[GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS - Templates
francesco bartoli xbartolone at gmail.com
Fri Aug 24 10:33:42 PDT 2018
Hi Julierme,
What docker-compose command did you run?
Il giorno ven 24 ago 2018 alle ore 18:50 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Hi GeoNode users and developers,
> I have site_index.html, site_base_html and site_base.css ready to use in a
> GeoNode at 2.9.0 instance installed via Docker in a CentOS virtual server.
> According to the structure bellow, the index.html is extended by making
> changes in site_index.html. I changed GeoNode to Geo in the default
> site_index.html jumbotron, but did not see the change making any effect to
> the index.html. Could someone tell me if there is anything else to take to
> consideration besides just changing the site_index.html?
> Thank you very much for your time in advance.
> Kind regards
> Julierme
> |{% extends 'master_index.html' %}
> |./geonode/geonode/contrib/geosites/site_template/templates/site_index.html
> site_index.html
>         |./geonode/geonode/contrib/geosites/templates/master_index.html
>         |------------> master_index.html
>                           |{% extends 'index.html' %}
>                           |./geonode/geonode/templates/index.html
>                           |------------------> index.html
>                                                    |{% extends
> 'geonode_base.html' %}
> |./geonode/geonode/base/templates/geonode_base.html
> geonode.base.html
>        |{% extends
> 'base.html' %}
> |./geonode/geonode/templates/base.html
> |---------->base.html
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180824/8731ab3b/attachment.html>
More information about the geonode-users mailing list
