[GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon Aug 27 09:05:04 PDT 2018
Hi Toni,
Thank you very much for your reply. I am doing great. And I hope you are
doing just wonderful. Yes, you are right. The files site_index.htm,
site_base.html and site_base.css are ready to use. I configured/edit them
in a geonode_project installed in a virtualenv in a Ubuntu at 16.04 server.
Now I want to copy site_index.html, site_base.html and site_base.css. to a
CentOS server that contains GeoNode and GeoNode_Project installed via
docker.
In Centos:
1  - GeoNode installed via Docker
GeoNode was installed according to [1], except I use the command line:
<docker-compose up --build -d>
2 - GeoNode_Project installed via Docker
GeoNode was installed according to [2], and because Geonode_Project django
container port was conflicting with GeoNode django port. I configured the
files docker-compose.yml and docker-compose.override.yml as follow:
docker-compose.yml
geonode:
ports:
   -81:80
django:
GEONODE_LB_HOST_IP: 192.168.00.02
GEONODE_LB_PORT: 81
SITEURL: http://192.168.00.02/
ALLOWED_HOSTS: "['localhost', '192.168.0.02', '127.0.0.1', '::1']"
GEOSERVER_PUBLIC_LOCATION: http://192.168.0.02/geoserver/
celery:
GEONODE_LB_HOST_IP: 192.168.0.02
GEONODE_LB_PORT: 81
SITEURL: http://192.168.0.02/
geoserver:
GEONODE_LB_PORT: 81
Said that, in the geonode_project folder, I am running python manage.py
collectstatic  and I am hitting a error message shown bellow:
File "manage.py", line 31, in <module>
    execute_from_command_line(sys.argv)
  File
"/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
line 364, in execute_from_command_line
    utility.execute()
  File
line 308, in execute
    settings.INSTALLED_APPS
  File
"/home/geo/Envs/geonode/lib/python2.7/site-packages/django/conf/__init__.py",
line 56, in __getattr__
    self._setup(name)
  File
line 41, in _setup
    self._wrapped = Settings(settings_module)
  File
line 110, in __init__
    mod = importlib.import_module(self.SETTINGS_MODULE)
  File "/usr/lib64/python2.7/importlib/__init__.py", line 37, in
import_module
    __import__(name)
  File "/home/geo/geonode_project/geonode_project/settings.py", line 30, in
<module>
    from geonode.settings import *
ImportError: No module named geonode.settings
Am I missing any configuration? Could you give me a hint on that, please?
I appreciated your time
Kind regards
Julierme
[1]
http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/setup_docker_compose.html
[2]https://github.com/GeoNode/geonode-project
On Sat, Aug 25, 2018 at 4:56 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hey Julierme,
> how are you doing? I haven´t followed the whole converersation.
> Just my two cents, is it possible that your´re look in the wrong place?
> Contrib app is a way to run multiple website. Are you looking for templates
> here? -> https://github.com/GeoNode/geonode/tree/master/geonode/templates
> Like base.html, index.html and so on?
> If so it would be better to start with geonode_project:
> here you can easily overwrite the files you mentioned here:
> https://github.com/GeoNode/geonode-project/tree/master/project_name/templates
> Without changing the core templates.
> cheers,
> toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 25.08.2018 um 21:00 schrieb geonode-users-request at lists.osgeo.org:
> Message: 1
> Date: Fri, 24 Aug 2018 18:02:26 -0300
> From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
> To: francesco bartoli <xbartolone at gmail.com>
> Cc: geonode-users <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] Geonode at 2.9.0 Docker Installation CentOS
> - Templates
> Message-ID:
> <CAKTKyJKomRPN8nTi-S7yLhk-S7BoH3wTmHDyEDEryx4WxoDCxQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Francesco,
> Thank you very much for reply.
> I went back and ran the command < docker-compose up --build -d>, but I am
> still not getting any success by editing the file site_index.html in
> ./geonode/contrib/geosites/site_template/templates/site_index.html.
> I appreciated your time.
> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180827/05eeddde/attachment-0001.html>
More information about the geonode-users mailing list
