[GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS - Templates
francesco bartoli
xbartolone at gmail.com
Fri Aug 24 11:28:05 PDT 2018
You should add the option --build cause you are overriding the base image
from the GeoNode docker hub
Il giorno ven 24 ago 2018 alle ore 19:54 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Hi Francesco,
> Thank you very much for your reply. If you meant the docker-compose
> command during installation, I ran <docker-compose up -d>.
> I appreciated your time.
> Julierme
> On Fri, Aug 24, 2018 at 2:33 PM francesco bartoli <xbartolone at gmail.com>
> wrote:
>> Hi Julierme,
>> What docker-compose command did you run?
>> Il giorno ven 24 ago 2018 alle ore 18:50 Julierme Pinheiro <
>>> Hi GeoNode users and developers,
>>> I have site_index.html, site_base_html and site_base.css ready to use in
>>> a GeoNode at 2.9.0 instance installed via Docker in a CentOS virtual
>>> server. According to the structure bellow, the index.html is extended by
>>> making changes in site_index.html. I changed GeoNode to Geo in the default
>>> site_index.html jumbotron, but did not see the change making any effect to
>>> the index.html. Could someone tell me if there is anything else to take to
>>> consideration besides just changing the site_index.html?
>>> Thank you very much for your time in advance.
>>> Kind regards
>>> Julierme
>>> |{% extends 'master_index.html' %}
>>> |./geonode/geonode/contrib/geosites/site_template/templates/site_index.html
>>> site_index.html
>>> |./geonode/geonode/contrib/geosites/templates/master_index.html
>>> |------------> master_index.html
>>> |{% extends 'index.html' %}
>>> |./geonode/geonode/templates/index.html
>>> |------------------> index.html
>>> |{% extends
>>> 'geonode_base.html' %}
>>> |./geonode/geonode/base/templates/geonode_base.html
>>> geonode.base.html
>>> extends 'base.html' %}
>>> |./geonode/geonode/templates/base.html
>>> |---------->base.html
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180824/9797a324/attachment-0001.html>
More information about the geonode-users
