[GeoNode-users] Can't load layers on Geonode without loggin to Geoserver
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Dec 5 00:20:37 PST 2018
Hello,
recently some work has been done both on master and 2.8.x branches in order
to overcome this issue.
Now the generation of the thumbnail does not rely on a WMS GetMap request
anymore but dumps an image locally.
You should try, if possible, to update your code and align to the latest
commits.
Il giorno lun 3 dic 2018 alle ore 16:13 Jose Cáceres <jose.atyus at gmail.com>
ha scritto:
> Hi,
> I have a problem, I have mi geonode site configured to be open, and so
> people can access the layers and compose maps without need to be logged in
> into Geonode.
> My problem is that I cannot load or view any thumbnails of the layers in
> Geonode, without first login in into geoserver. After I logged in into
> Geoserver, without loggin in into Geonode, I can access all the layers on
> Geoserver. See the attached screenshot from how Geonode looks before and
> after logging in Geoserver.
> The only layer visible in the first scenario, is one that I uploaded
> directly using the Geonode upload layer interface, the rest of the layers
> (88) where uploaded directly into Geoserver in a local PostGIS database and
> then run 'sudo geonode updatelayers' to incorporate them into Geonode.
> Is there a way to access the layers without loggin in to Geoserver?
> I'm running Geonode 2.8 with Geoserver 2.12
> Thanks for your help
> Kind regards
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 03/12/18
> 08:57:36
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181205/00a45821/attachment.html>
More information about the geonode-users
