granted
>>>     </Directory>
>>>          <Files wsgi.py>
>>>              Order deny,allow
>>>              Allow from all
>>>              Require all granted
>>>          </Files>
>>>         Order allow,deny
>>>         Allow from all
>>>         IndexOptions FancyIndexing
>>>     </Directory>
>>> #######################################################################################################3
>>> Within this configuration, geonode production is inheriting the
>>> site_base.css in ./geonode-proj/static_root/css/, but site_index.html and
>>> site_base.html.
>>> I also have to mention that WSGI being used is production
>>> WSGIScriptAlias / /home/geonode/my_geonode/my_geonode/wsgi.py.
>>> My first guest is: although I have created all the Alias path (including
>>> the templates directory) as showed above, Apache2 still looking for the
>>> site_index.html and site_base.html in the production folder
>>> /home/geonode/my_geonode/my_geonode/templates/.
>>> One thing I can not understand is: I created the Alias for
>>> geonode-project static_root and Apache is doing exactly what I want:
>>> getting the site_base.css. But why is not doing for the geonode_project
>>> templates.
>>> To test my first guest, I copied site_index.html and site_base.html to
>>> production path /home/geonode/my_geonode/my_geonode/templates and the
>>> response was a request to site_base.html, but site_index.html.
>>> Lastly, I have to say that I have production and geonode-project in the
>>> same virtualenv.
>>> I am very confused. Could someone give me a hint on that please? And my
>>> apologies for bringing this topic to discussion again.
>>> Thank you for your time in advance
>>> Kind regards
>>> Julierme
>>> [1] https://docs.djangoproject.com/en/2.1/howto/deployment/wsgi/modwsgi/
>>> [2]
>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A -
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>>  Massarosa
>> (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180820/899922e9/attachment-0001.html>
More information about the geonode-users mailing list
