[GeoNode-users] upload doesn't work without any logs (Eugenio Trumpy)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jun 12 08:09:29 PDT 2018
Hi Eugenio,
try maybe to rise up the GeoServer log level and check the logs (of
GeoServer) after the upload.
Maybe the SHP cannot be read from GeoServer for some reason.
Also, is this happening with every dataset or just with one SHP?
Il giorno mar 12 giu 2018 alle ore 17:00 Eugenio Trumpy <
frippe12573 at hotmail.com> ha scritto:
> Dear Toni,
> I set:
> DEBUG=True
> in local_setting.py configuration file. Since I have a geosites
> installation the local_setting I meant before was the general one (not
> inside the sites folder).
> Once I try to upload a shp file nothing is written in apache2 access.log
> The shape file is very very small! Deleted even the cookies, but nothing
> change.
> Eugenio
> *Da:* Toni Schönbuchner <toni.schoenbuchner at csgis.de>
> *Inviato:* martedì 12 giugno 2018 16:09
> *A:* Eugenio Trumpy
> *Cc:* geonode-users
> *Oggetto:* Re: upload doesn't work without any logs (Eugenio Trumpy)
> Dear Eugenio,
> have you tried to set DEBUG to true in local_settings? Further do you see
> the request in apaches access log?
> An upload which exeeds the allowed filesize limit can cause a 400 as well.
> Is your file of tremendous size?
> Next can you check your cookies in developer tools? It could be worth to
> delete all of them and retry with a
> fresh session.
> cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 73
> Web http://csgis.de
> CSGIS <http://csgis.de/>
> csgis.de
> OneCause is premium, responsive theme built with Bootstrap for Joomla CMS.
> With a clean and minimal design, this multi-purpose template is perfect for
> anything you can imagine.
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 12.06.2018 um 14:42 schrieb Eugenio Trumpy <frippe12573 at hotmail.com>:
> No IP or domain changed.
> That's weird...
> E.
> *Inviato:* martedì 12 giugno 2018 14:17
> *A:* frippe12573 at hotmail.com
> *Cc:* geonode-users
> Dear Eugenio,
> did you change anything on your ip or domain setup which could cause the
> error 400?
> Cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Web http://csgis.de
> csgis.de
> Message: 4
> Date: Tue, 12 Jun 2018 11:55:43 +0000
> From: Eugenio Trumpy <frippe12573 at hotmail.com>
> To: Simone Dalmasso <simone.dalmasso at gmail.com>
> Cc: geonode-users <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] upload doesn't work without any logs
> Message-ID:
> AM5P190MB0420AB6A1C678D9CEFBF67D4E57F0 at AM5P190MB0420.EURP190.PROD.OUTLOOK.COM
> Content-Type: text/plain; charset="iso-8859-1"
> Hi Simone,
> here is the issue:
> POST http://gemex.igg.cnr.it/layers/upload 400 (BAD REQUEST)
> any hints?
> Eugenio
> ________________________________
> Da: Simone Dalmasso <simone.dalmasso at gmail.com>
> Inviato: martedì 12 giugno 2018 13:41
> A: Eugenio Trumpy
> Cc: geonode-users
> Oggetto: Re: [GeoNode-users] upload doesn't work without any logs
> Hi Eugenio,
> the browser developers console is for sure the first place where to look.
> Best
> Il giorno mar 12 giu 2018 alle ore 11:25 Eugenio Trumpy <
> frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com
> <frippe12573 at hotmail.com>>> ha scritto:
> Hi all,
> I have problem with geonode 2.4 dev20160525015826.
> It worked properly, but currently I have problems uploading shp file.
> The strange thing is that nothing is written on the logs (apache2
> error.log and geoserver.log).
> Could you suggest me how to investigate on this problem?
> Thanks,
> Eugenio
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180612/7e8c988e/attachment-0001.html>
More information about the geonode-users mailing list
