[GeoNode-users] Geonode-Project Inherited by Geonode Production
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Mon Aug 20 14:10:07 PDT 2018
HI Alessio,
Please, where it says Alias /uploaded/
/home/geonode/geonode_proj/geonode_proj/uploaded/
in all scenarios change to:
Alias /templates/ /home/geonode/geonode_proj/geonode_proj/templates/
Kind regards
Julierme
On Mon, Aug 20, 2018 at 4:57 PM, Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Alessio,
> Thank you very much for reply. I went through all your highlights. I have
> site_base.css, site_index.html and site_base.html being displayed.
> I am still confused with one thing:
> I have geonode production in /home/geonode/my_geonode/* (virtualenv
> geonode)
> I have geonode project in /home/geonode/geonode_proj/* (virtualenv geonode)
> I set geonode.conf as follow:
> WSGIScriptAlias / /home/geonode/geonode_proj/geonode_proj/wsgi.py
> (geonode-project wsgi.py)
> Alias /uploaded/ /home/geonode/geonode_proj/geonode_proj/uploaded/
> Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root/
> I have Accounts, Emails, SITEURL and ALLOWED_HOSTS set in geonode
> production and geonode_proj settings.py
> Within this entire configuration I got geonode set the way I want, but it
> seems that geonode production is out of context/ out of the flow. Is not
> it? As you can see above I have hot used geonode production path in
> anywhere.
> Yet, related to your highlights, if I change geonode project wsgi.py, in a
> way that it retrieves the geonode production wsgi.py and geonode's site
> display its default configuration, templates, but css which is retrieved
> from geonode project.
> Also, if I change geonode production wsgi.py to retrieve its
> local_settings.py, apache won't start.
> I have geonode production at 2.8.0 (settings and local_settings) configured
> as in [1].
> These are the scenarios:
> Scenario 1
> 1 - geonode production and geonode project installed in the same virtualenv
> 1.1 geonode production installed as in [1]
> 1.2 geonode.conf configuration
> 1.3 geonode project settings.py
> geonode project settings.py got the same SITEURL, ALLOWED_HOSTS, ACCOUNTS
> and EMAILS configuration as in geonode production
> This is the closest I can get to what it is stated in [2].
> 1.4 Response:
> 1.4.1 I can have accounts being set and uploading layers, and everything
> taking place in geonode project path.
> 1.4.2 - Geonode production retrieves site_base.css in geonode_project path
> 1.4.3 - Geonode production retrieves the templates (site_index.html and
> site_base.html) folder in geonode project.
> Scenario 2:
> 2 - geonode production and geonode project installed in the same virtualenv
> 2.1 geonode production installed as in [1]
> 2.2 geonode.conf configuration
> WSGIScriptAlias / /home/geonode/my_geonode/my_geonode/wsgi.py
> (geonode-production wsgi.py)
> Alias /templates/ /home/geonode/geonode_proj/geonode_proj/uploaded/
> 2.3 Responses:
> 2.3.1 - I can have accounts being set and uploading layers, and everything
> taking place in geonode production path, except the static_root coming from
> geonode_project
> 2.3.2 - Geonode production retrieves site_base.css in geonode_project path
> 2.3.3 - Geonode production won't retrieve the templates folder in geonode
> project, though I set apache2 to do so.
> Scenario 3:
> Changing geonode project wsgi.py, in a way that it retrieves the geonode
> production wsgi.py and keeping the configuration in Scenario 1, geonode's
> site display its default configuration, templates. But it retrieves the css
> in geonode project.
> Scenario 4:
> Keeping the configuration in Scenario 2 and changing production wsgi.py to
> retrieve production local_settings.py instead of settings.py, apache2 won't
> start.
> Thank you very much for your time, help and patience.
> I appreciated it
> Julierme
> [1] http://docs.geonode.org/en/master/tutorials/install_and_
> admin/geonode_install/setup_configure_httpd.html
> [2] http://geonode.org/dev-workshop/#/8/3
> On Mon, Aug 20, 2018 at 6:44 AM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Hi Julierme,
>> few clarifications on how settings work. It might be useful for your use
>> case.
>> 1. geonode-project settings
>> Settings are taken from wsgi.py mostly, pointed from your HTTPD
>> configuration file.
>> geonode-project by default tries to use it's own settings which inherits
>> (by default) from geonode.settings
>> see here
>> https://github.com/geosolutions-it/geonode-project/blob/
>> master/project_name/wsgi.py#L38
>> this line will be converted into
>> os.environ.setdefault("DJANGO_SETTINGS_MODULE",
>> "your_custom_project.settings")
>> One solution to make it use directly the geonode settings (or other ones)
>> would be to just change this line. As an instance if you have a
>> "produtcion_settings.py" on geonode, you could write something like
>> "geonode.production_settings")
>> Or if you have your local_settings.py on GeoNode and you want to use that
>> ones you can write
>> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "geonode.local_settings")
>> 2. Django settings inheritance
>> In Django settings module can inherits from other ones. This is possible
>> through the "import" directive.
>> As an instance, typically, "local_settings" inherits from "settings" in
>> order to override some of the original properties. Nevertheless there exist
>> different policies around.
>> Currently geonode_project does:
>> a) If *no *geonode_project/local_settings.py exists, it inherits from
>> geonode/settings.py directly
>> master/project_name/settings.py#L26
>> b) If geonode_project/local_settings.py exists, it inherits from those
>> ones
>> master/project_name/settings.py#L27
>> and local_settings.py (at least the sample ones, no need to use those
>> ones) inherits from geonode/settings.py
>> master/project_name/local_settings.py.sample#L24
>> Hope this helps.
>> Il giorno ven 17 ago 2018 alle ore 18:25 Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>> Hi Alessio,
>>> Thank you very much for your reply and explanation. I can see all your
>>> highlights when, according to [1] / fourth marker bullet, I use the WSGI.py
>>> of geonode-project <WSGIScriptAlias / /home/geonode/geonode_proj/geonode_proj/wsgi.py>.
>>> I see site_base.css, site_index.html and site_base.html being used.
>>> However, pointing to geonode-project wsgi.py, it will retrieve
>>> geonode-project settings.py. And there is a problem, because I need the
>>> production settings.py.
>>> In the other hand, If I point to geonode production wsgi.py, it will
>>> retrieve production settings.py, and that is what I want. Furthermore, yet,
>>> using production wsgi.py, I created an Alias to geonode-project
>>> static_root folder in order to have apache2 retrieving site_base.css
>>> <Alias /static/ /home/geonode/geonode_proj/geonode_proj/static_root>
>>> and fine, site_base.css is being inherited, while production wsgi.py is
>>> being used.
>>> The same analogy, pointing to production wsgi.py which retrieves
>>> production's settings.py, I created an Alias to geonode_project
>>> subdirectories in order to get its urls.py and templates and I added the
>>> <Directory>:
>>> Alias /geonode_proj/ /home/geonode/geonode_proj/geonode_proj/
>>> Alias /site_index.html /home/geonode/geonode_proj/geo
>>> node_proj/templates/site_index.html
>>> Alias /site_base.html /home/geonode/geonode_proj/geo
>>> node_proj/templates/site_base.html
>>> Alias /geonode_base.html /home/geonode/geonode_proj/geo
>>> node_proj/templates/geonode_base.htm
>>> <Directory "/home/geonode/geonode_proj/geonode_proj/">
>>> Order allow,deny
>>> Options Indexes FollowSymLinks
>>> Allow from all
>>> Require all granted
>>> </Directory>
>>> <Directory "/home/geonode/geonode_proj/geonode_proj/templates/">
>>> Order allow,deny
>>> Allow from all
>>> Require all granted
>>> </Directory>
>>> <Directory "/home/geonode/geonode_proj/geonode_proj/static_root/">
>>> Order allow,deny
>>> Allow from all
>>> Require all granted
>>> </Directory>
>>> Final Response: Using geonode production wsgi.py, and Alias to
>>> geonode_project/static_root and Alias to geonode_project/templates, geonode
>>> production retrieves site_base.css in geonode_project, but geonode_project
>>> site_index.html, site_base.html and geonode_base.html.
>>> Hypotheses: geonode-production still using its default site_index.html,
>>> Test: I copied geonode-project site_index.html, site_base.html to
>>> geonode-production's template folder.
>>> Result: geonode-production site changed.
>>> Conclusions: according to the Result, Test and Final Response, I
>>> concluded that using geonode-production's wsgi, and Alias to
>>> geonode-project static_root and templates, geonode-production changes its
>>> css, but its templates (index and base (footer and header)).
>>> What I understood so far:
>>> 1 - Geonode Production installed in a virtualenv
>>> 2 - Geonode Project installed in the same Geonode Production virtualenv
>>> 3 - How to change Production site
>>> 3.1 - Edit site_base.css in geonode_project/static
>>> 3.2 - Edit site_index.html and site_base.html in
>>> 3.3 - Collect the files through python manage.py collectstatic
>>> 4 - Edit geonode.conf # http://geonode.org/dev-workshop/#/8/3
>>> 4.1 .Fourth bullet in # http://geonode.org/dev-workshop/#/8/3. - edit
>>> /etc/apache2/sites-enabled/geonode.conf replacing the wsgi path to the
>>> In here, says to point to geonode-project wsgi.py, but doing that,
>>> production settings.py is out of the flow, if I am not wrong. Though I see
>>> all the changes done through site_base.css, site_index.html, site_base.html.
>>> 4.2. Fifth bullet in # http://geonode.org/dev-workshop/#/8/3 -
>>> <Directory "/path/to/my_geonode/">
>>> Order allow,deny
>>> Require all granted
>>> </Directory>
>>> I did all that except, I am pointing to geonode production wsgi.py in
>>> order to use production settings.py. Besides the Alias created to
>>> geonode-project to have its static_root and templates. CSS is being
>>> retrieved, but site_index.html and site_base.html.
>>> Thank you very much for your time and patience.
>>> Kind regards
>>> Julierme
>>> [1] http://geonode.org/dev-workshop/#/8/3
>>> On Fri, Aug 17, 2018 at 5:32 AM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Hello Julierme,
>>>> I'm going to start providing to you some pointers on how
>>>> geonode-project Django template overrides GeoNode core ones.
>>>> 1. The main URL entry "site_index.html"
>>>> This is the very first thing to consider. geonode-project overrides the
>>>> default GeoNode main index through the "urls.py" file. Instead of using the
>>>> default GeoNode one, it says to Django to use its own defined here
>>>> master/project_name/templates/site_index.html
>>>> 2. "site_index.html"
>>>> This one inherits from GeoNode "index.html"
>>>> see https://github.com/geosolutions-it/geonode-project/blob/
>>>> master/project_name/templates/site_index.html#L1
>>>> Nevertheless geonode-project also overrides the "geonode_base.html"
>>>> (see https://github.com/geosolutions-it/geonode-project/
>>>> blob/master/project_name/templates/geonode_base.html ) which inherits
>>>> the local "site_base.html" (see https://github.com/geosol
>>>> utions-it/geonode-project/blob/master/project_name/
>>>> templates/site_base.html )
>>>> 3. "site_base.html"
>>>> The geonode-project "site_base.html" inherits the GeoNode "base.html"
>>>> Il giorno gio 16 ago 2018 alle ore 22:09 Julierme Pinheiro <
>>>>> Dear users and contributors,
>>>>> I am still trying to figure out the way Apache2/geonode.conf is
>>>>> configured in order to have geonode production inheriting the changes in
>>>>> geonode-project, mainly ./geonode_proj/static_root/css/site_base.css
>>>>> and ./geonode_proj/templates/site_index.html and site_base.html.
>>>>> Based on [1] I added the following lines to the geonode.conf which
>>>>> default configuration is found in [2]:
>>>>> ############################### New Configuration for site
>>>>> inheritance ###############################
>>>>> <Directory "/home/geonode/geonode_proj/">
>>>>> Order allow,deny
>>>>> Allow from all
>>>>> Require all granted
>>>>> </Directory>
>>>>> Order allow,deny
>>>>> Allow from all
>>>>> Require all granted
>>>>> </Directory>
>>>>> Order allow,deny
>>>>> Allow from all
>>>>> Require all granted
>>>>> </Directory>
>>>>> <Files wsgi.py>
>>>>> Order deny,allow
>>>>> Allow from all
>>>>> Require all granted
>>>>> </Files>
>>>>> Order allow,deny
>>>>> Allow from all
>>>>> IndexOptions FancyIndexing
>>>>> </Directory>
>>>>> ###########################################3
>>>>> Within this configuration, geonode production is inheriting the
>>>>> site_base.css in ./geonode-proj/static_root/css/, but site_index.html
>>>>> and site_base.html.
>>>>> I also have to mention that WSGI being used is production
>>>>> WSGIScriptAlias / /home/geonode/my_geonode/my_geonode/wsgi.py.
>>>>> My first guest is: although I have created all the Alias path
>>>>> (including the templates directory) as showed above, Apache2 still looking
>>>>> for the site_index.html and site_base.html in the production folder
>>>>> /home/geonode/my_geonode/my_geonode/templates/.
>>>>> One thing I can not understand is: I created the Alias for
>>>>> geonode-project static_root and Apache is doing exactly what I want:
>>>>> getting the site_base.css. But why is not doing for the geonode_project
>>>>> templates.
>>>>> To test my first guest, I copied site_index.html and site_base.html to
>>>>> production path /home/geonode/my_geonode/my_geonode/templates and the
>>>>> response was a request to site_base.html, but site_index.html.
>>>>> Lastly, I have to say that I have production and geonode-project in
>>>>> the same virtualenv.
>>>>> I am very confused. Could someone give me a hint on that please? And
>>>>> my apologies for bringing this topic to discussion again.
>>>>> Thank you for your time in advance
>>>>> Kind regards
>>>>> Julierme
>>>>> [1] https://docs.djangoproject.com/en/2.1/howto/deployment/wsgi/
>>>>> modwsgi/
>>>>> [2] http://docs.geonode.org/en/master/tutorials/install_and_admi
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A -
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>>>> Massarosa
>>>> (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax: +39 0584 1660272
>>>> mob: +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Massarosa
>> (LU) - Italy
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180820/782a2d46/attachment-0001.html>
More information about the geonode-users
