[GeoNode-users] GeoNode Docker Start Containers (Julierme Pinheiro)
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Mon Jul 30 22:59:35 PDT 2018
Dear Julierme,
I´m writing from mobile please excuse short answers:
> 1 - # I stopped all containers
> $ docker stop nginx4geonode django4geonode geoserver4geonode celery4geonode
> db4geonode rabbitmq4geonode
Use instead
$ docker-compose down
> I added the IP 198.162.0.2 to PROXY_ALLOWED_HOSTS = ['localhost',
> 'django', 'geonode', '192.168.0.2' ], but django.env also has
> PROXY_ALLOWED_HOST and changed it ALLOWED_HOSTS = ['localhost', 'django',
> 'geonode', '192.168.0.2‘ ]
> I got confused here. Should I add the IP only into django.env or should I
> add it to settings.py too? Or should I add it only to seetings.py?
docker-compose reads vars from this file here:
https://github.com/GeoNode/geonode/blob/master/docker-compose.yml#L108 <https://github.com/GeoNode/geonode/blob/master/docker-compose.yml#L108>
Then settings.py reads those through with os.getenv (= get environment variables)
So in a docker context these are populated and you can just use the env file.
> default='django.core.mail.backends.smtp.EmailBackend')
> EMAIL_HOST = 'smtp.sipa.edu'
> EMAIL_PORT = 587
> EMAIL_HOST_USER = 'osgeo.geonode'
> EMAIL_HOST_PASSWORD = 'passwd
> EMAIL_USE_TLS = True
> DEFAULT_FROM_EMAIL = 'osgeo.geonode at sipa.edu'
> else:
> EMAIL_BACKEND = os.getenv('DJANGO_EMAIL_BACKEND',
This must be set in settings as you did:
> 4.3 settings.py SITEURL CONFIG
> I got confused in here. As I mentioned in item 3, django.env is set as
> GEONODE_LB_HOST_IP=198.162.0.2 and GEONODE_LB_PORT=80. Though SITEURL =
> os.getenv('SITEURL', "http://localhost:8000/") in the seetings.py, do I
> still have to change it to http://198.162.0.2? <http://198.162.0.2/?>
You can set it here: https://github.com/GeoNode/geonode/blob/master/scripts/docker/env/production/django.env#L20 <https://github.com/GeoNode/geonode/blob/master/scripts/docker/env/production/django.env#L20>
> I got confused in here. SITEURL is set as SITEURL = "http://localhost/" in
> local_settings, but I set GEONODE_LB_HOST_IP=198.162.0.2 and
> GEONODE_LB_PORT=80 in django.env. Do I still have to change SITEURL to
> SITEURL = "http://198.162.0.2/" in local_settings? Does it make sense to
> have the local_settings.py? Or should I use only settings.py? There was not
> local_settings.py.sample as used to be for Python virtualenv setup, but I
> copied local_settings.py.geoserver.sample as local_settings.py.
local_seettings.py comes handy if you commit your changes to a git repository.
You can keep all your personal passwords in local_settings and exclude it from commit.
If you use it or not it´s up to you ;)
Cheers,
Toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil +49/ (0) 176 6680 3198
Tel +49/ (0) 341 24 04 738
Fax +49/ (0) 341 24 04 73
Web http://csgis.de
Hinweis gemäß § 33 BDSG
Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 31.07.2018 um 00:24 schrieb geonode-users-request at lists.osgeo.org:
> Re: GeoNode Docker Start Containers (Julierme Pinheiro)
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180731/bb2a1bf6/attachment-0001.html>
More information about the geonode-users
