[GeoNode-users] GeoNode Authentication
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Dec 13 06:39:38 PST 2018
Francesco you are right!
Oauth2 urls also should be revised, both on GeoNode admin and GeoServer
sides.
Il giorno gio 13 dic 2018 alle ore 15:33 francesco bartoli <
xbartolone at gmail.com> ha scritto:
> Shouldn't be also configured that SAE application as partner of django
> oauth toolkit
> http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html?highlight=auth2#django-oauth-toolkit-setup-and-configuration
> Il giorno gio 13 dic 2018 alle ore 12:05 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Hi,
>> please refer to this issue https://github.com/GeoNode/geonode/issues/4113
>> Someone had a similar issue recently.
>> It is worth notice that those changes work better using GeoNode 2.10
>> Il giorno mar 11 dic 2018 alle ore 15:33 Pierre-Alix Tremblay <
>> pierrealix at kartoza.com> ha scritto:
>>> Hi,
>>> I’m new to the GeoNode (and Django) world so sorry in advance if my
>>> question sounds newbie and a bit straightforward.
>>> I did a bit of research but it’s still not clear in my mind.
>>> I have a GeoNode instance running at http://my_domain/geonode.
>>> I have a django app (named SAE) running http://my_domain/
>>> So the apps run under the same domain.
>>> I want users to authenticate on SAE (using a custom login form) with
>>> their GeoNode credentials and be automatically logged on GeoNode.
>>> The flow would look like the GeoNode/GeoServer authentication using the
>>> OAuth 2 protocol but I don’t want to send the user to the GeoNode login
>>> form.
>>> Is it doable? How to achieve this?
>>> Kind regards,
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181213/fa8988a4/attachment-0001.html>
More information about the geonode-users
