[GeoNode-users] GeoNode Authentication
francesco bartoli xbartolone at gmail.com
Thu Dec 13 06:32:50 PST 2018
Shouldn't be also configured that SAE application as partner of django
oauth toolkit
http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html?highlight=auth2#django-oauth-toolkit-setup-and-configuration
Il giorno gio 13 dic 2018 alle ore 12:05 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Hi,
> please refer to this issue https://github.com/GeoNode/geonode/issues/4113
> Someone had a similar issue recently.
> It is worth notice that those changes work better using GeoNode 2.10
> Il giorno mar 11 dic 2018 alle ore 15:33 Pierre-Alix Tremblay <
> pierrealix at kartoza.com> ha scritto:
>> Hi,
>> I’m new to the GeoNode (and Django) world so sorry in advance if my
>> question sounds newbie and a bit straightforward.
>> I did a bit of research but it’s still not clear in my mind.
>> I have a GeoNode instance running at http://my_domain/geonode.
>> I have a django app (named SAE) running http://my_domain/
>> So the apps run under the same domain.
>> I want users to authenticate on SAE (using a custom login form) with
>> their GeoNode credentials and be automatically logged on GeoNode.
>> The flow would look like the GeoNode/GeoServer authentication using the
>> OAuth 2 protocol but I don’t want to send the user to the GeoNode login
>> form.
>> Is it doable? How to achieve this?
>> Kind regards,
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181213/eab45467/attachment-0001.html>
More information about the geonode-users mailing list
