[GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS - Templates
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Mon Aug 27 09:42:22 PDT 2018
Hi Francesco,
Thank you very much for your reply. I read the documentation you made
reference, but I am changing the approach. I installed geonode_project as
mentioned by Toni and now I am trying to copy the files site_index.html,
site_base.html to ./geonode_project/geonode_project/templates/ and to run
collectstatic, but I am hitting a error as I mentioned in a previous
e-mails:
(geonode) [geo at gis geonode_project]$ python manage.py collectstatic
File "manage.py", line 31, in <module>
execute_from_command_line(sys.argv)
File
"/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
line 364, in execute_from_command_line
utility.execute()
File
line 308, in execute
settings.INSTALLED_APPS
File
"/home/geo/Envs/geonode/lib/python2.7/site-packages/django/conf/__init__.py",
line 56, in __getattr__
self._setup(name)
File
line 41, in _setup
self._wrapped = Settings(settings_module)
File
line 110, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "/usr/lib64/python2.7/importlib/__init__.py", line 37, in
import_module
__import__(name)
File "/home/geo/geonode_project/geonode_project/settings.py", line 30, in
<module>
from geonode.settings import *
ImportError: No module named geonode.settings
I appreciated your time.
Kind regards
Julierme
On Sat, Aug 25, 2018 at 9:44 AM francesco bartoli <xbartolone at gmail.com>
wrote:
> Double check it has been activated following this section
> http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/geosites.html#activate-geosites-app
> Il giorno ven 24 ago 2018 alle ore 23:02 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hi Francesco,
>> Thank you very much for reply.
>> I went back and ran the command < docker-compose up --build -d>, but I am
>> still not getting any success by editing the file site_index.html in
>> ./geonode/contrib/geosites/site_template/templates/site_index.html.
>> Julierme
>> On Fri, Aug 24, 2018 at 3:28 PM, francesco bartoli <xbartolone at gmail.com>
>> wrote:
>>> You should add the option --build cause you are overriding the base
>>> image from the GeoNode docker hub
>>> Il giorno ven 24 ago 2018 alle ore 19:54 Julierme Pinheiro <
>>>> Hi Francesco,
>>>> Thank you very much for your reply. If you meant the docker-compose
>>>> command during installation, I ran <docker-compose up -d>.
>>>> Julierme
>>>> On Fri, Aug 24, 2018 at 2:33 PM francesco bartoli <xbartolone at gmail.com>
>>>> wrote:
>>>>> Hi Julierme,
>>>>> What docker-compose command did you run?
>>>>> Il giorno ven 24 ago 2018 alle ore 18:50 Julierme Pinheiro <
>>>>>> Hi GeoNode users and developers,
>>>>>> I have site_index.html, site_base_html and site_base.css ready to use
>>>>>> in a GeoNode at 2.9.0 instance installed via Docker in a CentOS virtual
>>>>>> server. According to the structure bellow, the index.html is extended by
>>>>>> making changes in site_index.html. I changed GeoNode to Geo in the default
>>>>>> site_index.html jumbotron, but did not see the change making any effect to
>>>>>> the index.html. Could someone tell me if there is anything else to take to
>>>>>> consideration besides just changing the site_index.html?
>>>>>> Thank you very much for your time in advance.
>>>>>> Kind regards
>>>>>> Julierme
>>>>>> |{% extends 'master_index.html' %}
>>>>>> |./geonode/geonode/contrib/geosites/site_template/templates/site_index.html
>>>>>> site_index.html
>>>>>> |./geonode/geonode/contrib/geosites/templates/master_index.html
>>>>>> |------------> master_index.html
>>>>>> |{% extends 'index.html' %}
>>>>>> |./geonode/geonode/templates/index.html
>>>>>> |------------------> index.html
>>>>>> |{% extends
>>>>>> 'geonode_base.html' %}
>>>>>> |./geonode/geonode/base/templates/geonode_base.html
>>>>>> geonode.base.html
>>>>>> extends 'base.html' %}
>>>>>> |./geonode/geonode/templates/base.html
>>>>>> |---------->base.html
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180827/503c3cb0/attachment.html>
More information about the geonode-users
