[GeoNode-users] What's the best way to install geonode in Debian?
Amedeo Fadini amefad at gmail.com
Mon Jul 30 22:17:49 PDT 2018
Hi Alessio, thank-you very much, I remember about gonode project and it
seems the easiest way,
No matter installing manualy GDAL and PostGIS (already on the server), I'm
still a bit confused on how virtual environment works, but I'll find some
docs about it...
Use of Docker and Ansible are mandatory? I think that once my geonode is up
and running I can work on that instance isn't it?
Amedeo
2018-07-30 16:45 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Hello Amedeo,
> I kindly suggest you to follow the README at
> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst
> Most probably you will need to install GDAL and PostGIS first on your
> server.
> Il giorno lun 30 lug 2018 alle ore 16:33 Amedeo Fadini <amefad at gmail.com>
> ha scritto:
>> Hi folks!
>> I am ready for a brand new installation of geonode on a Debian server,
>> once installed I'd like to make some changes and customization using a
>> geonode project.
>> As previously I've always used Ubuntu server, I'm not sure what's the
>> best way to install Geonode in Debian:  I started installing  every single
>> package like described in admin workshop for CentOS [0]  but I now realized
>> that is possibile add ppa repository in sources.d of Debian and maybe
>> install the packages from sources like described here [1]
>> If I add ppa repository wull "sudo apt-get instaall geonode" work in
>> Debian testing or not?
>> Thank-you for any good advice
>> Amedeo Fadini
>> [0] http://docs.geonode.org/en/master/tutorials/install_and_
>> admin/geonode_install/install_geonode_application.html#
>> packages-installation
>> [1] https://linuxconfig.org/install-packages-from-an-ubuntu-
>> ppa-on-debian-linux
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A -
> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>  Massarosa
> (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180731/72835c04/attachment.html>
More information about the geonode-users mailing list
