[GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS - Templates
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Fri Aug 24 10:54:45 PDT 2018
Hi Francesco,
Thank you very much for your reply. If you meant the docker-compose command
during installation, I ran <docker-compose up -d>.
I appreciated your time.
Julierme
On Fri, Aug 24, 2018 at 2:33 PM francesco bartoli <xbartolone at gmail.com>
wrote:
> Hi Julierme,
> What docker-compose command did you run?
> Il giorno ven 24 ago 2018 alle ore 18:50 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi GeoNode users and developers,
>> I have site_index.html, site_base_html and site_base.css ready to use in
>> a GeoNode at 2.9.0 instance installed via Docker in a CentOS virtual
>> server. According to the structure bellow, the index.html is extended by
>> making changes in site_index.html. I changed GeoNode to Geo in the default
>> site_index.html jumbotron, but did not see the change making any effect to
>> the index.html. Could someone tell me if there is anything else to take to
>> consideration besides just changing the site_index.html?
>> Thank you very much for your time in advance.
>> Kind regards
>> Julierme
>> |{% extends 'master_index.html' %}
>> |./geonode/geonode/contrib/geosites/site_template/templates/site_index.html
>> site_index.html
>> |./geonode/geonode/contrib/geosites/templates/master_index.html
>> |------------> master_index.html
>> |{% extends 'index.html' %}
>> |./geonode/geonode/templates/index.html
>> |------------------> index.html
>> |{% extends
>> 'geonode_base.html' %}
>> |./geonode/geonode/base/templates/geonode_base.html
>> geonode.base.html
>> extends 'base.html' %}
>> |./geonode/geonode/templates/base.html
>> |---------->base.html
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180824/ed953f20/attachment.html>
More information about the geonode-users
