[GeoNode-users] Cannot view uploaded layers
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Jan 9 02:14:31 PST 2018
It seems like many users recently are having issues with the REST Role
Service, but actually I cannot understand why.
I need to try an installation from scratch of 2.7.x and see if there's some
misconfiguration on the GeoServer Data Dir or something.
Basically the issue is that the Role Service, somehow, is not able to fetch
roles from GeoNode APIs.
Are you able to see if there's some error on the GeoNode logs?
Also, can you try to inspect manually the config.xml file under the
"geoserver\data\security\role\geonode REST role service" and see if there's
something wrong? Eventually you will need to restart GeoServer/Tomcat again.
Another check worth to do is the "geofence-server.properties" under the
"geoserver\data\geofence" folder. It should contain the following properties
### GeoFence Module configuration file
### GeoServer will read this file at boot time.
### This file may be automatically regenerated by GeoServer, so any changes
beside the property values may be lost.
### GeoFence main configuration
instanceName=default-gs
servicesUrl=internal:/
allowRemoteAndInlineLayers=true
allowDynamicStyles=true
grantWriteToWorkspacesToAuthenticatedUsers=true
useRolesToFilter=false
acceptedRoles=
### Cache configuration
cacheSize=500000
cacheRefresh=6000000
cacheExpire=6000000
gwc.context.suffix=gwc
org.geoserver.rest.DefaultUserGroupServiceName=geonode REST role service
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
2018-01-09 10:59 GMT+01:00 <Stefano.LUONI at ext.ec.europa.eu>:
> Hi Alessio,
> you're right: after uploading layers, no GeoFence data rules were
> automatically added, hence the access is denied because only the default
> DENY rule is present. Unfortunately, if I manually add a rule to allow
> access to a layer (all roles + all users + all services + all requests +
> geonode workspace + selected layer + priority=0), nothing changes and I'm
> still unable to visualize the layer from GeoNode.
> I realised that I forgot to change the "Active role service" property in
> Security => Settings in GeoServer; if I set "geonode REST role service" I'm
> unable to upload layers though, as I get a 403 error from Tomcat.
> I'm not sure what can be wrong; I followed all steps in this guide:
> http://docs.geonode.org/en/master/tutorials/admin/
> geoserver_geonode_security/
> The only thing is different is that I don't have the geonodeAuthProvider
> created among Authentication Providers and I don't know how I'm supposed to
> add it.
> *From:* Alessio Fabiani [alessio.fabiani at geo-solutions.it]
> *Sent:* 09 January 2018 10:23
> *To:* Simone Dalmasso
> *Cc:* LUONI Stefano (JRC-ISPRA-EXT); geonode-users
> *Subject:* Re: [GeoNode-users] Cannot view uploaded layers
> Please double check GeoFence rules actually exist on GeoServer.
> Regards,
> Alessio Fabiani
> http://goo.gl/it488V for more information.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax: +39 0584 1660272 <0584%20166%200272>
> mob: +39 331 6233686 <331%20623%203686>
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-01-09 10:16 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi Stefano,
>> That error could be due to oauth misconfiguration and Geoserver is hiding
>> the layer.
>> Il giorno lun 8 gen 2018 alle 17:06 <Stefano.LUONI at ext.ec.europa.eu> ha
>> scritto:
>>> Hi,
>>> I've got this issue with layers: after uploading, which seems to be ok,
>>> I cannot view anything on Geonode website. More specifically, tiles are
>>> loaded but they not include anything of the layer, as WMS calls return
>>> errors like below.
>>> This is what I spot from the GeoServer log:
>>> 2018-01-08 15:41:46,328 ERROR [geoserver.ows] -
>>> org.geoserver.platform.ServiceException: Could not find layer
>>> geonode:afg_aal
>>> This is what I spot from Apache error log:
>>> [Mon Jan 08 17:01:31.588608 2018] [wsgi:error] [pid 1387:tid
>>> 140510650439424] Possible error with OWSLib. Turning all available
>>> properties to string
>>> I'm trying with both raster and shape files; all files are correctly
>>> uploaded and I'm able to see them via Layer Preview from GeoServer side.
>>> I'm using Ubuntu 16.04, Geonode 2.7, Geoserver 2.12-SNAPSHOT.
>>> Thank you very much,
>>> Stefano
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180109/e8d8bb31/attachment-0001.html>
More information about the geonode-users
