[GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS - Templates
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Fri Aug 24 14:02:26 PDT 2018
Hi Francesco,
Thank you very much for reply.
I went back and ran the command < docker-compose up --build -d>, but I am
still not getting any success by editing the file site_index.html in
./geonode/contrib/geosites/site_template/templates/site_index.html.
I appreciated your time.
Julierme
On Fri, Aug 24, 2018 at 3:28 PM, francesco bartoli <xbartolone at gmail.com>
wrote:
> You should add the option --build cause you are overriding the base image
> from the GeoNode docker hub
> Il giorno ven 24 ago 2018 alle ore 19:54 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi Francesco,
>> Thank you very much for your reply. If you meant the docker-compose
>> command during installation, I ran <docker-compose up -d>.
>> Julierme
>> On Fri, Aug 24, 2018 at 2:33 PM francesco bartoli <xbartolone at gmail.com>
>> wrote:
>>> Hi Julierme,
>>> What docker-compose command did you run?
>>> Il giorno ven 24 ago 2018 alle ore 18:50 Julierme Pinheiro <
>>>> Hi GeoNode users and developers,
>>>> I have site_index.html, site_base_html and site_base.css ready to use
>>>> in a GeoNode at 2.9.0 instance installed via Docker in a CentOS virtual
>>>> server. According to the structure bellow, the index.html is extended by
>>>> making changes in site_index.html. I changed GeoNode to Geo in the default
>>>> site_index.html jumbotron, but did not see the change making any effect to
>>>> the index.html. Could someone tell me if there is anything else to take to
>>>> consideration besides just changing the site_index.html?
>>>> Thank you very much for your time in advance.
>>>> Kind regards
>>>> Julierme
>>>> |{% extends 'master_index.html' %}
>>>>        |./geonode/geonode/contrib/geosites/site_template/
>>>> site_index.html
>>>>         |./geonode/geonode/contrib/geosites/templates/master_index.html
>>>>         |------------> master_index.html
>>>>                           |{% extends 'index.html' %}
>>>>                           |./geonode/geonode/templates/index.html
>>>>                           |------------------> index.html
>>>>                                                    |{% extends
>>>> 'geonode_base.html' %}
>>>> |./geonode/geonode/base/templates/geonode_base.html
>>>> geonode.base.html
>>>> extends 'base.html' %}
>>>> |./geonode/geonode/templates/base.html
>>>> |---------->base.html
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180824/cf455bbb/attachment.html>
More information about the geonode-users mailing list
