[GeoNode-users] Can't load layers on Geonode without loggin to Geoserver
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Dec 7 01:14:18 PST 2018
Uhm that's strange, could you maybe try docker-compose build again
after having updated the code base?
Il giorno gio 6 dic 2018 alle ore 03:43 Jose Cáceres <jose.atyus at gmail.com>
ha scritto:
> Hi Alesio,
> Thanks for your answer, I actually try to updated Geonode to 2.10 version
> using the Deployment Using Docker instructions that you provided in this
> link:
> https://docs.google.com/document/d/1S0ac9IR9IW9tUjMu7JETPLUjnfQ6P87m1PKNko8IPWY/edit
> It all goes well up to the point after I run:
> docker-compose -f docker-compose.yml -f
> docker-compose.override.localhost.yml up
> I always got stuck in this point:
> rabbitmq4geonode | missed heartbeats from client, timeout: 60s
> And I'm not sure if this is due to slow connectivity from my network or
> because I messed something up alone the way
> Thanks for your help.
> Kind Regards,
> José
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 05/12/18
> 20:40:32
> On Wed, Dec 5, 2018 at 2:20 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hello,
>> recently some work has been done both on master and 2.8.x branches in
>> order to overcome this issue.
>> Now the generation of the thumbnail does not rely on a WMS GetMap request
>> anymore but dumps an image locally.
>> You should try, if possible, to update your code and align to the latest
>> commits.
>> Il giorno lun 3 dic 2018 alle ore 16:13 Jose Cáceres <
>> jose.atyus at gmail.com> ha scritto:
>>> Hi,
>>> I have a problem, I have mi geonode site configured to be open, and so
>>> people can access the layers and compose maps without need to be logged in
>>> into Geonode.
>>> My problem is that I cannot load or view any thumbnails of the layers in
>>> Geonode, without first login in into geoserver. After I logged in into
>>> Geoserver, without loggin in into Geonode, I can access all the layers on
>>> Geoserver. See the attached screenshot from how Geonode looks before and
>>> after logging in Geoserver.
>>> The only layer visible in the first scenario, is one that I uploaded
>>> directly using the Geonode upload layer interface, the rest of the layers
>>> (88) where uploaded directly into Geoserver in a local PostGIS database and
>>> then run 'sudo geonode updatelayers' to incorporate them into Geonode.
>>> Is there a way to access the layers without loggin in to Geoserver?
>>> I'm running Geonode 2.8 with Geoserver 2.12
>>> Kind regards
>>> José David Cáceres
>>> Ingeniero Ambiental
>>> Máster en Tecnologías de la Información Geográfica
>>> e-mail: jose.atyus at gmail.com
>>> [image: Mailtrack]
>>> notificado con
>>> Mailtrack
>>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 03/12/18
>>> 08:57:36
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> José David Cáceres
> Ingeniero Ambiental
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181207/02b93e0f/attachment-0001.html>
More information about the geonode-users mailing list
