[GeoNode-users] What's the best way to install geonode in Debian?
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Jul 30 07:45:49 PDT 2018
Hello Amedeo,
I kindly suggest you to follow the README at
https://github.com/geosolutions-it/geonode-project/blob/master/README.rst
Most probably you will need to install GDAL and PostGIS first on your
server.
Il giorno lun 30 lug 2018 alle ore 16:33 Amedeo Fadini <amefad at gmail.com>
ha scritto:
> Hi folks!
> I am ready for a brand new installation of geonode on a Debian server,
> once installed I'd like to make some changes and customization using a
> geonode project.
> As previously I've always used Ubuntu server, I'm not sure what's the best
> way to install Geonode in Debian: I started installing every single
> package like described in admin workshop for CentOS [0] but I now realized
> that is possibile add ppa repository in sources.d of Debian and maybe
> install the packages from sources like described here [1]
> If I add ppa repository wull "sudo apt-get instaall geonode" work in
> Debian testing or not?
> Thank-you for any good advice
> Amedeo Fadini
> [0]
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html#packages-installation
> [1]
> https://linuxconfig.org/install-packages-from-an-ubuntu-ppa-on-debian-linux
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180730/c22dc670/attachment-0001.html>
More information about the geonode-users
