[GeoNode-users] [GeoNode-devel] GeoNode Loves Keycloak
francesco bartoli
xbartolone at gmail.com
Fri Jun 1 10:24:58 PDT 2018
thanks for the info, anyway it looks promising!
Il giorno ven 1 giu 2018 alle ore 19:01 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Basically, with several updates to the Oauth2 libraries, GeoNode has
> become OIDC 1.0 compliant and therefore it can be setup as a Identity
> Provider for Keycloak.
> GeoServer is connected directly to Keycloak, which acts as Authentication
> Provider.
> Keycloak, other than SSO and Identity Broker for several Authentication
> Providers, is also able to translate Roles.
> Among the advantages listed above, OIDC is more secure since it shares
> signed or encrypted JWT.
> However, we are still far from having something stable.
> 2018-06-01 18:52 GMT+02:00 francesco bartoli <xbartolone at gmail.com>:
>> Pretty cool Alessio! How does it work?
>> Il giorno ven 1 giu 2018 alle ore 18:19 Simone Dalmasso <
>> simone.dalmasso at gmail.com> ha scritto:
>>> :O !!
>>> 2018-06-01 17:42 GMT+02:00 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it>:
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3
>>>> <https://maps.google.com/?q=Via+di+Montramito+3&entry=gmail&source=g>/A
>>>> - 55054 Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax: +39 0584 1660272
>>>> mob: +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Simone
> @alfa7691
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180601/beda6d70/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180601/beda6d70/attachment-0001.gif>
More information about the geonode-users
