[GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS - Templates
francesco bartoli xbartolone at gmail.com
Sat Aug 25 05:43:51 PDT 2018
Double check it has been activated following this section
http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/geosites.html#activate-geosites-app
Il giorno ven 24 ago 2018 alle ore 23:02 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Hi Francesco,
> Thank you very much for reply.
> I went back and ran the command < docker-compose up --build -d>, but I am
> still not getting any success by editing the file site_index.html in
> ./geonode/contrib/geosites/site_template/templates/site_index.html.
> I appreciated your time.
> Julierme
> On Fri, Aug 24, 2018 at 3:28 PM, francesco bartoli <xbartolone at gmail.com>
> wrote:
>> You should add the option --build cause you are overriding the base image
>> from the GeoNode docker hub
>> Il giorno ven 24 ago 2018 alle ore 19:54 Julierme Pinheiro <
>>> Hi Francesco,
>>> Thank you very much for your reply. If you meant the docker-compose
>>> command during installation, I ran <docker-compose up -d>.
>>> Julierme
>>> On Fri, Aug 24, 2018 at 2:33 PM francesco bartoli <xbartolone at gmail.com>
>>> wrote:
>>>> Hi Julierme,
>>>> What docker-compose command did you run?
>>>> Il giorno ven 24 ago 2018 alle ore 18:50 Julierme Pinheiro <
>>>>> Hi GeoNode users and developers,
>>>>> I have site_index.html, site_base_html and site_base.css ready to use
>>>>> in a GeoNode at 2.9.0 instance installed via Docker in a CentOS virtual
>>>>> server. According to the structure bellow, the index.html is extended by
>>>>> making changes in site_index.html. I changed GeoNode to Geo in the default
>>>>> site_index.html jumbotron, but did not see the change making any effect to
>>>>> the index.html. Could someone tell me if there is anything else to take to
>>>>> consideration besides just changing the site_index.html?
>>>>> Thank you very much for your time in advance.
>>>>> Kind regards
>>>>> Julierme
>>>>> |{% extends 'master_index.html' %}
>>>>> |./geonode/geonode/contrib/geosites/site_template/templates/site_index.html
>>>>> site_index.html
>>>>>         |./geonode/geonode/contrib/geosites/templates/master_index.html
>>>>>         |------------> master_index.html
>>>>>                           |{% extends 'index.html' %}
>>>>>                           |./geonode/geonode/templates/index.html
>>>>>                           |------------------> index.html
>>>>>                                                    |{% extends
>>>>> 'geonode_base.html' %}
>>>>> |./geonode/geonode/base/templates/geonode_base.html
>>>>> geonode.base.html
>>>>> extends 'base.html' %}
>>>>> |./geonode/geonode/templates/base.html
>>>>> |---------->base.html
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180825/05f2d4e9/attachment.html>
More information about the geonode-users mailing list
