[GeoNode-users] upload doesn't work without any logs (Eugenio Trumpy)
Eugenio Trumpy
frippe12573 at hotmail.com
Wed Jun 13 08:11:20 PDT 2018
Hi Alessio and all,
I understood the problem was caused by the SHP file itself.
The SHP file had some field names longer than 9 character and with some special character (e.g. °),
I changed the name of the fields and the upload worked fine.
Thank you for your support anyway.
Ciao
Eugenio
Da: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Inviato: martedì 12 giugno 2018 17:32
A: Eugenio Trumpy
Cc: Alessio Fabiani; Toni Schönbuchner; geonode-users
Oggetto: Re: [GeoNode-users] upload doesn't work without any logs (Eugenio Trumpy)
Uhm, that's weird. And I guess no layer has been created on GeoServer also, right?
Could you maybe try to create the layer on GeoServer first and than run
python manage.py updatelayers --skip-geonode-registered --skip-unadvertised
Il giorno mar 12 giu 2018 alle ore 17:27 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> ha scritto:
Hi Alessio,
that's really strange! It happens only with some recent SHP files created by QGIS from csv file.
I tried with a SHP created today as polygon and it works properly.
Following your suggestion I set:
log4j.category.org.geoserver=DEBUG
then I tried to upload the SHP file that was not uploaded, the same in the log
I cannot find any new lines.
Eugenio
Da: Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>
Inviato: martedì 12 giugno 2018 17:09
A: Eugenio Trumpy
Cc: Toni Schönbuchner; geonode-users
Hi Eugenio,
try maybe to rise up the GeoServer log level and check the logs (of GeoServer) after the upload.
Maybe the SHP cannot be read from GeoServer for some reason.
Also, is this happening with every dataset or just with one SHP?
Il giorno mar 12 giu 2018 alle ore 17:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> ha scritto:
Dear Toni,
I set:
DEBUG=True
in local_setting.py configuration file. Since I have a geosites installation the local_setting I meant before was the general one (not inside the sites folder).
Once I try to upload a shp file nothing is written in apache2 access.log
The shape file is very very small! Deleted even the cookies, but nothing change.
Eugenio
Da: Toni Schönbuchner <toni.schoenbuchner at csgis.de<mailto:toni.schoenbuchner at csgis.de>>
Inviato: martedì 12 giugno 2018 16:09
A: Eugenio Trumpy
Cc: geonode-users
Oggetto: Re: upload doesn't work without any logs (Eugenio Trumpy)
Dear Eugenio,
have you tried to set DEBUG to true in local_settings? Further do you see the request in apaches access log?
An upload which exeeds the allowed filesize limit can cause a 400 as well. Is your file of tremendous size?
Next can you check your cookies in developer tools? It could be worth to delete all of them and retry with a
fresh session.
cheers,
Toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil +49/ (0) 176 6680 3198
Tel +49/ (0) 341 24 04 738
Fax +49/ (0) 341 24 04 73
Web http://csgis.de
CSGIS<http://csgis.de/>
csgis.de<http://csgis.de>
OneCause is premium, responsive theme built with Bootstrap for Joomla CMS. With a clean and minimal design, this multi-purpose template is perfect for anything you can imagine.
Hinweis gemäß § 33 BDSG
Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
Am 12.06.2018 um 14:42 schrieb Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
No IP or domain changed.
That's weird...
E.
Inviato: martedì 12 giugno 2018 14:17
A: frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>
Cc: geonode-users
Dear Eugenio,
did you change anything on your ip or domain setup which could cause the error 400?
Cheers,
Toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Web http://csgis.de<http://csgis.de/>
Message: 4
Date: Tue, 12 Jun 2018 11:55:43 +0000
From: Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>
To: Simone Dalmasso <simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>>
Cc: geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Subject: Re: [GeoNode-users] upload doesn't work without any logs
Message-ID:
<AM5P190MB0420AB6A1C678D9CEFBF67D4E57F0 at AM5P190MB0420.EURP190.PROD.OUTLOOK.COM<mailto:AM5P190MB0420AB6A1C678D9CEFBF67D4E57F0 at AM5P190MB0420.EURP190.PROD.OUTLOOK.COM>>
Content-Type: text/plain; charset="iso-8859-1"
Hi Simone,
here is the issue:
POST http://gemex.igg.cnr.it/layers/upload 400 (BAD REQUEST)
any hints?
Eugenio
Da: Simone Dalmasso <simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>>
Inviato: martedì 12 giugno 2018 13:41
A: Eugenio Trumpy
Cc: geonode-users
Hi Eugenio,
the browser developers console is for sure the first place where to look.
Best
Il giorno mar 12 giu 2018 alle ore 11:25 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com><mailto:frippe12573 at hotmail.com>> ha scritto:
Hi all,
I have problem with geonode 2.4 dev20160525015826.
It worked properly, but currently I have problems uploading shp file.
The strange thing is that nothing is written on the logs (apache2 error.log and geoserver.log).
Could you suggest me how to investigate on this problem?
Thanks,
Eugenio
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180613/81d381b9/attachment-0001.html>
More information about the geonode-users
