[GeoNode-users] Geonode-Project Inherited by Geonode Production
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Mon Aug 20 12:57:01 PDT 2018
Hi Alessio,
Thank you very much for reply. I went through all your highlights. I have
site_base.css, site_index.html and site_base.html being displayed.
I am still confused with one thing:
I have geonode production in /home/geonode/my_geonode/* (virtualenv
geonode)
I have geonode project in /home/geonode/geonode_proj/* (virtualenv geonode)
I set geonode.conf as follow:
WSGIScriptAlias / /home/geonode/geonode_proj/geonode_proj/wsgi.py
(geonode-project wsgi.py)
Alias /uploaded/ /home/geonode/geonode_proj/geonode_proj/uploaded/
Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root/
I have Accounts, Emails, SITEURL and ALLOWED_HOSTS set in geonode
production and geonode_proj settings.py
Within this entire configuration I got geonode set the way I want, but it
seems that geonode production is out of context/ out of the flow. Is not
it? As you can see above I have hot used geonode production path in
anywhere.
Yet, related to your highlights, if I change geonode project wsgi.py, in a
way that it retrieves the geonode production wsgi.py and geonode's site
display its default configuration, templates, but css which is retrieved
from geonode project.
Also, if I change geonode production wsgi.py to retrieve its
local_settings.py, apache won't start.
I have geonode production at 2.8.0 (settings and local_settings) configured as
in [1].
These are the scenarios:
Scenario 1
1 - geonode production and geonode project installed in the same virtualenv
1.1 geonode production installed as in [1]
1.2 geonode.conf configuration
1.3 geonode project settings.py
geonode project settings.py got the same SITEURL, ALLOWED_HOSTS, ACCOUNTS
and EMAILS configuration as in geonode production
This is the closest I can get to what it is stated in [2].
1.4 Response:
1.4.1 I can have accounts being set and uploading layers, and everything
taking place in geonode project path.
1.4.2 - Geonode production retrieves site_base.css in geonode_project path
1.4.3 - Geonode production retrieves the templates (site_index.html and
site_base.html) folder in geonode project.
Scenario 2:
2 - geonode production and geonode project installed in the same virtualenv
2.1 geonode production installed as in [1]
2.2 geonode.conf configuration
WSGIScriptAlias / /home/geonode/my_geonode/my_geonode/wsgi.py
(geonode-production wsgi.py)
Alias /templates/ /home/geonode/geonode_proj/geonode_proj/uploaded/
2.3 Responses:
2.3.1 - I can have accounts being set and uploading layers, and everything
taking place in geonode production path, except the static_root coming from
geonode_project
2.3.2 - Geonode production retrieves site_base.css in geonode_project path
2.3.3 - Geonode production won't retrieve the templates folder in geonode
project, though I set apache2 to do so.
Scenario 3:
Changing geonode project wsgi.py, in a way that it retrieves the geonode
production wsgi.py and keeping the configuration in Scenario 1, geonode's
site display its default configuration, templates. But it retrieves the css
in geonode project.
Scenario 4:
Keeping the configuration in Scenario 2 and changing production wsgi.py to
retrieve production local_settings.py instead of settings.py, apache2 won't
start.
Thank you very much for your time, help and patience.
I appreciated it
Julierme
[1]
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
[2] http://geonode.org/dev-workshop/#/8/3
On Mon, Aug 20, 2018 at 6:44 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Julierme,
> few clarifications on how settings work. It might be useful for your use
> case.
> 1. geonode-project settings
> Settings are taken from wsgi.py mostly, pointed from your HTTPD
> configuration file.
> geonode-project by default tries to use it's own settings which inherits
> (by default) from geonode.settings
> see here
> https://github.com/geosolutions-it/geonode-project/blob/master/project_
> name/wsgi.py#L38
> this line will be converted into
> os.environ.setdefault("DJANGO_SETTINGS_MODULE",
> "your_custom_project.settings")
> One solution to make it use directly the geonode settings (or other ones)
> would be to just change this line. As an instance if you have a
> "produtcion_settings.py" on geonode, you could write something like
> "geonode.production_settings")
> Or if you have your local_settings.py on GeoNode and you want to use that
> ones you can write
> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "geonode.local_settings")
> 2. Django settings inheritance
> In Django settings module can inherits from other ones. This is possible
> through the "import" directive.
> As an instance, typically, "local_settings" inherits from "settings" in
> order to override some of the original properties. Nevertheless there exist
> different policies around.
> Currently geonode_project does:
> a) If *no *geonode_project/local_settings.py exists, it inherits from
> geonode/settings.py directly
> name/settings.py#L26
> b) If geonode_project/local_settings.py exists, it inherits from those
> ones
> name/settings.py#L27
> and local_settings.py (at least the sample ones, no need to use those
> ones) inherits from geonode/settings.py
> name/local_settings.py.sample#L24
> Hope this helps.
> Il giorno ven 17 ago 2018 alle ore 18:25 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi Alessio,
>> Thank you very much for your reply and explanation. I can see all your
>> highlights when, according to [1] / fourth marker bullet, I use the WSGI.py
>> of geonode-project <WSGIScriptAlias / /home/geonode/geonode_proj/geonode_proj/wsgi.py>.
>> I see site_base.css, site_index.html and site_base.html being used.
>> However, pointing to geonode-project wsgi.py, it will retrieve
>> geonode-project settings.py. And there is a problem, because I need the
>> production settings.py.
>> In the other hand, If I point to geonode production wsgi.py, it will
>> retrieve production settings.py, and that is what I want. Furthermore, yet,
>> using production wsgi.py, I created an Alias to geonode-project
>> static_root folder in order to have apache2 retrieving site_base.css
>> <Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root> and
>> fine, site_base.css is being inherited, while production wsgi.py is being
>> used.
>> The same analogy, pointing to production wsgi.py which retrieves
>> production's settings.py, I created an Alias to geonode_project
>> subdirectories in order to get its urls.py and templates and I added the
>> <Directory>:
>> Alias /geonode_proj/ /home/geonode/geonode_proj/geonode_proj/
>> Alias /templates/ /home/geonode/geonode_proj/geonode_proj/templates/
>> Alias /site_index.html /home/geonode/geonode_proj/
>> geonode_proj/templates/site_index.html
>> Alias /site_base.html /home/geonode/geonode_proj/
>> geonode_proj/templates/site_base.html
>> Alias /geonode_base.html /home/geonode/geonode_proj/
>> geonode_proj/templates/geonode_base.htm
>> <Directory "/home/geonode/geonode_proj/geonode_proj/">
>> Order allow,deny
>> Options Indexes FollowSymLinks
>> Allow from all
>> Require all granted
>> </Directory>
>> <Directory "/home/geonode/geonode_proj/geonode_proj/templates/">
>> Order allow,deny
>> Allow from all
>> Require all granted
>> </Directory>
>> <Directory "/home/geonode/geonode_proj/geonode_proj/static_root/">
>> Order allow,deny
>> Allow from all
>> Require all granted
>> </Directory>
>> Final Response: Using geonode production wsgi.py, and Alias to
>> geonode_project/static_root and Alias to geonode_project/templates, geonode
>> production retrieves site_base.css in geonode_project, but geonode_project
>> site_index.html, site_base.html and geonode_base.html.
>> Hypotheses: geonode-production still using its default site_index.html,
>> Test: I copied geonode-project site_index.html, site_base.html to
>> geonode-production's template folder.
>> Result: geonode-production site changed.
>> Conclusions: according to the Result, Test and Final Response, I
>> concluded that using geonode-production's wsgi, and Alias to
>> geonode-project static_root and templates, geonode-production changes its
>> css, but its templates (index and base (footer and header)).
>> What I understood so far:
>> 1 - Geonode Production installed in a virtualenv
>> 2 - Geonode Project installed in the same Geonode Production virtualenv
>> 3 - How to change Production site
>> 3.1 - Edit site_base.css in geonode_project/static
>> 3.2 - Edit site_index.html and site_base.html in geonode_project/templates
>> 3.3 - Collect the files through python manage.py collectstatic
>> 4 - Edit geonode.conf # http://geonode.org/dev-workshop/#/8/3
>> 4.1 .Fourth bullet in # http://geonode.org/dev-workshop/#/8/3. - edit
>> /etc/apache2/sites-enabled/geonode.conf replacing the wsgi path to the
>> In here, says to point to geonode-project wsgi.py, but doing that,
>> production settings.py is out of the flow, if I am not wrong. Though I see
>> all the changes done through site_base.css, site_index.html, site_base.html.
>> 4.2. Fifth bullet in # http://geonode.org/dev-workshop/#/8/3 -
>> <Directory "/path/to/my_geonode/">
>> Order allow,deny
>> Require all granted
>> </Directory>
>> I did all that except, I am pointing to geonode production wsgi.py in
>> order to use production settings.py. Besides the Alias created to
>> geonode-project to have its static_root and templates. CSS is being
>> retrieved, but site_index.html and site_base.html.
>> Thank you very much for your time and patience.
>> Kind regards
>> Julierme
>> [1] http://geonode.org/dev-workshop/#/8/3
>> On Fri, Aug 17, 2018 at 5:32 AM, Alessio Fabiani <alessio.fabiani at geo-
>>> Hello Julierme,
>>> I'm going to start providing to you some pointers on how geonode-project
>>> Django template overrides GeoNode core ones.
>>> 1. The main URL entry "site_index.html"
>>> This is the very first thing to consider. geonode-project overrides the
>>> default GeoNode main index through the "urls.py" file. Instead of using the
>>> default GeoNode one, it says to Django to use its own defined here
>>> name/templates/site_index.html
>>> 2. "site_index.html"
>>> This one inherits from GeoNode "index.html"
>>> see https://github.com/geosolutions-it/geonode-
>>> project/blob/master/project_name/templates/site_index.html#L1
>>> Nevertheless geonode-project also overrides the "geonode_base.html" (see
>>> name/templates/geonode_base.html ) which inherits the local
>>> "site_base.html" (see https://github.com/geosolutions-it/geonode-
>>> project/blob/master/project_name/templates/site_base.html )
>>> 3. "site_base.html"
>>> The geonode-project "site_base.html" inherits the GeoNode "base.html"
>>> Il giorno gio 16 ago 2018 alle ore 22:09 Julierme Pinheiro <
>>>> Dear users and contributors,
>>>> I am still trying to figure out the way Apache2/geonode.conf is
>>>> configured in order to have geonode production inheriting the changes in
>>>> geonode-project, mainly ./geonode_proj/static_root/css/site_base.css
>>>> and ./geonode_proj/templates/site_index.html and site_base.html.
>>>> Based on [1] I added the following lines to the geonode.conf which
>>>> default configuration is found in [2]:
>>>> ############################### New Configuration for site inheritance
>>>> <Directory "/home/geonode/geonode_proj/">
>>>> Order allow,deny
>>>> Allow from all
>>>> Require all granted
>>>> </Directory>
>>>> Order allow,deny
>>>> Allow from all
>>>> Require all granted
>>>> </Directory>
>>>> Order allow,deny
>>>> Allow from all
>>>> Require all granted
>>>> </Directory>
>>>> <Files wsgi.py>
>>>> Order deny,allow
>>>> Allow from all
>>>> Require all granted
>>>> </Files>
>>>> Order allow,deny
>>>> Allow from all
>>>> IndexOptions FancyIndexing
>>>> </Directory>
>>>> ###########################################3
>>>> Within this configuration, geonode production is inheriting the
>>>> site_base.css in ./geonode-proj/static_root/css/, but site_index.html
>>>> and site_base.html.
>>>> I also have to mention that WSGI being used is production
>>>> WSGIScriptAlias / /home/geonode/my_geonode/my_geonode/wsgi.py.
>>>> My first guest is: although I have created all the Alias path
>>>> (including the templates directory) as showed above, Apache2 still looking
>>>> for the site_index.html and site_base.html in the production folder
>>>> /home/geonode/my_geonode/my_geonode/templates/.
>>>> One thing I can not understand is: I created the Alias for
>>>> geonode-project static_root and Apache is doing exactly what I want:
>>>> getting the site_base.css. But why is not doing for the geonode_project
>>>> templates.
>>>> To test my first guest, I copied site_index.html and site_base.html to
>>>> production path /home/geonode/my_geonode/my_geonode/templates and the
>>>> response was a request to site_base.html, but site_index.html.
>>>> Lastly, I have to say that I have production and geonode-project in the
>>>> same virtualenv.
>>>> I am very confused. Could someone give me a hint on that please? And my
>>>> apologies for bringing this topic to discussion again.
>>>> Thank you for your time in advance
>>>> Kind regards
>>>> Julierme
>>>> [1] https://docs.djangoproject.com/en/2.1/howto/deployment/
>>>> wsgi/modwsgi/
>>>> [2] http://docs.geonode.org/en/master/tutorials/install_and_
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A -
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>>> Massarosa
>>> (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Massarosa
> (LU) - Italy
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180820/eed22beb/attachment-0001.html>
More information about the geonode-users
