[GeoNode-users] Upgraded to Geoserver 2.12.1 -- Unexpected
unni mana unnivm at gmail.com
Sun Jan 7 02:30:56 PST 2018
Hi Toni,
Do I need to upgrade geonode as well? The main reason for upgrading
geoserver to latest is that I need to use .mbtiles extension. But in order
to use this extension, I need to use latest geoserver.
Geoserver 2.10 does not support mbtiles. I have tried that earlier.
what are the things I need to look into gsconfig file?
Thanks
Unni M
On Sun, Jan 7, 2018 at 3:24 PM, Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hi Unni,
> Geonode needs a modified geoserver version (because of auth).
> That´s why I mentioned the build resource.
> Unfortunately I´m not familiar with this exception further cannot say if
> geonode 1.7.11
> and geoserver 2.12.1 are compatible. ( 1.7.11 ships with 2.10 as far as I
> remember ) .
> I´m sure other users can help you here.
> Just to double check, you´re settings are correct and you brought
> everything in sync?
> manage.py updatelayers etc … ? Also a look at your gsconfig version could
> be a first
> step.
> Cheers,
> Toni
> Hi Toni,
> I upgraded to latest geoserver (2.12.x ) from that location(
> http://build.geonode.org/geoserver/latest/) you have mentioned. But when
> I upload a layer from *geonode*, I am getting the following error
> *Unexpected excwpti9n 'NoneType'* object has no attribute 'store_type'
> The current *geonode *version is used :is *1.7.11*
> Thanks
> Unni M
If not played, Free Sudoku Android Game
<https://play.google.com/store/apps/details?id=com.gamerfan.sudoku>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180107/1607a4a0/attachment-0001.html>
More information about the geonode-users mailing list
