[GeoNode-users] [GeoNode/geonode-project] geonode-project at 2.8 docker installation fails configuring WSGI as local_settings (#51)
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu Dec 6 04:21:56 PST 2018
Dear all,
Here http://192.241.135.159/ is an example. Ubuntu Server 18.04 LTS with
geonode-project at 2.8 installed via docker using
os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.settings")
config for WSGI.py. SITE_BASE.CSS has not been retrieved.
But both, either settings and local_settings in WSGI.py, SITE_BASE.CSS has
not been retrieved.
Thank you for your time in advance
Any help will be very appreciated
Kind regards
Julierme
On Wed, Dec 5, 2018 at 6:22 AM Alessio Fabiani <notifications at github.com>
wrote:
> Dear all,
> historically geonode-project followed the path described by Matteo for
> whatever reasons that I don't remember now.
> I agree that we should align the two approaches in order to avoid
> confusion.
> Il giorno lun 3 dic 2018 alle ore 16:21 juliermegithub <
> notifications at github.com> ha scritto:
> > Hi Alessio and Matteo,
> > I tried installing a new instance, using local_settings.py and
> configuring
> > wsgi.py as os.environ.setdefault("DJANGO_SETTINGS_MODULE",
> > "my_geonode.settings").
> > But the installation did not succeed.
> > Kind regards
> > Julierme
> > On Mon, Dec 3, 2018 at 11:38 AM Julierme Pinheiro <
> > juliermeopensourcedeveloper at gmail.com> wrote:
> > > Dear Alessio and Matteo,
> > > Thank you both for the highlights. Let me understand what you both
> > pointed
> > > here:
> > > By Alessio:
> > > I understood that I can use local_settings.py, and still configure
> > wsgi.py
> > > Is that the correct understanding?
> > > Sorry Alessio, one thing I did not understand: I currently have
> > > "DJANGO_SETTINGS_MODULE", "my_geonode.local_settings" set in WSGI.py
> for
> > > the installed geonode-project at 2.8 instance, Can I revert this
> > > configuration to "my_geonode.settings" by adding the line <
> > > DJANGO_SETTINGS_MODULE=my_geonode.settings> to the file uwsgi.ini?
> > > By Matteo:
> > > First of all, I could not understand why we run the command
> > > DJANGO_SETTINGS_MODULE=my_geonode.local_settings paver setup, as we
> > already
> > > have a geoserver4my_geonode container. But anyway, I ran the commands
> > > bellow and got the response for paver start:
> > > $ docker exec -it django4my_geonode paver reset
> > > $ docker exec -it django4my_geonode paver setup
> > > $ docker exec -it django4my_geonode paver sync
> > > $ docker exec -it django4my_geonode paver start
> > > Java was not found in your path.
> > > Any comment on that will be very appreciated it.
> > > Kind Regards
> > > Julierme
> > > On Mon, Dec 3, 2018 at 7:21 AM Matteo De Stefano <
> > > wrote:
> > >> This is an issue in gonode-project settings and local_settings
> > >> management, in my opinion.
> > >> Currently, local_settings.py are always imported by settings.py, and
> not
> > >> overriding but just "extending" settings.py.
> > >> This diverges from the behavior of local_settings in vanilla geonode,
> > >> where local_settings.py are importing settings.py, and overriding:
> https://github.com/GeoNode/geonode/blob/master/geonode/local_settings.py.geoserver.sample
> > >> This is confusing, and the instructions in README are wrong, since
> wsgi
> > >> needs always to load settings.py, with current approach (to be
> fixed?).
> > >> Pointing to local_settings.py is wrong.
> > >> The following lines of instructions in README should be removed, or
> > >> modified:
> > >> **# Using Custom Local Settings
> > >> cp my_geonode/local_settings.py.sample my_geonode/local_settings.py
> > >> vim my_geonode/wsgi.py
> > >> --> os.environ.setdefault("DJANGO_SETTINGS_MODULE",
> > >> "my_geonode.local_settings")
> > >> DJANGO_SETTINGS_MODULE=my_geonode.local_settings paver reset
> > >> DJANGO_SETTINGS_MODULE=my_geonode.local_settings paver sync
> > >> DJANGO_SETTINGS_MODULE=my_geonode.local_settings paver start**
> > >> You are receiving this because you were mentioned.
> > >> Reply to this email directly, view it on GitHub
> https://github.com/GeoNode/geonode-project/issues/51#issuecomment-443641754
> > >> or mute the thread
> https://github.com/notifications/unsubscribe-auth/ANlWkFwZPbuVTm8DhMP-_ZSAf4hocIpfks5u1O0XgaJpZM4Yy2Av
> > You are receiving this because you commented.
> https://github.com/GeoNode/geonode-project/issues/51#issuecomment-443747404
> > or mute the thread
> https://github.com/notifications/unsubscribe-auth/ABOARbAHtqy2yg1l1Jnl4QPKjlxhMxvaks5u1UF-gaJpZM4Yy2Av
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V
> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> <https://github.com/GeoNode/geonode-project/issues/51#issuecomment-444398806>,
> or mute the thread
> <https://github.com/notifications/unsubscribe-auth/ANlWkJssJ0MYU-5UUJQuQ7t6oHB_jANLks5u14JHgaJpZM4Yy2Av>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181206/2d547350/attachment.html>
More information about the geonode-users mailing list
